[Geoserver-devel] [jira] Created: (GEOS-2922) Catalog XStream depersister causes startup failure with CITE WFS 1.1 config
                 Key: GEOS-2922
                 URL: http://jira.codehaus.org/browse/GEOS-2922
             Project: GeoServer
          Issue Type: Bug
          Components: Global
            Reporter: Ben Caradoc-Davies
            Assignee: Andrea Aime
         Attachments: GeoServerLoader.patch
Starting GeoServer with the CITE WFS 1.1 config fails because the the XStream depersister sets the FeatureTypeInfo attributes list to null, causing a NPE in GeoServerLoader.
Workaround: apply attached patch to check for null attributes list in GeoServerLoader.
Better fix: change XStream depersister to set attribute list to an empty list, not null.
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
20 Apr 14:19:39 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: /home/car605/geoserver/cite/geoserver-trunk/src/community/web2/app/src/main/webapp/data
20 Apr 14:19:39 INFO [util.ApplicationContextProvider] - No context parameter, system or Java environment variables found for GEOSERVER_WMS_URL
20 Apr 14:19:39 INFO [util.ApplicationContextProvider] - Reverting to http://localhost:8080/geoserver/wms?request=GetCapabilities
20 Apr 14:19:39 INFO [util.GetCapabilitiesConfiguration] - Constructing from url http://localhost:8080/geoserver/wms?request=GetCapabilities
20 Apr 14:19:39 INFO [org.geoserver] - Loaded workspace 'it.geosolutions'
20 Apr 14:19:39 INFO [org.geoserver] - Loaded workspace 'sf'
20 Apr 14:19:39 INFO [org.geoserver] - Loaded store 'sf', enabled
20 Apr 14:19:39 INFO [org.geoserver] - Loaded data store 'sf'
20 Apr 14:19:39 WARN [referencing.factory] - Axis elements found in a wkt definition, the force longitude first axis order hint might not be respected:
PROJCS["Monte Mario / Italy zone 1", GEOGCS["Monte Mario", DATUM["Monte Mario", SPHEROID["International 1924", 6378388.0, 297.0, AUTHORITY["EPSG","7022"]], TOWGS84[-104.1,-49.1,-9.9,0.971,-2.917,0.714,-11.68], AUTHORITY["EPSG","6265"]], PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]], UNIT["degree", 0.017453292519943295], AXIS["Geodetic longitude", EAST], AXIS["Geodetic latitude", NORTH], AUTHORITY["EPSG","4265"]], PROJECTION["Transverse Mercator", AUTHORITY["EPSG","9807"]], PARAMETER["central_meridian", 9.0], PARAMETER["latitude_of_origin", 0.0], PARAMETER["scale_factor", 0.9996], PARAMETER["false_easting", 1500000.0], PARAMETER["false_northing", 0.0], UNIT["m", 1.0], AXIS["Easting", EAST], AXIS["Northing", NORTH], AUTHORITY["EPSG","3003"]]
20 Apr 14:19:40 INFO [org.geoserver] - Loaded feature type 'PrimitiveGeoFeature', disabled
20 Apr 14:19:41 WARN [org.geoserver] - Schema override failed for feature type 'PrimitiveGeoFeature'
java.lang.NullPointerException
  at org.geoserver.config.GeoServerLoader.handleSchemaOverride(GeoServerLoader.java:792)
  at org.geoserver.config.GeoServerLoader.readCatalog(GeoServerLoader.java:532)
  at org.geoserver.config.GeoServerLoader.loadCatalog(GeoServerLoader.java:154)
  at org.geoserver.config.GeoServerLoader.postProcessBeforeInitialization(GeoServerLoader.java:125)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanFactory.java:350)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1330)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:473)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409)
  at java.security.AccessController.doPrivileged(Native Method)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:380)
  at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:264)
  at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:221)
  at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:261)
  at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:185)
  at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:164)
  at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:269)
  at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:104)
