[Geoserver-devel] [jira] Created: (GEOS-2967) Deleting all layers from layer group causes NullPointerException
                 Key: GEOS-2967
                 URL: http://jira.codehaus.org/browse/GEOS-2967
             Project: GeoServer
          Issue Type: Bug
    Affects Versions: 2.0-alpha2
         Environment: Ubuntu Jaunty
            Reporter: Tim Coulter
            Assignee: Andrea Aime
When removing all layers from a layer group, Geoserver returns a Null Pointer Exception.
Steps to reproduce:
1) Log into Geoserver and click on the "Layer Groups" link on the right hand side.
2) Select the 'tiger-ny' layer group that comes pre-installed with Geosever, then proceed to remove all of tiger-ny's layers by using the minus sign next to each layer in the list.
3) Once all of the layers are removed, click the "Save" button. Notice that you get a page titled "Unexpected RuntimeException" showing the exception listed below.
Exception:
WicketMessage: Method onFormSubmitted of interface org.apache.wicket.markup.html.form.IFormSubmitListener targeted at component [MarkupContainer [Component id = form]] threw an exception
Root cause:
java.lang.NullPointerException: Layer group must not be empty
at org.geoserver.catalog.impl.CatalogImpl.validate(CatalogImpl.java:827)
at org.geoserver.catalog.impl.CatalogImpl.save(CatalogImpl.java:842)
at org.geoserver.security.SecureCatalogImpl.save(SecureCatalogImpl.java:930)
at org.geoserver.web.data.layergroup.LayerGroupEditPage$2.onSubmit(LayerGroupEditPage.java:114)
at org.apache.wicket.markup.html.form.Form.delegateSubmit(Form.java:1351)
at org.apache.wicket.markup.html.form.Form.onFormSubmitted(Form.java:810)
at org.apache.wicket.RequestListenerInterface.invoke(RequestListenerInterface.java:183)
at org.apache.wicket.request.target.component.listener.ListenerInterfaceRequestTarget.processEvents(ListenerInterfaceRequestTarget.java:73)
at org.apache.wicket.request.AbstractRequestCycleProcessor.processEvents(AbstractRequestCycleProcessor.java:91)
at org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1175)
at org.apache.wicket.RequestCycle.step(RequestCycle.java:1252)
at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1353)
at org.apache.wicket.RequestCycle.request(RequestCycle.java:493)
at org.apache.wicket.protocol.http.WicketFilter.doGet(WicketFilter.java:355)
at org.apache.wicket.protocol.http.WicketServlet.doPost(WicketServlet.java:145)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:158)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:142)
at org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:81)
at org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:217)
at org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:106)
at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:176)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:206)
at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:324)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
at org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:842)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:648)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:395)
at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
Complete stack:
org.apache.wicket.WicketRuntimeException: Method onFormSubmitted of interface org.apache.wicket.markup.html.form.IFormSubmitListener targeted at component [MarkupContainer [Component id = form]] threw an exception
at org.apache.wicket.RequestListenerInterface.invoke(RequestListenerInterface.java:194)
java.lang.reflect.InvocationTargetException
at sun.reflect.GeneratedMethodAccessor163.invoke(Unknown Source)
