Accept default description from FeatureSource Info or Schema description
Key: GEOS-2865
URL: http://jira.codehaus.org/browse/GEOS-2865
Project: GeoServer
Issue Type: Wish
Components: Configuration
Reporter: Jody Garnett
Assignee: Andrea Aime
Fix For: 1.7.4
When creating a new Layer the user has the opportunity to type in the Title and Abstract (and keywords etc...). Right now we base a lot of this information on the name of the feature source being described.
We should be able to get better default values from:
- FeatureSource.getInfo()
- description associated with the schema FeatureType (or contained attribute types)
The driver for this bug report is the CCIP integration showcase where MarkLeslie has filled in all the table descriptions in the PostGIS database; and a lot of the column descriptions as well. It would be good to leverage this work as default descriptions; rather than copying and pasting the text out of pgAdmin.
