[Geoserver-devel] [jira] Created: (GEOS-3065) Can't create file based CoverageStore with relative URL, FileExistsValidator does not find my URL's
                 Key: GEOS-3065
                 URL: http://jira.codehaus.org/browse/GEOS-3065
             Project: GeoServer
          Issue Type: Bug
          Components: Wicket UI
            Reporter: Gabriel Roldán
            Assignee: Andrea Aime
             Fix For: 2.0-beta1
Hey Andrea I'm assigning this to you for your revision cause I'm not sure if it's just me doing something wrong.
The point is I don't seem able to add any file based coverage store using a relative path to the data dir cause I can't find a URL notation that satisfies FileExistsValidator
Tried the following:
- coverages/arc_sample/precip30min.asc
- file:coverages/arc_sample/precip30min.asc (this one throws the exception bellow as an error page)
- file:/coverages/arc_sample/precip30min.asc
{code}
WicketMessage: Exception 'java.lang.IllegalArgumentException: Value of variable [[path]] could not be resolved while interpolating [[Invalid path: ${path}]]' occurred during validation org.geoserver.web.wicket.FileExistsValidator on component 46:rasterStoreForm:urlPanel:border:paramValue
Root cause:
at org.apache.wicket.util.string.interpolator.VariableInterpolator.toString(VariableInterpolator.java:136)
{code}
