format_options parameter appears to be static (can be clobbered across requests)
Key: GEOS-3045
URL: http://jira.codehaus.org/browse/GEOS-3045
Project: GeoServer
Issue Type: Bug
Components: Global
Affects Versions: 1.7.3
Environment: GeoServer 1.7.3 (war edition); Tomcat 5.5.27; Java 1.5.0; WinXP
Reporter: Mark Leslie
Assignee: Andrea Aime
I've written a custom output format that uses the format_options parameter in the url to define attributes to aggregate features on: eg. format_options:aggregates=theme_id
The values passed into format_options persist between requests, ie. if aggregates isn't set again the last value will be used. Setting format_options only overwrite the options set, ie. setting format_options:colour=fish will set colour equal to fish, but will not change the value of aggregates.
This also causes problems in concurrent requests, as the values can be clobbered before being processed.
