[Geoserver-devel] [jira] Created: (GEOS-3038) DataAccessIntegrationWfsTest in App-schema module
                 Key: GEOS-3038
                 URL: http://jira.codehaus.org/browse/GEOS-3038
             Project: GeoServer
          Issue Type: Test
          Components: Application schema
    Affects Versions: 2.0.x
            Reporter: Rini Angreani
            Assignee: Rini Angreani
            Priority: Minor
             Fix For: 2.0.x
This is to test the encoding for DataAccessIntegrationTest in Geotools app-schema module.
The idea is having a non-app-schema data access with complex features of a certain XML form, as an input to an app-schema data access which will transform the output in another XML form. This is already OK'ed by Ben.
