[Geoserver-devel] [jira] Created: (GEOS-2984) GeoServer won't build with Maven 2.1.0
                 Key: GEOS-2984
                 URL: http://jira.codehaus.org/browse/GEOS-2984
             Project: GeoServer
          Issue Type: Bug
    Affects Versions: 1.7.4
            Reporter: Andrea Aime
            Assignee: Andrea Aime
             Fix For: 1.7.5, 2.0-beta1
{code}
aaime@anonymised.com:~/devel/gs-1.7.x/src$ mvn21 clean install
[INFO] Scanning for projects...
[WARNING] Overriding profile: 'geosearch' (source: pom) with new instance from source: pom
[ERROR] BUILD FAILURE
[INFO] The projects in the reactor contain a cyclic reference: Edge between 'Vertex{label='org.geoserver.maven:build-configs'}' and 'Vertex{label='org.geoserver.maven:build-configs'}' introduces to cycle in the graph org.geoserver.maven:build-configs --> org.geoserver.maven:build-configs
[INFO] Total time: 2 seconds
[INFO] Finished at: Tue May 05 09:42:40 GMT+01:00 2009
[INFO] Final Memory: 8M/73M
{code}
