[Geoserver-devel] [jira] Created: (GEOS-3096) Build failure in WMS transformer tests
                 Key: GEOS-3096
                 URL: http://jira.codehaus.org/browse/GEOS-3096
             Project: GeoServer
          Issue Type: Bug
          Components: WMS
    Affects Versions: 2.0.x
            Reporter: Ben Caradoc-Davies
            Assignee: Andrea Aime
            Priority: Blocker
Not showing up in GeoServer Hudson, so might be caused by a GeoTools change.
[INFO] Building Web Map Service Module
[INFO] [clean:clean]
[INFO] Deleting directory /home/buildbot/GeoServerTrunkSlave/build/geoserver-trunk/src/wms/target
[INFO] [resources:resources]
[INFO] Copying 15 resources
[INFO] skip non existing resourceDirectory /home/buildbot/GeoServerTrunkSlave/build/geoserver-trunk/src/wms/src/main/resources
[INFO] [compiler:compile]
[INFO] Compiling 142 source files to /home/buildbot/GeoServerTrunkSlave/build/geoserver-trunk/src/wms/target/classes
[INFO] [resources:testResources]
[INFO] Copying 27 resources
[INFO] [compiler:testCompile]
[INFO] Compiling 44 source files to /home/buildbot/GeoServerTrunkSlave/build/geoserver-trunk/src/wms/target/test-classes
[INFO] [surefire:test]
[INFO] Surefire report directory: /home/buildbot/GeoServerTrunkSlave/build/geoserver-trunk/src/wms/target/surefire-reports
T E S T S
Running org.vfny.geoserver.wms.responses.map.kml.KMLTransformerTest
Tests run: 10, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 2.58 sec <<< FAILURE!
Running org.vfny.geoserver.wms.responses.map.georss.RSSGeoRSSTransformerTest
<rss xmlns:atom="http://www.w3.org/2005/Atom&quot; xmlns:georss="http://www.georss.org/georss&quot; version="2.0">
  <channel>
    <title/>
    <description>Feed auto-generated by GeoServer</description>
    <link><![CDATA[http://localhost:80/geoserver/wms?service=wms&srs=EPSG%3A4326&width=0&styles=BasicPolygons&height=0&transparent=false&bbox=-180.0%2C90.0%2C-90.0%2C180.0&request=GetMap&layers=cite%3ABasicPolygons&format=&version=1.1.1]]></link>
    <atom:link href="http://localhost:80/geoserver/wms?service=wms&amp;srs=EPSG%3A4326&amp;width=0&amp;styles=BasicPolygons&amp;height=0&amp;transparent=false&amp;bbox=-180.0%2C90.0%2C-90.0%2C180.0&amp;request=GetMap&amp;layers=cite%3ABasicPolygons&amp;format=&amp;version=1.1.1&quot; rel="self"/>
    <item>
      <title>BasicPolygons.1107531493630</title>
      <link><![CDATA[http://localhost:80/geoserver/wms/reflect?format=application/atom+xml&layers=cite:BasicPolygons&featureid=BasicPolygons.1107531493630]]></link>
      <guid><![CDATA[http://localhost:80/geoserver/wms/reflect?format=application/atom+xml&layers=cite:BasicPolygons&featureid=BasicPolygons.1107531493630]]></guid>
      <description><![CDATA[<h4>BasicPolygons</h4>
<ul class="textattributes">
</ul>
]]></description>
      <georss:polygon>0.0 -1.0 1.0 0.0 0.0 1.0 -1.0 0.0 0.0 -1.0</georss:polygon>
    </item>
  </channel>
</rss>
27 May 09:02:48 ERROR [geoserver.georss] - Unable to encode map layer: FeatureCollectionMapLayer[ UNNAMED, VISIBLE, UNSELECTED, style=StyleImpl[ name=Default], data=org.vfny.geoserver.global.GeoServerFeatureLocking@anonymised.com876...]
org.geotools.referencing.operation.projection.ProjectionException: The transform result may be 9,926,771.873 meters away from the expected position. Are you sure that the input coordinates are inside this map projection area of validity? The point is located 182°10.4'E away from the central meridian and 0°00.0'N away from the latitude of origin. The projection is "Transverse_Mercator".
  at org.geotools.referencing.operation.projection.MapProjection.checkReciprocal(MapProjection.java:630)
  at org.geotools.referencing.operation.projection.MapProjection.transform(MapProjection.java:821)
  at org.geotools.referencing.operation.projection.MapProjection.transform(MapProjection.java:855)
  at org.geotools.referencing.operation.transform.AbstractMathTransform.transform(AbstractMathTransform.java:235)
  at org.geotools.referencing.CRS.transform(CRS.java:1137)
  at org.geotools.referencing.CRS.transform(CRS.java:1203)
  at org.geotools.geometry.jts.ReferencedEnvelope.transform(ReferencedEnvelope.java:557)
  at org.geotools.geometry.jts.ReferencedEnvelope.transform(ReferencedEnvelope.java:512)
  at org.vfny.geoserver.wms.responses.map.georss.GeoRSSTransformerBase$GeoRSSTranslatorSupport.loadFeatureCollections(GeoRSSTransformerBase.java:243)
  at org.vfny.geoserver.wms.responses.map.georss.RSSGeoRSSTransformer$RSSGeoRSSTranslator.encodeItems(RSSGeoRSSTransformer.java:78)
  at org.vfny.geoserver.wms.responses.map.georss.RSSGeoRSSTransformer$RSSGeoRSSTranslator.encode(RSSGeoRSSTransformer.java:68)
  at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:714)
  at org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:484)
  at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:296)
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:129)
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:108)
  at org.vfny.geoserver.wms.responses.map.georss.RSSGeoRSSTransformerTest.getRSSResponse(RSSGeoRSSTransformerTest.java:182)
  at org.vfny.geoserver.wms.responses.map.georss.RSSGeoRSSTransformerTest.testReproject(RSSGeoRSSTransformerTest.java:151)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:131)
  at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
  at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
  at junit.extensions.TestSetup.run(TestSetup.java:25)
  at sun.reflect.GeneratedMethodAccessor118.invoke(Unknown Source)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
Tests run: 6, Failures: 4, Errors: 0, Skipped: 0, Time elapsed: 0.489 sec <<< FAILURE!
Running org.vfny.geoserver.wms.responses.map.georss.AtomGeoRSSTransformerTest
Tests run: 4, Failures: 2, Errors: 0, Skipped: 0, Time elapsed: 0.191 sec <<< FAILURE!
Failed tests:
  testRasterPlacemark(org.vfny.geoserver.wms.responses.map.kml.KMLTransformerTest)
  testFilter(org.vfny.geoserver.wms.responses.map.georss.RSSGeoRSSTransformerTest)
  testLatLongInternal(org.vfny.geoserver.wms.responses.map.georss.RSSGeoRSSTransformerTest)
  testSimpleInternal(org.vfny.geoserver.wms.responses.map.georss.RSSGeoRSSTransformerTest)
  testReproject(org.vfny.geoserver.wms.responses.map.georss.RSSGeoRSSTransformerTest)
  testLatLongInternal(org.vfny.geoserver.wms.responses.map.georss.AtomGeoRSSTransformerTest)
  testSimpleInternal(org.vfny.geoserver.wms.responses.map.georss.AtomGeoRSSTransformerTest)
Tests run: 156, Failures: 7, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
