[Geoserver-devel] [jira] Created: (GEOS-2907) Add geoserver profiles
                 Key: GEOS-2907
                 URL: http://jira.codehaus.org/browse/GEOS-2907
             Project: GeoServer
          Issue Type: Task
          Components: Configuration
            Reporter: Justin Deoliveira
            Assignee: Justin Deoliveira
             Fix For: 2.0.x
Add the notion of a "profile", that is a virtual geoserver configuration. The thought here is that a profile is just another instance of the GeoServer interface. GeoServer will need a name, as profiles are named.
