[Geoserver-devel] [jira] Created: (GEOS-3106) Disabling a Store does not disable it's layers, and they can still be accessed
                 Key: GEOS-3106
                 URL: http://jira.codehaus.org/browse/GEOS-3106
             Project: GeoServer
          Issue Type: Bug
          Components: Wicket UI
    Affects Versions: 2.0-beta1
            Reporter: Gabriel Roldán
            Assignee: Gabriel Roldán
             Fix For: 2.0-beta2
What the correct behaviour would be when disabling a Store?
Currently that doesn't imply disabling it's layers, so disabling a store and going to the layer preview page still shows up the layers from the disabled store, and they can be viewed.
Two options:
- disabling a store disables it's layers
- or disabling a sore does not disable it's layers but we add logic to avoid serving layers from disabled stores.
For instance, both LayerInfo and ResourceInfo have a isEnabled property, but I don't see where in the code a ResourceInfo is being set to enabled (not in {{org.geoserver.web.data.resource}}).
I think option 2 is the one I like more provided that we change the isEnabled property semantics to be:
- ResourceInfo.isEnabled = getStore().isEnabled && this.enabled
- LayerInfo.isEnabled = getResource().isEnabled && this.enabled
so it gets well encapsulated. What do you think?
