[Geoserver-devel] [jira] Created: (GEOS-3094) Deleting styles with shared resources causes runtime exception
                 Key: GEOS-3094
                 URL: http://jira.codehaus.org/browse/GEOS-3094
             Project: GeoServer
          Issue Type: Bug
    Affects Versions: 2.0-beta1
         Environment: Ubuntu Jaunty
            Reporter: Tim Coulter
            Assignee: Andrea Aime
            Priority: Blocker
             Fix For: 2.0-beta2
When deleting styles from Geoserver, a runtime exception occurs if the styles share the same layer and are deleted in a specific order.
Steps to reproduce:
1) Install and run a fresh version of Geoserver.
2) After logging in, click on the Styles link in the left-hand navigation, and find the "restricted" style.
3) Delete the "restricted" style. Do this using the associated checkbox and the "Remove selected style(s)" link, making sure to select the "OK" button on the cautionary popup.
4) Now delete the "polygon" style (you may have to page through the list). Notice that upon clicking the "OK" button in the popup, you are given the exception below.
Discussion:
1) There are other styles in which this happens. It occurs by deleting:
- The "streams" style and then the "line" style;
- The "poi" style and then the "point" style; or
- The "rain" style and then the "raster" style.
2) Order matters. For instance, in the example above, if you were to delete the "polygon" style before deleting the "restricted" style, you would not see this error.
3) The styles that cause this error are "point," "line," "polygon," and "raster," all of which seem like default styles shipped with Geoserver.
Exception:
Root cause:
java.lang.IllegalArgumentException: Unable to delete style referenced by 'restricted'
at org.geoserver.catalog.impl.CatalogImpl.remove(CatalogImpl.java:1144)
at org.geoserver.security.SecureCatalogImpl.remove(SecureCatalogImpl.java:918)
at org.geoserver.catalog.CascadeDeleteVisitor.visit(CascadeDeleteVisitor.java:156)
at org.geoserver.catalog.impl.StyleInfoImpl.accept(StyleInfoImpl.java:61)
at org.geoserver.catalog.impl.ModificationProxy.invoke(ModificationProxy.java:98)
at $Proxy7.accept(Unknown Source)
at org.geoserver.web.data.SelectionRemovalLink$1.onSubmit(SelectionRemovalLink.java:56)
at org.geoserver.web.wicket.GeoServerDialog$4.onSubmit(GeoServerDialog.java:80)
at org.apache.wicket.ajax.markup.html.form.AjaxSubmitLink$1.onSubmit(AjaxSubmitLink.java:94)
at org.apache.wicket.ajax.form.AjaxFormSubmitBehavior.onEvent(AjaxFormSubmitBehavior.java:128)
at org.apache.wicket.ajax.AjaxEventBehavior.respond(AjaxEventBehavior.java:163)
at org.apache.wicket.ajax.AbstractDefaultAjaxBehavior.onRequest(AbstractDefaultAjaxBehavior.java:297)
at org.apache.wicket.request.target.component.listener.BehaviorRequestTarget.processEvents(BehaviorRequestTarget.java:104)
at org.apache.wicket.request.AbstractRequestCycleProcessor.processEvents(AbstractRequestCycleProcessor.java:91)
at org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1220)
at org.apache.wicket.RequestCycle.step(RequestCycle.java:1297)
at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1399)
at org.apache.wicket.RequestCycle.request(RequestCycle.java:529)
at org.apache.wicket.protocol.http.WicketFilter.doGet(WicketFilter.java:356)
at org.apache.wicket.protocol.http.WicketServlet.doPost(WicketServlet.java:145)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:158)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:142)
at org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:81)
at org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:217)
at org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:106)
at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:176)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:206)
at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:324)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
at org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:842)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:648)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:395)
at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
