[Geoserver-devel] [jira] Created: (GEOS-3111) SDE raster image has a purple cast
                 Key: GEOS-3111
                 URL: http://jira.codehaus.org/browse/GEOS-3111
             Project: GeoServer
          Issue Type: Bug
          Components: ArcSDE
    Affects Versions: 1.7.4
         Environment: SDE 9.2 SP 5
Oracle 10.2.0.2
GeoServer running in Tomcat 5.5.9
            Reporter: Aleda Freeman
            Assignee: Andrea Aime
            Priority: Minor
         Attachments: 1.6.5_2005_orthos.png, nightly_6_2_09_2005_orthos.pdf, nightly_6_2_09_2005_orthos.png
In 1.6.5 the image looks normal but in 1.7.x (all the ones I've tried, currently nightly downloaded 6/2/2009) it's purplish (at all zoom levels).
The same SDE is referenced for both and the same config info.xml is used for both GeoServer versions.
The layer is massgis:GISDATA.IMG_COQ2005
Interestingly, the PDF has the right coloring, but the lower left is cut off.
