Message:
A new issue has been created in JIRA.
View the issue:
http://jira.codehaus.org/browse/GEOS-292
Here is an overview of the issue:
Key: GEOS-292
Summary: Dispatcher servlet not working for WFS under Tomcat 5.5.7
Type: Bug
Status: Open
Priority: Minor
Original Estimate: 1 day
Time Spent: Unknown
Remaining: 1 day
Project: GeoServer
Components:
WFS
Versions:
1.2.5
Assignee: Chris Holmes
Reporter: Craig E. Oaks
Created: Fri, 18 Feb 2005 4:17 PM
Updated: Fri, 18 Feb 2005 4:17 PM
Environment: Geoserver 1.2.4, Tomcat 5.5.7, Java 1.5, WinXP
Description:
The Geoserver Dispatcher servlet is not working for WFS under Tomcat 5.5.7. This bug only occurs when performing XML requests and does not occur during KVP requests. I have tried both replacing and removing xalan.jar and have also reproduced the error under Java 1.4.2_07. (Note that a GeoServer install using Jetty in the same environment does not encounter this issue).
For example, an XML request of: http://someserver:8080/geoserver/wfs/GetFeature will return a valid GML response; however, a request of http://someserver:8080/geoserver/wfs (/GetFeature omitted) returns the following Tomcat 500 Server Error:
HTTP Status 500 -
type Exception report
message
description The server encountered an internal error () that prevented it from fulfilling this request.
exception
java.lang.IllegalStateException: getOutputStream() has already been called for this response
org.apache.catalina.connector.Response.getWriter(Response.java:596)
org.apache.catalina.connector.ResponseFacade.getWriter(ResponseFacade.java:186)
org.vfny.geoserver.servlets.wfs.TestWfsPost.processRequest(TestWfsPost.java:231)
org.vfny.geoserver.servlets.wfs.TestWfsPost.doPost(TestWfsPost.java:72)
javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
javax.servlet.http.HttpServlet.service(HttpServlet.java:802)
note The full stack trace of the root cause is available in the Apache Tomcat/5.5.7 logs.
Apache Tomcat/5.5.7
Thanks for your help!
JIRA INFORMATION:
If you want more information on JIRA, or have a bug to report see:
