[Geoserver-devel] [jira] Created: (GEOS-3186) Overriding schema.xsd in states shapefile does not seem to work for GetFeature WFS 1.1
                 Key: GEOS-3186
                 URL: http://jira.codehaus.org/browse/GEOS-3186
             Project: GeoServer
          Issue Type: Bug
    Affects Versions: 1.7.5
            Reporter: Andrea Aime
            Assignee: Justin Deoliveira
             Fix For: 1.7.6
Steps to reproduce:
1) get the WFS 1.1.0 DescribeFeatureType response and store it in a schema.xsd file inside the feature type configuration
2) remove all of the columns but the first three
3) reload
Results:
- schema.xml is generated
- the feature type config panel shows only the 3 left attributes
- DescribeFeatureType works fine for both wfs 1.0 and 1.1
- GetFeature works fine for 1.0 and only the chosen attributes are returned
- WFS 1.1 GetFeature returns
{code:xml}
<ows:ExceptionReport version="1.0.0" xsi:schemaLocation="http://www.opengis.net/ows http://localhost:8080/geoserver/schemas/ows/1.0.0/owsExceptionReport.xsd&quot;&gt;
<ows:Exception exceptionCode="NoApplicableCode">
<ows:ExceptionText>
java.lang.RuntimeException: Could not find element declaration: (http://www.openplans.org/topp, states )
</ows:ExceptionText>
</ows:Exception>
</ows:ExceptionReport>
{code}
