[Geoserver-devel] [jira] Created: (GEOS-3100) port DataAccess New/Edit page to use proper composite wicket model instead of a MapModel for all properties
                 Key: GEOS-3100
                 URL: http://jira.codehaus.org/browse/GEOS-3100
             Project: GeoServer
          Issue Type: Task
          Components: Wicket UI
    Affects Versions: 2.0-beta1
            Reporter: Gabriel Roldán
            Assignee: Gabriel Roldán
            Priority: Critical
             Fix For: 2.0-beta2
DataAccess New/Edit page uses a weird approach for the page model: it builds a Map with both the StoreInfo and DataAccess parameters properties and uses a MapModel. This is clearly wrong as it requires passing the properties back and forward from the map to the actual data objects
