[Geoserver-devel] [jira] Created: (GEOS-3115) schemaLocation in app-schema GetFeature response contains non-namespace-qualified DescribeFeatureType
                 Key: GEOS-3115
                 URL: http://jira.codehaus.org/browse/GEOS-3115
             Project: GeoServer
          Issue Type: Bug
          Components: WFS
            Reporter: Ben Caradoc-Davies
            Assignee: Rini Angreani
             Fix For: 2.0.x
Because the DescribeFeatureType response given in the schemaLocation for an app-schema DataAccess feature type is not namespace-qualified, the URL is invalid, and the response cannot be validated. If the type name is prefixed with the namespace prefix, the URL becomes valid. Even better, would it be possible to refer directly to the app-schema schemaUri? This would remove the need for a DescribeFeatureType call. (We still need to support the latter to be WFS compliant.)
Example showing missing prefix:
{code}
<wfs:FeatureCollection numberOfFeatures="2"
  timeStamp="2009-06-03T14:06:45.379+08:00"
  xsi:schemaLocation="urn:cgi:xmlns:CGI:GeoSciML:2.0 http://localhost:8080/geoserver/wfs?service=WFS&amp;version=1.1.0&amp;request=DescribeFeatureType&amp;typeName=GeologicUnit http://www.opengis.net/wfs http://localhost:8080/geoserver/schemas/wfs/1.1.0/wfs.xsd&quot;
  xmlns:ogc="http://www.opengis.net/ogc&quot; xmlns:gml="http://www.opengis.net/gml&quot;
  xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xmlns:gsml="urn:cgi:xmlns:CGI:GeoSciML:2.0"
  xmlns:xlink="http://www.w3.org/1999/xlink&quot; xmlns:ows="http://www.opengis.net/ows&quot;
  xmlns:wfs="http://www.opengis.net/wfs&quot;&gt;
  <gml:featureMembers>
    <gsml:GeologicUnit gml:id="gu.1">
      <gml:description>Cheese</gml:description>
      <gml:name>Yaugher Volcanic Group</gml:name>
    </gsml:GeologicUnit>
    <gsml:GeologicUnit gml:id="gu.2">
      <gml:description>Olivine basalt</gml:description>
      <gml:name>New Group</gml:name>
  </gml:featureMembers>
</wfs:FeatureCollection>
{code}
Should have a DescribeFeatureType with typeName=gsml:GeologicUnit, or even better, an external URL such as http://www.geosciml.org/geosciml/2.0/xsd/geosciml.xsd
