[Geoserver-devel] [jira] Created: (GEOS-2961) Record Tomcat version requirements in documentation
                 Key: GEOS-2961
                 URL: http://jira.codehaus.org/browse/GEOS-2961
             Project: GeoServer
          Issue Type: Task
          Components: Documentation
            Reporter: Paul Ramsey
            Assignee: Andrea Aime
The otherwise verbose "Running In A Production Environment" section doesn't indicate what versions of Tomcat Geoserver is compatible with. Ideally, a little table of geoserver versions, and tomcat/java versions, with indications of "no", "not recommended", "works" would be good. Also other containers, to the extent that the knowledge of compatibility exists. IT managers will want to compare what works with what they have.
