Message:
A new issue has been created in JIRA.
View the issue:
http://jira.codehaus.org/secure/ViewIssue.jspa?key=GEOS-32
Here is an overview of the issue:
Key: GEOS-32
Summary: Fix wms GetCapabilities and error documents
Type: Task
Status: Open
Priority: Critical
Original Estimate: 4 hours
Time Spent: Unknown
Remaining: 4 hours
Project: GeoServer
Components:
WMS
Fix Fors:
1.1.0
Versions:
1.1beta
Assignee: Gabriel Rold?n
Reporter: Chris Holmes
Created: Wed, 17 Dec 2003 5:24 PM
Updated: Wed, 17 Dec 2003 5:24 PM
Description:
The capabilities document returned by the wms does not seem to be valid, as the results section is empty. Some of the spacing is also off. This needs to be fixed for 1.1.0 release. The errors reported are also wfs xml, they don't conform to the wms dtd, which is required as part of the spec. Both should completely validate.
JIRA INFORMATION:
If you want more information on JIRA, or have a bug to report see:
