[Geoserver-devel] [jira] Created: (GEOS-3153) Allow serving non-spatial ArcSDE registered tables
                 Key: GEOS-3153
                 URL: http://jira.codehaus.org/browse/GEOS-3153
             Project: GeoServer
          Issue Type: New Feature
          Components: ArcSDE, Configuration
         Environment: GeoServer 1.7.x, ArcSDE 9.2/9.3/ Oracle 10g/MS SQLServer 2000
            Reporter: Gabriel Roldán
            Assignee: Gabriel Roldán
             Fix For: 1.7.6
Ability to set, through the GeoServer admin UI, an optional DataStore parameter indicating that non spatial feature classes shall be exposed through the DataStore.
Which non spatial feature classes to expose as FeatureTypes are restricted to the non spatial tables registered in the ArcSDE database (For example, using the command sde_table -o register) and that have an SDE or USER managed primary key. Otherwise it is impossible to assign a reliable feature identifier to the Feature instances.
