Modify GeoServer to return a view of the catalog
Key: GEOS-2919
URL: http://jira.codehaus.org/browse/GEOS-2919
Project: GeoServer
Issue Type: Task
Reporter: Justin Deoliveira
Assignee: Justin Deoliveira
Fix For: 2.0.x
Modify org.geoserver.config.GeoServer to return a thread local view of the catalog. This view can be set in a couple of different ways:
* If a map is specified by the client, the thread local view should be the map filtered catalog
* If the active profile is not the global profile, the thread local view should be the profile filtered catalog
