Cannot use absolute paths in Mosaic Plugin
Key: GEOS-2985
URL: http://jira.codehaus.org/browse/GEOS-2985
Project: GeoServer
Issue Type: Bug
Affects Versions: 1.7.4
Environment: Windows XP; JDK 1.6.0_13
Reporter: Ralf Wagner
Assignee: Andrea Aime
Priority: Minor
It seems that in version 1.7.4 Mosaic Plugin always appends current directory to the path of given raster file. So, mosaics which worked fine in version 1.7.3, fails on 1.7.4. Here is sample entry from logfile:
2009-05-05 10:35:30,886 INFO [gce.imagemosai] - Unable to read image for file C:\Home\Rpw\DHO\trunk\GeoServer\data_dir\coverages\Ortofoto_2000pas6_m\C:\Home\Rpw\DHO\trunk\GeoServer\data_dir\coverages\Ortofoto_2000pas6_m\6.165.33.01.tif
DBF file for given SHP file contains following path: "C:\Home\Rpw\DHO\trunk\GeoServer\data_dir\coverages\Ortofoto_2000pas6_m\6.165.33.01.tif"
