[Geoserver-devel] [jira] Created: (GEOS-3156) Render Bug 1.7.5
Render Bug 1.7.5
                 Key: GEOS-3156
                 URL: http://jira.codehaus.org/browse/GEOS-3156
             Project: GeoServer
          Issue Type: Bug
          Components: WMS
    Affects Versions: 1.7.5
         Environment: Windows/Linux GeoServer 1.7.5 Java 1.6 U14
            Reporter: Tobias Warneke
            Assignee: Andrea Aime
Using GeoServer 1.7.5 a problem rendering lines with a stroke-linecap exists. There are artifacts rendered at the line - border. At first I thought there is no antialiasing done but as larger my stroke-width was as larger the artifacts got. stroke-linejoin I did not test.
GeoServer 1.7.4 works well.
To reproduce this problem just modify the style default_line.sld using the stroke configuration below and open the tiger-roads layer.
<Stroke>
<CssParameter name="stroke">#0000FF</CssParameter>
<CssParameter name="stroke-linecap"><ogc:Literal>round</ogc:Literal></CssParameter>
<CssParameter name="stroke-width">100</CssParameter>
</Stroke>
hope I have no typo in there :).
regards
tobias
