[Geoserver-devel] [jira] Created: (GEOS-2957) CatalogImpl.resolve() does not set CoverageInfo.parameters to an empty map producing an NPE when trying to use it
                 Key: GEOS-2957
                 URL: http://jira.codehaus.org/browse/GEOS-2957
             Project: GeoServer
          Issue Type: Bug
            Reporter: Gabriel Roldán
            Assignee: Gabriel Roldán
             Fix For: 2.0-beta1
{{CoverageInfo.getParameters():Map<String,Serializable>}} shouldn't return null but an empty map. When loading the configuration, since xstream sets the collection properties to null if non present, CatalogImpl.resolve() is meant to fix that as a post processing step after xstream loading, but it is not setting that property
