Expose generalization distance control in PDF and SVG output
Key: GEOS-3102
URL: http://jira.codehaus.org/browse/GEOS-3102
Project: GeoServer
Issue Type: New Feature
Components: WMS
Affects Versions: 1.7.4
Reporter: Andrea Aime
Assignee: Andrea Aime
Fix For: 1.7.x, 2.0.x
Both PDF and SVG outputs are vector in nature, so they are not bound to a specific resolution.
The renderer used in both still generalizes the geometries following the resolution that comes from the width/height parameters as if the output was vector.
We could just drop the generalization, or allow the user to control it more explicitly. I'm unsure on how to proceed in particular because the size of the output with big datasets can skyrocket without the on the fly generalization the renderer is applying today.
