V/D workspace confusion
Key: GEOS-3200
URL: http://jira.codehaus.org/browse/GEOS-3200
Project: GeoServer
Issue Type: Improvement
Components: Wicket UI
Affects Versions: 2.0-beta1
Reporter: alyssa wright
Assignee: Andrea Aime
Priority: Minor
Fix For: 2.1.x
Not clear that the check boxes are only used for deleting workspaces. When looking to view workspaces I would check the boxes, and then select the link. I would like to suggest having an X box instead of a check box that clearly indicates that the workspace is marked for deletion. Or perhaps, even having the delete icon besides each work space would work. I'm not sure what's the best solution. . but as it stands now, I
think the interface is confusing.
