Shapefile download - problem if null geometries
Key: GEOS-3180
URL: http://jira.codehaus.org/browse/GEOS-3180
Project: GeoServer
Issue Type: Bug
Affects Versions: 1.7.5
Environment: SDE 9.2 SP 5
Oracle 10.2.0.2
Reporter: Aleda Freeman
Assignee: Andrea Aime
Priority: Minor
Gabriel Roldan says:
Andrea means the GeoTools ArcSDE plugin may have started to do things the right way, which it actually was. I can provide the exact commit date and chengelog when I get internet access back, they're calling for boarding right now
but the thing is that before whenever a null geometry came from the database the gt arcsde plugin was bulding an empty geometry, and now features are built with an empty geometry only if the attribute is not nillable.
Request:
It's using http://maps.massgis.state.ma.us/geoserver/wfs?request=GetFeature&service=wfs&version=1.0.0&typename=massgis:GISDATA.TOWNS_POLY&outputformat=SHAPE-ZIP
In GeoServer log:
2009-06-19 12:40:37,912 INFO [geoserver.wfs] -
Request: getFeature
handle = null
service = wfs
version = 1.0.0
baseUrl = http://maps.massgis.state.ma.us:80/geoserver/
providedVersion = 1.0.0
query = [net.opengis.wfs.impl.QueryTypeImpl@anonymised.com (group: null, propertyName: null, function: null, filter: null, sortBy: null, featureVersion: null, handle: null, srsName: null, typeName: [{http://massgis.state.ma.us/featuretype\}GISDATA.TOWNS_POLY])]
maxFeatures = null
outputFormat = SHAPE-ZIP
resultType = results
traverseXlinkDepth = null
traverseXlinkExpiry = null
formatOptions = {}
2009-06-19 12:40:37,912 WARN [data.shapefile] - FieldName FIPS_COUNTY is longer than 10 characters, truncating to FIPS_COUNT
2009-06-19 12:40:37,952 ERROR [data.shapefile] - The following locker still has a lock� read on file:/home/afreeman/apps/apache-tomcat-5.5.26/temp/wfsshptemp0.6462004266500585/GISDATA.TOWNS_POLY.shp by org.geotools.data.shapefile.shp.ShapefileReader
it was created with the following stack trace
org.geotools.data.shapefile.ShpFilesLocker$Trace: Locking file:/home/afreeman/apps/apache-tomcat-5.5.26/temp/wfsshptemp0.6462004266500585/GISDATA.TOWNS_POLY.shp for read by org.geotools.data.shapefile.shp.ShapefileReader in thread TP-Processor1
at org.geotools.data.shapefile.ShpFilesLocker.setTraceException(ShpFilesLocker.java:54)
at org.geotools.data.shapefile.ShpFilesLocker.<init>(ShpFilesLocker.java:33)
at org.geotools.data.shapefile.ShpFiles.acquireRead(ShpFiles.java:365)
at org.geotools.data.shapefile.ShpFiles.getReadChannel(ShpFiles.java:813)
at org.geotools.data.shapefile.shp.ShapefileReader.<init>(ShapefileReader.java:157)
at org.geotools.data.shapefile.ShapefileDataStore.openShapeReader(ShapefileDataStore.java:425)
at org.geotools.data.shapefile.ShapefileDataStore.getAttributesReader(ShapefileDataStore.java:411)
at org.geotools.data.shapefile.ShapefileDataStore.createFeatureWriter(ShapefileDataStore.java:572)
at org.geotools.data.AbstractDataStore.getFeatureWriter(AbstractDataStore.java:486)
at org.geotools.data.AbstractDataStore.getFeatureWriter(AbstractDataStore.java:520)
at org.geotools.data.AbstractDataStore.getFeatureWriterAppend(AbstractDataStore.java:529)
at org.geotools.data.AbstractFeatureStore.addFeatures(AbstractFeatureStore.java:254)
at org.geoserver.wfs.response.ShapeZipOutputFormat.writeCollectionToShapefile(ShapeZipOutputFormat.java:199)
at org.geoserver.wfs.response.ShapeZipOutputFormat.write(ShapeZipOutputFormat.java:157)
at org.geoserver.wfs.WFSGetFeatureOutputFormat.write(WFSGetFeatureOutputFormat.java:137)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:712)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:216)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:690)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:269)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:188)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:215)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:265)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:124)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:174)
at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:249)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:149)
at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:163)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:174)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:117)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:108)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:174)
at org.apache.jk.server.JkCoyoteHandler.invoke(JkCoyoteHandler.java:200)
at org.apache.jk.common.HandlerRequest.invoke(HandlerRequest.java:283)
at org.apache.jk.common.ChannelSocket.invoke(ChannelSocket.java:773)
at org.apache.jk.common.ChannelSocket.processConnection(ChannelSocket.java:703)
at org.apache.jk.common.ChannelSocket$SocketConnection.runIt(ChannelSocket.java:895)
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:689)
at java.lang.Thread.run(Thread.java:595)
2009-06-19 12:40:37,952 ERROR [data.shapefile] - The following locker still has a lock� read on file:/home/afreeman/apps/apache-tomcat-5.5.26/temp/wfsshptemp0.6462004266500585/GISDATA.TOWNS_POLY.dbf by org.geotools.data.shapefile.dbf.DbaseFileReader
org.geotools.data.shapefile.ShpFilesLocker$Trace: Locking file:/home/afreeman/apps/apache-tomcat-5.5.26/temp/wfsshptemp0.6462004266500585/GISDATA.TOWNS_POLY.dbf for read by org.geotools.data.shapefile.dbf.DbaseFileReader in thread TP-Processor1
at org.geotools.data.shapefile.dbf.DbaseFileReader.<init>(DbaseFileReader.java:130)
at org.geotools.data.shapefile.ShapefileDataStore.openDbfReader(ShapefileDataStore.java:450)
2009-06-19 12:40:37,952 ERROR [geoserver.ows] -
java.lang.NullPointerException
at org.geotools.data.shapefile.ShapefileFeatureWriter.write(ShapefileFeatureWriter.java:356)
at org.geotools.data.shapefile.ShapefileFeatureWriter.close(ShapefileFeatureWriter.java:221)
at org.geotools.data.InProcessLockingManager$1.close(InProcessLockingManager.java:348)
at org.geotools.data.AbstractFeatureStore.addFeatures(AbstractFeatureStore.java:276)
