[Geoserver-devel] [jira] Created: (GEOS-3055) Freemarker template - *.ftl file is destroyed when applying/saving configuration
                 Key: GEOS-3055
                 URL: http://jira.codehaus.org/browse/GEOS-3055
             Project: GeoServer
          Issue Type: Bug
    Affects Versions: 1.7.4
         Environment: Ubuntu 8.04 (2.6.24-19-server), Apache 2.2, Apache Tomcat Version 6.0.16, Java SUN 1.6.0_06-b02
            Reporter: Milan Antonovic
            Assignee: Andrea Aime
Every time geoserver is restarted or after applying some modification and then saving,
the *.ftl files are deleted from the directory GEOSERVER_DATE_DIR/featureTypes/.
But when I put the file in the specific featuretype folders it is not deleted.
Note: in the "GEOSERVER_DATE_DIR/featureTypes/", during the operation "apply and then save", a backup file (content.ftl.bak) is created before the elimination .
