Can't edit the test suite configuration
Key: GEOS-316
URL: http://jira.codehaus.org/browse/GEOS-316
Project: GeoServer
Type: Bug
Components: Validation
Versions: 1.3.0-beta
Environment: Windows XP ; JDK 1.4
Reporter: Pierrick Brihaye
Assigned to: Chris Holmes
http://localhost:8080/geoserver/config/validation/suite.do
Select : IntegrityCheck
Then : Edit
I get :
10:48:57.419 WARN!! Exception for /geoserver/config/validation/testSuiteSelect.d
o
javax.servlet.ServletException: Action must be a MessageResource key value of ei
ther 'label.edit' or 'label.delete'
at org.vfny.geoserver.action.validation.ValidationTestSuiteSelectAction.
execute(ValidationTestSuiteSelectAction.java:75)
at org.vfny.geoserver.action.ConfigAction.execute(ConfigAction.java:98)
at org.apache.struts.action.RequestProcessor.processActionPerform(Reques
tProcessor.java:484)
If you want more information on JIRA, or have a bug to report see:
