[Geoserver-devel] [jira] Created: (GEOS-2963) GetLegendGraphic with coverages -- width parameter misbehaves
                 Key: GEOS-2963
                 URL: http://jira.codehaus.org/browse/GEOS-2963
             Project: GeoServer
          Issue Type: Bug
          Components: WMS
    Affects Versions: 1.7.2
         Environment: Version of JVM: Sun Microsystems Inc. : 1.6.0_02
Linux RH v???
            Reporter: Emanuele Tajariol
            Assignee: Andrea Aime
         Attachments: geoserver_style.xml
The width parameter in this url
   http://server:port/geoserver/wms?VERSION=1.1.1&REQUEST=GetLegendGraphic&LAYER=cropland4&STYLE=cropland&WIDTH=50&HEIGHT=20&FORMAT=image/png&BGCOLOR=0xFFFFFF&TRANSPARENT=TRUE
will set the width of the coloured block, not of the whole image.
If labels are too long, they'll not fit in the image, and will be cropped.
The attached SLD defines a label "Rainfed herbaceous crops,shrub" that does not fit entirely in the image width, and anything longer will be cropped as well.
