[Geoserver-devel] [jira] Created: (GEOS-295) Invalid datastore connection blocks update/delete for other connections
Message:
  A new issue has been created in JIRA.
View the issue:
  http://jira.codehaus.org/browse/GEOS-295
Here is an overview of the issue:
        Key: GEOS-295
    Summary: Invalid datastore connection blocks update/delete for other connections
       Type: Bug
     Status: Open
   Priority: Major
Original Estimate: Unknown
Time Spent: Unknown
  Remaining: Unknown
    Project: GeoServer
   Assignee: Chris Holmes
   Reporter: Holger Lang
    Created: Tue, 22 Feb 2005 5:10 AM
    Updated: Tue, 22 Feb 2005 5:10 AM
Description:
if there is a ArcSDE or PostGis datastore configurated on the GeoServer configuration page and the datastore connection becomes invalid, the delete and update request for featuretypes which uses other datastores (like shapefiles) is blocked.
Following error message will be thrown in this case:
java.util.NoSuchElementException:
No datastore found capable of managing DataStoreConfig[namespace=topp, enabled=false, abstract=My local postgis testing database, connection parameters={namespace=http://www.openplans.org/topp, user=postgres, passwd=postgres, host=localhost, port=5432, database=dcmms, dbtype=postgis}] at org.vfny.geoserver.global.DataStoreInfo.getDataStore(DataStoreInfo.java:235) at org.vfny.geoserver.global.Data.lockExists(Data.java:1303) at org.vfny.geoserver.responses.wfs.TransactionResponse.execute(TransactionResponse.java:268)
Greetings,
Holger
JIRA INFORMATION:
If you want more information on JIRA, or have a bug to report see:
