[Geoserver-devel] [jira] Created: (GEOS-3012) GetMapTest not an OnlineTest and fails when remote service unavailable
                 Key: GEOS-3012
                 URL: http://jira.codehaus.org/browse/GEOS-3012
             Project: GeoServer
          Issue Type: Bug
          Components: WMS
            Reporter: Ben Caradoc-Davies
            Assignee: Andrea Aime
            Priority: Blocker
I am getting very tired of GetMapTest failures. It should be an OnlineTestCase.
Failed tests:
  testRemoteOWSUserStyleGet(org.vfny.geoserver.wms.responses.map.png.GetMapTest)
08 May 14:24:42 ERROR [geoserver.ows] -
org.vfny.geoserver.wms.WmsException: Could not connect to remote OWS
  at org.geoserver.wms.kvp.GetMapKvpRequestReader.connectRemoteWFS(GetMapKvpRequestReader.java:1123)
  at org.geoserver.wms.kvp.GetMapKvpRequestReader.addRemoteLayersFromUserLayer(GetMapKvpRequestReader.java:630)
  at org.geoserver.wms.kvp.GetMapKvpRequestReader.processStandaloneSld(GetMapKvpRequestReader.java:548)
  at org.geoserver.wms.kvp.GetMapKvpRequestReader.processSld(GetMapKvpRequestReader.java:429)
  at org.geoserver.wms.kvp.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:257)
  at org.geoserver.wms.kvp.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:1)
  at org.geoserver.ows.Dispatcher.parseRequestKVP(Dispatcher.java:1092)
  at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:431)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:209)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1040)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1007)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:454)
  at org.vfny.geoserver.wms.responses.map.png.GetMapTest.testRemoteOWSUserStyleGet(GetMapTest.java:143)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:131)
  at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
  at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
  at junit.extensions.TestSetup.run(TestSetup.java:25)
  at org.eclipse.jdt.internal.junit.runner.junit3.JUnit3TestReference.run(JUnit3TestReference.java:130)
  at org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38)
  at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:460)
  at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:673)
  at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:386)
  at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:196)
Caused by: java.net.ConnectException: Connection refused
  at java.net.PlainSocketImpl.socketConnect(Native Method)
  at java.net.PlainSocketImpl.doConnect(PlainSocketImpl.java:333)
  at java.net.PlainSocketImpl.connectToAddress(PlainSocketImpl.java:195)
  at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:182)
  at java.net.Socket.connect(Socket.java:520)
  at sun.net.NetworkClient.doConnect(NetworkClient.java:152)
  at sun.net.www.http.HttpClient.openServer(HttpClient.java:388)
  at sun.net.www.http.HttpClient.openServer(HttpClient.java:523)
  at sun.net.www.http.HttpClient.<init>(HttpClient.java:231)
  at sun.net.www.http.HttpClient.New(HttpClient.java:304)
  at sun.net.www.http.HttpClient.New(HttpClient.java:321)
  at sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(HttpURLConnection.java:828)
  at sun.net.www.protocol.http.HttpURLConnection.plainConnect(HttpURLConnection.java:780)
  at sun.net.www.protocol.http.HttpURLConnection.connect(HttpURLConnection.java:705)
  at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:949)
  at org.geotools.data.wfs.protocol.http.SimpleHttpProtocol$SimpleHttpResponse.getResponseStream(SimpleHttpProtocol.java:65)
  at org.geotools.data.wfs.WFSDataStoreFactory.loadCapabilities(WFSDataStoreFactory.java:684)
  at org.geotools.data.wfs.WFSDataStoreFactory.createDataStore(WFSDataStoreFactory.java:347)
  at org.geoserver.wms.kvp.GetMapKvpRequestReader.connectRemoteWFS(GetMapKvpRequestReader.java:1121)
  ... 43 more
     [ http://jira.codehaus.org/browse/GEOS-3012?page=com.atlassian.jira.plugin.system.issuetabpanels:all-tabpanel ]
Ben Caradoc-Davies reopened GEOS-3012:
Reopened for review.
                Key: GEOS-3012
            Project: GeoServer
         Issue Type: Bug
         Components: WMS
           Priority: Blocker
        Attachments: wms-online-test.patch
Failed tests:
  ... 43 more
Good morning Andrea. Recognise this one?
Probably the easiest way to protect our sanity is to fix services on sigma, bringing it back up, and then keep this bug open but with reduced priority.
                Key: GEOS-3012
            Project: GeoServer
         Issue Type: Bug
         Components: WMS
           Priority: Blocker
            Fix For: 2.0-beta1
Failed tests:
  ... 43 more
