restconfig: Add support for external and url upload methods to send coverages
Key: GEOS-3004
URL: http://jira.codehaus.org/browse/GEOS-3004
Project: GeoServer
Issue Type: Bug
Affects Versions: 1.7.4
Reporter: Daniele Romagnoli
Assignee: Andrea Aime
Fix For: 1.7.5
Actually, only direct upload method is supported (file.format method).
We need to support also external and url methods. (adding proper entries in the applicationContext)
Note that when adding a coverage with the external upload method, geoserver doesn't need to create a directory/and copy the uploaded file within the GEOSERVER_DATA_DIR/data folder.
It only needs to set the info.xml within a proper element on GEOSERVER_DATA_DIR/coverages subfolder.
We also need to relax the mediatype check on the StoreFileResource.handleFileUpload method since rest requestes may come without an explicit content-type.
I'm working on it.
