[Geoserver-devel] [jira] Created: (GEOS-3015) GML3OutputFormat complex feature changes break WFSV
                 Key: GEOS-3015
                 URL: http://jira.codehaus.org/browse/GEOS-3015
             Project: GeoServer
          Issue Type: Bug
          Components: Versioning, WFS
            Reporter: Andrea Aime
            Assignee: Justin Deoliveira
             Fix For: 2.0-beta1
The changes made to get full type information from catalog required by the application schema support introduced the assumption GML3OutputFormat can only be used by GetFeature requests.
This is not the case with WFSV, where the same output format is used for GetLog output as well, via a subclass (GetLogGML3OutputFormat).
Solutions:
- make the GML3OutputFormat code fall back on the old approach in case the request is not a GetFeature
- move the above code in its own overridable method, and GetLogGML3OutputFormat will just use the old way of doing things
I'm of course open to other suggestions
