DescribeFeatureType for complex types give wrong type names
Key: GEOS-3143
URL: http://jira.codehaus.org/browse/GEOS-3143
Project: GeoServer
Issue Type: Improvement
Components: WFS
Affects Versions: 2.0.x
Reporter: Rini Angreani
Assignee: Rini Angreani
Fix For: 2.0.x
DescribeFeatureType builds a complex schema content as an output, but the contents are inaccurate.
Eg.
<xsd:schema elementFormDefault="qualified"
targetNamespace="http://www.cgi-iugs.org/xml/GeoSciML/2"
xmlns:Q1="http://www.opengis.net/sampling/1.0"
xmlns:gml="http://www.opengis.net/gml"
xmlns:gsml="http://www.cgi-iugs.org/xml/GeoSciML/2" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<xsd:import namespace="http://www.opengis.net/gml" schemaLocation="http://localhost:80/geoserver/schemas/gml/3.1.1/base/gml.xsd"/>
<xsd:complexType name="MappedFeatureTypeType">
<xsd:complexContent>
<xsd:extension base="gml:AbstractFeatureType">
<xsd:sequence>
<xsd:element maxOccurs="2147483647" minOccurs="0"
name="metaDataProperty" nillable="false" type="gml:MetaDataPropertyType"/>
<xsd:element maxOccurs="1" minOccurs="0"
name="description" nillable="false" type="gml:StringOrRefType"/>
name="name" nillable="false" type="gml:CodeType"/>
name="boundedBy" nillable="false" type="gml:BoundingShapeType"/>
name="location" nillable="false" type="gml:LocationPropertyType"/>
<xsd:element maxOccurs="1" minOccurs="1"
name="positionalAccuracy" nillable="false" type="gsml:CGI_ValuePropertyType"/>
<xsd:element maxOccurs="2147483647" minOccurs="1"
name="observationMethod" nillable="false" type="gsml:CGI_TermValuePropertyType"/>
name="samplingFrame" nillable="false" type="Q1:SpatiallyExtensiveSamplingFeaturePropertyType"/>
name="shape" nillable="false" type="gml:GeometryPropertyType"/>
name="specification" nillable="false" type="gsml:GeologicFeaturePropertyType"/>
name="metadata" nillable="false" type="gsml:MetadataPropertyType"/>
</xsd:sequence>
</xsd:extension>
</xsd:complexContent>
</xsd:complexType>
<xsd:element name="MappedFeature" substitutionGroup="gml:_Feature" type="gsml:MappedFeatureTypeType"/>
</xsd:schema>
whereas the type name is "MappedFeatureType", not "MappedFeatureTypeType".
Ben's idea is to import schema locations provided in the configuration file instead.
eg.
Config file:
<targetTypes>
<FeatureType>
<schemaUri>http://schemas.opengis.net/GeoSciML/geosciml.xsd </schemaUri>
</FeatureType>
</targetTypes>
The new DescribeFeatureType output:
<xsd:import namespace="http://www.cgi-iugs.org/xml/GeoSciML/2" schemaLocation="http://schemas.opengis.net/GeoSciML/geosciml.xsd"/>
</xsd:schema>
