[Geoserver-devel] [jira] Created: (GEOS-2870) Style generated to label cities was invalid
                 Key: GEOS-2870
                 URL: http://jira.codehaus.org/browse/GEOS-2870
             Project: GeoServer
          Issue Type: Bug
          Components: UI
    Affects Versions: 1.7.3
         Environment: http://ccip.lisasoft.com:8080/geoserver/
            Reporter: Jody Garnett
            Assignee: Andrea Aime
            Priority: Trivial
Using the style editor to generate labeled cities produced an invalid style; when the map preview widget was called from internet explorer a wms exception was immediately produced.
# Initially the style was generated without name
# Copying the style into uDig it did not pass validation
The generated style is here:
{code:xml}
<StyledLayerDescriptor version="1.0.0"
  xsi:schemaLocation="http://www.opengis.net/sld StyledLayerDescriptor.xsd"
  xmlns="http://www.opengis.net/sld&quot; xmlns:ogc="http://www.opengis.net/ogc&quot;
  xmlns:xlink="http://www.w3.org/1999/xlink&quot;
  xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot;&gt;
<NamedLayer>
    <Name>city</Name>
    <UserStyle>
      <Name>city_style</Name>
      <Title>geoserver style</Title>
      <Abstract>Generated by GeoServer</Abstract>
      <FeatureTypeStyle>
      <Rule>
        <PointSymbolizer>
          <Graphic>
  <Mark>
    <WellKnownName></WellKnownName>
          <Fill>
            <CssParameter name="fill">#0000BB</CssParameter>
            <CssParameter name="fill-opacity">1</CssParameter>
          </Fill>
  </Mark>
  <Opacity>1</Opacity>
  <Size>5</Size>
</Graphic>
        </PointSymbolizer>
        <TextSymbolizer>
          <Label>
            <ogc:PropertyName>name</ogc:PropertyName>
          </Label>
            <Font>
              <CssParameter name="font-family">Times New Roman</CssParameter>
              <CssParameter name="font-style">Normal</CssParameter>
              <CssParameter name="font-size">12</CssParameter>
            </Font>
          <Fill>
            <CssParameter name="fill">#000000</CssParameter>
          </Fill>
        </TextSymbolizer>
      </Rule>
      </FeatureTypeStyle>
    </UserStyle>
  </NamedLayer>
</StyledLayerDescriptor>
{code:xml}
