Allow Serializable instances in resource metadata
Key: GEOS-3190
URL: http://jira.codehaus.org/browse/GEOS-3190
Project: GeoServer
Issue Type: Bug
Components: Configuration
Affects Versions: 2.0-beta1
Reporter: David Winslow
Assignee: Justin Deoliveira
Fix For: 2.0.x
In the metadata maps associated with ResourceInfo objects in the new Catalog API, only Strings are persisted properly (using the XStream persister). As per the API, any Serializable object should be acceptable.
