[Geoserver-devel] [jira] Created: (GEOS-3222) WCS request returning java.io.IOException
                 Key: GEOS-3222
                 URL: http://jira.codehaus.org/browse/GEOS-3222
             Project: GeoServer
          Issue Type: Bug
          Components: WCS
         Environment: 1.7.5 - windows vista
            Reporter: Jonathan
            Assignee: Andrea Aime
This may not be a bug but fairly sure it is.
I have a file-based pyramid coverage I nabbed from http://etch.opengeo.org/bluemarble/ (bluemarble00), and I've added it to GeoServer. It serves fine over OpenLayers and KML, so now I'm trying to extract data directly using WCS.
The URL I'm using is:
http://<host>:8080/geoserver/wcs?request=GetCoverage&version=1.1.1&identifier=j2:pyramid&SERVICE=wcs&FORMAT=image/geotiff&boundingbox=-180,-90,-170,-80,urn:ogc:def:crs:EPSG::4326 <http://%3chost%3e:8080/geoserver/wcs?request=GetCoverage&version=1.1.1&identifier=j2:pyramid&SERVICE=wcs&FORMAT=image/geotiff&boundingbox=-180,-90,-170,-80,urn:ogc:def:crs:EPSG::4326>
I know there's data at those co-ords, yet it returns this error:
<ows:Exception exceptionCode="NoApplicableCode">
&#8722;
<ows:ExceptionText>
java.io.IOException: The requested coverage could not be found.
</ows:ExceptionText>
</ows:Exception>
</ows:ExceptionReport>
Which isn't the same as saying there is no data at those co-ords. That error is this (I changed to a different dataset (single GeoTiff) to test):
&#8722;
<ows:ExceptionText>
The Intersection is null. Check the requested BBOX!
</ows:Exception>
  And it can't be because it can't find the coverage itself because if I change the "identifier" to a made up one, it gives this error:
<ows:Exception exceptionCode="InvalidParameterValue" locator="identifier">
<ows:ExceptionText>Could not find coverage &apos;j2:outtsif&apos;</ows:ExceptionText>
</ows:Exception>
The question then is, what does "java.io.IOException: The requested coverage could not be found.
Note - the co-ords themselves may be in the wrong format, but then surely shouldn't it complain that no data was found?
Per Justin's suggestion in the mailing-list, I turned on verbose logging and ran the URL. 2300 lines:
2009-07-03 13:08:58,610 DEBUG [geoserver.filters] - filtering http://193.63.128.51:8080/geoserver/wcs
2009-07-03 13:08:58,624 INFO [servlet.DispatcherServlet] - FrameworkServlet 'dispatcher': initialization started
2009-07-03 13:08:58,626 INFO [support.XmlWebApplicationContext] - Refreshing org.springframework.web.context.support.XmlWebApplicationContext@anonymised.com: display name [WebApplicationContext for namespace 'dispatcher-servlet']; startup date [Fri Jul 03 13:08:58 BST 2009]; parent: org.springframework.web.context.support.XmlWebApplicationContext@anonymised.com
2009-07-03 13:08:58,628 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from ServletContext resource [/WEB-INF/dispatcher-servlet.xml]
2009-07-03 13:08:58,633 INFO [support.XmlWebApplicationContext] - Bean factory for application context [org.springframework.web.context.support.XmlWebApplicationContext@anonymised.com]: org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com
2009-07-03 13:08:58,634 INFO [support.DefaultListableBeanFactory] - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com: defining beans ; parent: org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com
2009-07-03 13:08:58,706 INFO [servlet.DispatcherServlet] - FrameworkServlet 'dispatcher': initialization completed in 81 ms
2009-07-03 13:08:58,731 INFO [referencing.factory] - Using "file:/C:/server/geoserver-1.7.5-bin/webapps/geoserver/WEB-INF/lib/main-1.7.5.jar!/org/vfny/geoserver/crs/override_epsg.properties" as EPSG factory.
2009-07-03 13:08:58,737 INFO [referencing.factory] - Connected to EPSG database "jdbc:hsqldb:file:/C:/Users/080468~1.J20/AppData/Local/Temp/Geotools/Databases/HSQL/EPSG" on "HSQL Database Engine".
2009-07-03 13:08:58,740 INFO [referencing.factory] - Using "/C:/server/geoserver-1.7.5-bin/./data_dir/user_projections/epsg.properties" as EPSG factory.
