Simplify GeoserverTablePanel setup
Key: GEOS-3171
URL: http://jira.codehaus.org/browse/GEOS-3171
Project: GeoServer
Issue Type: Improvement
Components: Wicket UI
Reporter: Andrea Aime
Assignee: Andrea Aime
Fix For: 2.0-beta2
At the moment there are two issues that produce quite some boilerplate:
- the table panel pretends a component to be generated for each property. Have a simple label be generated when the subclass does not need/still does not want to generate a custom component
- custom properties need to be coded in each and single method. Provide an abstract property that allows to just code the property value extraction instead
