startup.bat doesn't like pathnames with spaces
Key: GEOS-3178
URL: http://jira.codehaus.org/browse/GEOS-3178
Project: GeoServer
Issue Type: Bug
Components: Global
Affects Versions: 2.0-beta1, 1.7.5
Environment: Windows (binary)
Reporter: Mike Pumphrey
Assignee: Mike Pumphrey
Fix For: 1.7.6, 2.0-beta2
When using the "OS independent binary" build of GeoServer in Windows, startup is achieved through the startup.bat. This file looks to environment variables for its path locations, however it does not seem to handle spaces in paths, bombing out when it encounters a path with spaces.
I think this file should probably be rearchitected, or at least synched up with startup.sh (which I'm guessing probably has been given more love recently).
