xsi:nil="true" is ignored in insert request though the schema shows nillable="true"
Key: GEOS-3126
URL: http://jira.codehaus.org/browse/GEOS-3126
Project: GeoServer
Issue Type: Bug
Components: ArcSDE
Affects Versions: 1.7.4
Environment: ArecSDE 9.2 database (Oracle 10g)
Reporter: Gerhard Sommer
Assignee: Andrea Aime
Priority: Minor
I try to insert a feature type with the following request:
<Transaction version="1.0.0" service="WFS" lockAction="ALL" xmlns:vienna="http://www.wien.gv.at/ows/wfs/gml" xmlns="http://www.opengis.net/wfs" xmlns:gml="http://www.opengis.net/gml" xmlns:ogc="http://www.opengis.net/ogc" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<Insert>
<vienna:TEST_TEILFL_F fid="newvienna:TEST_TEILFL_F.9223372036854775807">
<vienna:AEND_DATUM xsi:nil="true"></vienna:AEND_DATUM>
</vienna:TEST_TEILFL_F>
</Insert>
</Transaction>
and get the following error, though AEND_DATUM (a DateTime field) is nillable according to the schema and NULL is allowed for the field in the database:
<ServiceExceptionReport
version="1.2.0"
xmlns="http://www.opengis.net/ogc"
xsi:schemaLocation="http://www.opengis.net/ogc http://schemas.opengis.net/wfs/1.0.0/OGC-exception.xsd">
<ServiceException>
java.lang.RuntimeException: Parsing failed for AEND_DATUM: java.lang.IllegalArgumentException: Failed to parse dateTime at:
Details:
org.geoserver.platform.ServiceException: java.lang.RuntimeException: Parsing failed for AEND_DATUM: java.lang.IllegalArgumentException: Failed to parse dateTime at:
at org.geoserver.ows.Dispatcher.exception(Dispatcher.java:1272)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:224)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:647)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:269)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:188)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:215)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:178)
at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:163)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:47)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:172)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:117)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:108)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:174)
at org.apache.coyote.http11.Http11AprProcessor.process(Http11AprProcessor.java:835)
at org.apache.coyote.http11.Http11AprProtocol$Http11ConnectionHandler.process(Http11AprProtocol.java:640)
at org.apache.tomcat.util.net.AprEndpoint$Worker.run(AprEndpoint.java:1286)
at java.lang.Thread.run(Thread.java:619)
Caused by: java.lang.RuntimeException: Parsing failed for AEND_DATUM: java.lang.IllegalArgumentException: Failed to parse dateTime at:
at org.geotools.xml.impl.ParseExecutor.visit(ParseExecutor.java:158)
at org.geotools.xml.impl.BindingWalker$BindingExecutionChain.execute(BindingWalker.java:208)
at org.geotools.xml.impl.BindingWalker.walk(BindingWalker.java:174)
at org.geotools.xml.impl.ElementHandlerImpl.endElement(ElementHandlerImpl.java:222)
at org.geotools.xml.impl.ParserHandler.endElement(ParserHandler.java:585)
at org.apache.xerces.parsers.AbstractSAXParser.endElement(Unknown Source)
at org.apache.xerces.impl.XMLNSDocumentScannerImpl.scanEndElement(Unknown Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl$FragmentContentDispatcher.dispatch(Unknown Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
at org.apache.xerces.parsers.AbstractSAXParser.parse(Unknown Source)
at org.geotools.xml.Parser.parse(Parser.java:180)
at org.geotools.xml.Parser.parse(Parser.java:158)
at org.geoserver.wfs.xml.v1_0_0.WfsXmlReader.read(WfsXmlReader.java:60)
at org.geoserver.ows.Dispatcher.parseRequestXML(Dispatcher.java:1148)
at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:438)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:209)
... 48 more
Caused by: java.lang.IllegalArgumentException: Failed to parse dateTime at:
at org.geotools.xml.impl.DatatypeConverterImpl.parseDateTime(DatatypeConverterImpl.java:111)
at org.geotools.xs.bindings.XSDateTimeBinding.parse(XSDateTimeBinding.java:99)
at org.geotools.xml.impl.ParseExecutor.visit(ParseExecutor.java:147)
... 66 more
</ServiceException></ServiceExceptionReport>
If I just omit AEND_DATUM, which is also OK because of minOccurs=0, it works.
