[Geoserver-devel] [jira] Created: (GEOS-2960) Find a way for DataStorePanelInfo bean declarations not to depend on the corresponding geotools plugin being on the classpath
                 Key: GEOS-2960
                 URL: http://jira.codehaus.org/browse/GEOS-2960
             Project: GeoServer
          Issue Type: Task
          Components: Wicket UI
    Affects Versions: 2.0-alpha1
            Reporter: Gabriel Roldán
            Assignee: Gabriel Roldán
             Fix For: 2.0.x
The custom icons for the different store types can be declared in the app-code applicationContext through an instantiation of {{DataStorePanelInfo}}, but if the corresponding geotools plugin is not on the classpath the bean creation fails (cause the datastore factory/gce format is not found), preventing the whole application to function