  at org.springframework.beans.factory.support.ConstructorResolver.resolveConstructorArguments(ConstructorResolver.java:495)
  at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:162)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:925)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:835)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:440)
  at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveManagedList(BeanDefinitionValueResolver.java:287)
  at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:126)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1245)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1010)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:472)
  at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:429)
  at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:729)
  at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:381)
  at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:255)
  at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:199)
  at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:45)
  at org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.java:540)
  at org.mortbay.jetty.servlet.Context.startContext(Context.java:135)
  at org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1220)
  at org.mortbay.jetty.handler.ContextHandler.doStart(ContextHandler.java:510)
  at org.mortbay.jetty.webapp.WebAppContext.doStart(WebAppContext.java:448)
  at org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCycle.java:39)
  at org.mortbay.jetty.handler.HandlerWrapper.doStart(HandlerWrapper.java:130)
  at org.mortbay.jetty.Server.doStart(Server.java:222)
  at org.geoserver.web.Start.main(Start.java:57)
20 Apr 14:19:41 INFO [org.geoserver] - Loaded feature type 'sf'
20 Apr 14:19:41 INFO [org.geoserver] - Loaded layer 'PrimitiveGeoFeature'
20 Apr 14:19:41 INFO [org.geoserver] - Loaded feature type 'AggregateGeoFeature', disabled
20 Apr 14:19:41 WARN [org.geoserver] - Schema override failed for feature type 'AggregateGeoFeature'
20 Apr 14:19:41 INFO [org.geoserver] - Loaded layer 'AggregateGeoFeature'
20 Apr 14:19:41 INFO [org.geoserver] - Loaded feature type 'EntitéGénérique', disabled
20 Apr 14:19:41 WARN [org.geoserver] - Schema override failed for feature type 'EntitéGénérique'
20 Apr 14:19:41 INFO [org.geoserver] - Loaded layer 'EntitéGénérique'
20 Apr 14:19:41 INFO [util.ApplicationContextProvider] - No context parameter, system or Java environment variables found for GEOSERVER_WMS_URL
20 Apr 14:19:41 INFO [util.ApplicationContextProvider] - Reverting to http://localhost:8080/geoserver/wms
20 Apr 14:19:41 WARN [storage.DefaultStorageFinder] - Found no usable default cache prefixes !!! Please set GEOWEBCACHE_CACHE_DIR if you would like a specific location.
20 Apr 14:19:41 WARN [storage.DefaultStorageFinder] - Reverting to java.io.tmpdir: /tmp/geowebcache
20 Apr 14:19:42 INFO [geowebcache.GeoWebCacheDispatcher] - set TileLayerDispatcher
20 Apr 14:19:42 INFO [geowebcache.GeoWebCacheDispatcher] - Invoked setServletPrefix(gwc)
20 Apr 14:19:42 INFO [wms.WMSService] - Will proxy requests to backend that are not getmap or getcapabilities.
20 Apr 14:19:42 INFO [util.ApplicationContextProvider] - No context parameter, system or Java environment variables found for GEOSERVER_WFS_URL
20 Apr 14:19:42 INFO [util.ApplicationContextProvider] - Reverting to null
20 Apr 14:19:42 INFO [util.ApplicationContextProvider] - No context parameter, system or Java environment variables found for GEOWEBCACHE_WFS_FILTER
20 Apr 14:19:42 INFO [wfs.WFSService] - Configured to forward to http://localhost:8080/geoserver/wfs , timeout is 600000ms, regex filter null
20 Apr 14:19:42 INFO [rest.RESTDispatcher] - Created RESTDispatcher with 4 paths
20 Apr 14:19:42 INFO [org.geoserver] - Loaded service 'wcs', enabled
20 Apr 14:19:42 INFO [org.geoserver] - Loaded service 'wfs', enabled
20 Apr 14:19:42 INFO [org.geoserver] - Loaded service 'wms', enabled
