Update versions/shift locations of iText & commons-httpclient dependencies
Key: GEOS-3114
URL: http://jira.codehaus.org/browse/GEOS-3114
Project: GeoServer
Issue Type: Improvement
Components: Configuration
Reporter: agerber
Assignee: Justin Deoliveira
Priority: Minor
Attachments: poms-patch.tar.gz
I <agerber> am working on integrating MapFish's PDF printing capabilities. This requires updating the version of iText in the main POM, moving the commons-httpclient dependency to the main POM, and adding the "printing" project to the community POM. Making these updates does not cause any test failures when executing "mvn clean install".
Specifically, files attached do:
</pom.xml>
-update iText to use version 2.1.5
-adds a dependency on commons-httpclient 3.1 (Apache Commons HTTP client), moved from main
</main/pom.xml>
-removes the dependency on commons-httpclient, moved to root POM
</community/pom.xml>
-adds the printing module
