[Geoserver-devel] [jira] Created: (GEOS-2971) Removing keywords from WFS, WMS, WCS metadata removes ALL keywords.
Removing keywords from WFS,WMS,WCS metadata removes ALL keywords.
                 Key: GEOS-2971
                 URL: http://jira.codehaus.org/browse/GEOS-2971
             Project: GeoServer
          Issue Type: Bug
    Affects Versions: 2.0-alpha2
         Environment: Ubuntu Jaunty
            Reporter: Tim Coulter
            Assignee: Andrea Aime
When removing keywords from WFS, WMS and WCS metadata, all keywords are removed regardless of whether or not any keywords were selected.
Steps to reproduce:
1) Login to Geosever and click on either the WFS, WMS, or WCS links under the Services heading.
2) Scroll down to the section labeled Current Keywords, and select one item in the list box by clicking on it with your mouse. The item you selected should now be highlighted.
3) Click the "Remove Selected" button. Notice that after the page reloads, no keywords are present within the list box.
Note: If you do not select any keyword in step #2 and simply click the "Remove Selected" button in step #3, all keywords are still removed.
