[Geoserver-devel] [jira] Created: (GEOS-3146) The list of styles can't be sorted, it's a ModificationProxy$list
                 Key: GEOS-3146
                 URL: http://jira.codehaus.org/browse/GEOS-3146
             Project: GeoServer
          Issue Type: Bug
          Components: Wicket UI
    Affects Versions: 2.0-beta1
            Reporter: Gabriel Roldán
            Assignee: Justin Deoliveira
             Fix For: 2.0-beta2
try to sort the list of styles, GeoServerDataProvider.iterator() will complain at line 145 {{Collections.sort(items, comparator);}} because {{items}} is a {{ModificationProxy$list}} and does not support the {{List.set}} method:
{panel}
aused by: java.lang.UnsupportedOperationException
  at java.util.AbstractList.set(AbstractList.java:115)
  at java.util.AbstractList$ListItr.set(AbstractList.java:412)
  at java.util.Collections.sort(Collections.java:163)
  at org.geoserver.web.wicket.GeoServerDataProvider.iterator(GeoServerDataProvider.java:145)
  at org.apache.wicket.markup.repeater.data.DataViewBase$ModelIterator.<init>(DataViewBase.java:103)
{panel}
The easiest would be to change {{StyleProvider.getItems()}} to return {{new ArrayList(getCatalog().getStyles())}} instead of plain {{getCatalog().getStyles()}}, but am not completely sure that'd be the way to go.
Justin?
