[Geoserver-devel] [jira] Created: (GEOS-3183) Windows installer ignores JAVA_HOME input
                 Key: GEOS-3183
                 URL: http://jira.codehaus.org/browse/GEOS-3183
             Project: GeoServer
          Issue Type: Improvement
          Components: Windows Installer
    Affects Versions: 1.7.5
         Environment: Windows XP SP3 32-bit
            Reporter: Mike Toews
            Assignee: Andrea Aime
The Windows installer asks for a path to a Java JDK, however, this seems to be ignored.
I have a computer that previously had an older JDK (past year) with JAVA_HOME assigned to it. I re-installed a new version of JDK, but this doesn't modify JAVA_HOME. While installing GeoServer (geoserver-1.7.5-ng.exe), the default value for the JDK path was borrowed from the JAVA_HOME environment variable, but since it was wrong, I set the path in the installer to the correct path.
However, when I started the GeoServer service, it failed to start since it was reading the wrong JAVA_HOME path.
A possible solution is: if JAVA_HOME is not set or is incorrect, the installer should identify this and write the system variable using the path provided in the installer.