2009-07-03 13:08:58,748 WARN [referencing.factory] - Axis elements found in a wkt definition, the force longitude first axis order hint might not be respected:
PROJCS["WGS84 / Simple Mercator", GEOGCS["WGS 84", DATUM["WGS_1984", SPHEROID["WGS_1984", 6378137.0, 298.257223563]], PRIMEM["Greenwich", 0.0], UNIT["degree", 0.017453292519943295]], PROJECTION["Mercator_1SP_Google"], PARAMETER["latitude_of_origin", 0.0], PARAMETER["central_meridian", 0.0], PARAMETER["scale_factor", 1.0], PARAMETER["false_easting", 0.0], PARAMETER["false_northing", 0.0], UNIT["m", 1.0], AXIS["x", EAST], AXIS["y", NORTH], AUTHORITY["EPSG","54004"]]
2009-07-03 13:08:58,754 INFO [geotools.factory] - Factory implementations for category CSAuthorityFactory:
  org.geotools.referencing.factory.epsg.DefaultFactory
  org.geotools.referencing.factory.epsg.LongitudeFirstFactory
  org.geotools.referencing.factory.URN_AuthorityFactory
  org.geotools.referencing.factory.HTTP_AuthorityFactory
  org.geotools.referencing.factory.epsg.LongitudeFirstEpsgDecorator
  org.geotools.referencing.factory.epsg.ThreadedHsqlEpsgFactory
2009-07-03 13:08:58,758 INFO [geotools.factory] - Factory implementations for category DatumAuthorityFactory:
2009-07-03 13:08:58,764 DEBUG [referencing.factory] - Failure in the primary factory: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject". Now trying the fallback factory...
2009-07-03 13:08:58,770 DEBUG [referencing.factory] - Failure in the primary factory: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject". Now trying the fallback factory...
2009-07-03 13:08:58,827 INFO [geoserver.wcs] -
Request: getServiceInfo
2009-07-03 13:08:59,110 DEBUG [geoserver.global] - getting coverage j2:pyramid
2009-07-03 13:08:59,144 INFO [geotools.factory] - Factory implementations for category GridCoverageFactory:
  org.geotools.coverage.grid.GridCoverageFactory
2009-07-03 13:08:59,200 DEBUG [gce.imagemosai] - Connected mosaic reader to its data store file:/C:/server/geoserver-1.7.5-bin/./data_dir/coverages/bluemarbles/bluemarble00/0/pyramid.shp
2009-07-03 13:08:59,201 DEBUG [data.shapefile] - Read lock: file:/C:/server/geoserver-1.7.5-bin/./data_dir/coverages/bluemarbles/bluemarble00/0/pyramid.shp by org.geotools.data.shapefile.shp.ShapefileReader
2009-07-03 13:08:59,203 TRACE [data.shapefile] - Shapefile Reader has been opened. Number open: 1
2009-07-03 13:08:59,203 TRACE [data.shapefile] - IndexFile has been opened. Number open: 1
2009-07-03 13:08:59,203 DEBUG [data.shapefile] - Read lock: file:/C:/server/geoserver-1.7.5-bin/./data_dir/coverages/bluemarbles/bluemarble00/0/pyramid.shx by org.geotools.data.shapefile.shp.IndexFile
2009-07-03 13:08:59,213 TRACE [data.shapefile] - Memory mapping file...
2009-07-03 13:08:59,223 DEBUG [data.shapefile] - Read lock: file:/C:/server/geoserver-1.7.5-bin/./data_dir/coverages/bluemarbles/bluemarble00/0/pyramid.dbf by org.geotools.data.shapefile.dbf.DbaseFileReader
2009-07-03 13:08:59,225 TRACE [data.shapefile] - Dbase File Reader has been opened. Number open: 1
2009-07-03 13:08:59,238 DEBUG [data.shapefile] - Read lock: file:/C:/server/geoserver-1.7.5-bin/./data_dir/coverages/bluemarbles/bluemarble00/0/pyramid.prj by org.geotools.data.shapefile.prj.PrjFileReader
2009-07-03 13:08:59,240 TRACE [data.shapefile] - PRJ reader has been opened. Number open: 1
2009-07-03 13:08:59,253 DEBUG [data.shapefile] - Read lock: file:/C:/server/geoserver-1.7.5-bin/./data_dir/coverages/bluemarbles/bluemarble00/0/pyramid.prj by org.geotools.data.shapefile.prj.PrjFileReader
2009-07-03 13:08:59,253 TRACE [data.shapefile] - PRJ reader has been closed. Number open: 0
