web2 FileExistsValidatorTest.testAbsoluteRaw() fails on Windows, breaking the build
Key: GEOS-3072
URL: http://jira.codehaus.org/browse/GEOS-3072
Project: GeoServer
Issue Type: Bug
Components: Wicket UI
Affects Versions: 2.0.x
Reporter: Ben Caradoc-Davies
Assignee: Andrea Aime
In web2, FileExistsValidatorTest.testAbsoluteRaw() fails on Windows. It passes on Linux. I suspect a path handling problem.
Workaround: comment out this test.
I will try to get a Windows-based developer to make a better report.
