ArcSDE DataStore level versioning support
Key: GEOS-3152
URL: http://jira.codehaus.org/browse/GEOS-3152
Project: GeoServer
Issue Type: New Feature
Components: ArcSDE, Configuration
Reporter: Gabriel Roldán
Assignee: Gabriel Roldán
Fix For: 1.7.6
Ability to set, through the GeoServer admin UI, an optional DataStore parameter indicating which ArcSDE version the DataStore should work upon when fetching/editing Feature data.
This means a given ArcSDE DataStore instance will be able to work upon a single, configurable ArcSDE version at any time.
Editing more than one version at the same time, hence, can be achieved by setting up a separate DataStore instance pointing to another Version.
The default behaviour, when a specific version is not specified is to work upon the database DEFAULT version.
