[Geoserver-devel] [jira] Created: (GEOS-3149) Keep DataAccess namespace param in sync with the workspace's datastore until the resource/publish split is complete
                 Key: GEOS-3149
                 URL: http://jira.codehaus.org/browse/GEOS-3149
             Project: GeoServer
          Issue Type: Task
          Components: Wicket UI
    Affects Versions: 2.0-beta1
            Reporter: Gabriel Roldán
            Assignee: Gabriel Roldán
             Fix For: 2.0-beta2
We're allowing to change the workspace AND the dataaccess namespace parameter independently, but it leads to issues since the resource/publish split is not really finished yet. So since we need to rely on the assumption of namespace being the same than the one linked to the workspace, do not allow to edit the datastore namespace, make it read only and auto update it whenever the datastore's workspace is changed. This can be easily reverted when the split is done.
     [ http://jira.codehaus.org/browse/GEOS-3149?page=com.atlassian.jira.plugin.system.issuetabpanels:all-tabpanel ]
Gabriel Roldán reopened GEOS-3149:
                Key: GEOS-3149
            Project: GeoServer
         Issue Type: Task
           Priority: Critical
            Fix For: 2.0-beta2
