Message:
A new issue has been created in JIRA.
View the issue:
http://jira.codehaus.org/browse/GEOS-290
Here is an overview of the issue:
Key: GEOS-290
Summary: Fails at compiling. org.vfny.geoserver.global.ConfigurationException: there is no namespace defined for datatasore 'biz'
Type: Bug
Status: Open
Priority: Major
Original Estimate: 1 day
Time Spent: Unknown
Remaining: 1 day
Project: GeoServer
Components:
Configuration
Versions:
1.2.3
Assignee: Chris Holmes
Reporter: Michael Jenik
Created: Fri, 18 Feb 2005 4:35 AM
Updated: Fri, 18 Feb 2005 4:35 AM
Description:
I was configuring the datastore. I made a postgis conection.
Then I submited all in the FeatureType Editor.
Then I restarted the server.
And then I have an error compiling geoserver..
My Configuration : Tomcat5 , geoserver 1.2.3 , postgis 9 .
Here is the tomcat log:
("lanzó excepción de" means "threw exeption about")
2005-02-18 05:39:43 StandardContext[/geoserver]El Servlet /geoserver lanzó excepción de load()
javax.servlet.ServletException: there is no namespace defined for datatasore 'biz'
at org.vfny.geoserver.global.GeoServerPlugIn.init(GeoServerPlugIn.java:146)
at org.apache.struts.action.ActionServlet.initModulePlugIns(ActionServlet.java:1158)
at org.apache.struts.action.ActionServlet.init(ActionServlet.java:473)
at javax.servlet.GenericServlet.init(GenericServlet.java:211)
at org.apache.catalina.core.StandardWrapper.loadServlet(StandardWrapper.java:1029)
at org.apache.catalina.core.StandardWrapper.load(StandardWrapper.java:862)
at org.apache.catalina.core.StandardContext.loadOnStartup(StandardContext.java:4013)
at org.apache.catalina.core.StandardContext.start(StandardContext.java:4357)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:823)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:807)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:595)
at org.apache.catalina.core.StandardHostDeployer.install(StandardHostDeployer.java:277)
at org.apache.catalina.core.StandardHost.install(StandardHost.java:832)
at org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:625)
at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:431)
at org.apache.catalina.startup.HostConfig.start(HostConfig.java:983)
at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:349)
at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:119)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1091)
at org.apache.catalina.core.StandardHost.start(StandardHost.java:789)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1083)
at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:478)
at org.apache.catalina.core.StandardService.start(StandardService.java:480)
at org.apache.catalina.core.StandardServer.start(StandardServer.java:2313)
at org.apache.catalina.startup.Catalina.start(Catalina.java:556)
at java.lang.reflect.Method.invoke(Method.java:324)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:287)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:425)
----- Root Cause -----
at org.vfny.geoserver.global.xml.XMLConfigReader.loadDataStore(XMLConfigReader.java:762)
at org.vfny.geoserver.global.xml.XMLConfigReader.loadDataStores(XMLConfigReader.java:720)
at org.vfny.geoserver.global.xml.XMLConfigReader.loadCatalog(XMLConfigReader.java:257)
at org.vfny.geoserver.global.xml.XMLConfigReader.load(XMLConfigReader.java:163)
at org.vfny.geoserver.global.xml.XMLConfigReader.<init>(XMLConfigReader.java:131)
at org.vfny.geoserver.global.GeoServerPlugIn.init(GeoServerPlugIn.java:88)
Do I solve this error by upgrading to 1.2.4 ?
This Soft looks good .
Congratulations for the high reached point.
Please Help...
Reagards ,
Mike
JIRA INFORMATION:
If you want more information on JIRA, or have a bug to report see:
