[Geoserver-devel] [jira] Created: (GEOS-2981) Deleting store causes RuntimeException
                 Key: GEOS-2981
                 URL: http://jira.codehaus.org/browse/GEOS-2981
             Project: GeoServer
          Issue Type: Bug
    Affects Versions: 2.0-alpha2
         Environment: Ubuntu Jaunty
            Reporter: Tim Coulter
            Assignee: Andrea Aime
When removing a store that contains layers, Geoserver returns a RuntimeException.
Steps to reproduce:
1) Login to a fresh install of Geoserver as the admin user.
2) Click the Stores link on the left hand side of the page, and find the states_shapefile store in the list on the resulting page.
3) Click the Remove link in the same row as the states_shapefile store, and notice you are given the following alert message: "Are you sure you want to remove states_shapefile ? All dependent layers will be removed as well."
4) Click OK in the alert message, and notice you are given the exception listed below.
Discussion:
The message in the RuntimeException implies that non-empty stores cannot be deleted. However, the alert message shown in step #3 states that dependent layers will be removed if the store is deleted. Although the RuntimeException should be fixed out of principle, what will Geoserver do: Delete the layers itself, or expect the user to delete them manually? If the latter, we should change the alert message shown in step #3.
Exception:
Unexpected RuntimeException
Root cause:
java.lang.IllegalArgumentException: Unable to delete non-empty store.
at org.geoserver.catalog.impl.CatalogImpl.remove(CatalogImpl.java:156)
at org.geoserver.security.SecureCatalogImpl.remove(SecureCatalogImpl.java:914)
at org.geoserver.web.data.store.StorePanel$3.onClick(StorePanel.java:134)
at org.geoserver.web.wicket.ConfirmationAjaxLink$1.onClick(ConfirmationAjaxLink.java:51)
at org.apache.wicket.ajax.markup.html.AjaxLink$1.onEvent(AjaxLink.java:65)
at org.apache.wicket.ajax.AjaxEventBehavior.respond(AjaxEventBehavior.java:163)
at org.apache.wicket.ajax.AbstractDefaultAjaxBehavior.onRequest(AbstractDefaultAjaxBehavior.java:297)
at org.apache.wicket.request.target.component.listener.BehaviorRequestTarget.processEvents(BehaviorRequestTarget.java:100)
at org.apache.wicket.request.AbstractRequestCycleProcessor.processEvents(AbstractRequestCycleProcessor.java:91)
at org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1175)
at org.apache.wicket.RequestCycle.step(RequestCycle.java:1252)
at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1353)
at org.apache.wicket.RequestCycle.request(RequestCycle.java:493)
at org.apache.wicket.protocol.http.WicketFilter.doGet(WicketFilter.java:355)
at org.apache.wicket.protocol.http.WicketServlet.doGet(WicketServlet.java:124)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:158)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:142)
at org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:81)
at org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:217)
at org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:106)
at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:176)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:206)
at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:324)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:828)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:514)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:395)
at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