2009-07-03 13:08:59,254 DEBUG [data.shapefile] - Read lock: file:/C:/server/geoserver-1.7.5-bin/./data_dir/coverages/bluemarbles/bluemarble00/0/pyramid.dbf by org.geotools.data.shapefile.dbf.DbaseFileReader
2009-07-03 13:08:59,255 TRACE [data.shapefile] - Dbase File Reader has been closed. Number open: 0
2009-07-03 13:08:59,256 DEBUG [data.shapefile] - Read lock: file:/C:/server/geoserver-1.7.5-bin/./data_dir/coverages/bluemarbles/bluemarble00/0/pyramid.shp by org.geotools.data.shapefile.shp.ShapefileReader
2009-07-03 13:08:59,257 TRACE [data.shapefile] - Shapefile Reader has been closed. Number open: 0
2009-07-03 13:08:59,257 DEBUG [data.shapefile] - Read lock: file:/C:/server/geoserver-1.7.5-bin/./data_dir/coverages/bluemarbles/bluemarble00/0/pyramid.shx by org.geotools.data.shapefile.shp.IndexFile
2009-07-03 13:08:59,258 TRACE [data.shapefile] - IndexFile has been closed. Number open: 0
2009-07-03 13:08:59,299 DEBUG [gce.imagemosai] - Highest res 0.004168982768204495 0.004168982768204495
2009-07-03 13:08:59,310 DEBUG [gce.imagemosai] - Reading mosaic from file:/C:/server/geoserver-1.7.5-bin/./data_dir/coverages/bluemarbles/bluemarble00/0/pyramid.shp
2009-07-03 13:08:59,310 DEBUG [gce.imagemosai] - Highest res 0.004168982768204495 0.004168982768204495
2009-07-03 13:08:59,325 DEBUG [gce.imagemosai] - Adjusted Requested Envelope = ReferencedEnvelope[-180.0020844913841 : -90.00208449138555, -89.997915508613 : 0.0020844913855455616]
Requested raster dimension = java.awt.Rectangle[x=0,y=0,width=21588,height=21588]
Corresponding raster source region = java.awt.Rectangle[x=0,y=0,width=21588,height=21588]
2009-07-03 13:08:59,333 DEBUG [gce.imagemosai] - Loading level 0 with subsampling factors 1 1
2009-07-03 13:08:59,349 DEBUG [gce.imagemosai] - Index needa to be recreated...
2009-07-03 13:08:59,361 DEBUG [gce.imagemosai] - Index Loaded
2009-07-03 13:08:59,375 DEBUG [data.shapefile] - Read lock: file:/C:/server/geoserver-1.7.5-bin/./data_dir/coverages/bluemarbles/bluemarble00/0/pyramid.shp by org.geotools.data.shapefile.shp.ShapefileReader
2009-07-03 13:08:59,376 TRACE [data.shapefile] - Shapefile Reader has been opened. Number open: 1
2009-07-03 13:08:59,376 TRACE [data.shapefile] - IndexFile has been opened. Number open: 1
2009-07-03 13:08:59,377 DEBUG [data.shapefile] - Read lock: file:/C:/server/geoserver-1.7.5-bin/./data_dir/coverages/bluemarbles/bluemarble00/0/pyramid.shx by org.geotools.data.shapefile.shp.IndexFile
2009-07-03 13:08:59,378 TRACE [data.shapefile] - Memory mapping file...
2009-07-03 13:08:59,378 DEBUG [data.shapefile] - Read lock: file:/C:/server/geoserver-1.7.5-bin/./data_dir/coverages/bluemarbles/bluemarble00/0/pyramid.dbf by org.geotools.data.shapefile.dbf.DbaseFileReader
2009-07-03 13:08:59,379 TRACE [data.shapefile] - Dbase File Reader has been opened. Number open: 1
2009-07-03 13:08:59,388 INFO [geotools.factory] - Factory implementations for category FeatureFactory:
  org.geotools.feature.LenientFeatureFactoryImpl
  org.geotools.feature.ValidatingFeatureFactoryImpl
2009-07-03 13:08:59,425 DEBUG [data.shapefile] - Read lock: file:/C:/server/geoserver-1.7.5-bin/./data_dir/coverages/bluemarbles/bluemarble00/0/pyramid.shp by org.geotools.data.shapefile.shp.ShapefileReader
2009-07-03 13:08:59,426 TRACE [data.shapefile] - Shapefile Reader has been closed. Number open: 0
2009-07-03 13:08:59,426 DEBUG [data.shapefile] - Read lock: file:/C:/server/geoserver-1.7.5-bin/./data_dir/coverages/bluemarbles/bluemarble00/0/pyramid.shx by org.geotools.data.shapefile.shp.IndexFile
2009-07-03 13:08:59,427 TRACE [data.shapefile] - IndexFile has been closed. Number open: 0
2009-07-03 13:08:59,428 DEBUG [data.shapefile] - Read lock: file:/C:/server/geoserver-1.7.5-bin/./data_dir/coverages/bluemarbles/bluemarble00/0/pyramid.dbf by org.geotools.data.shapefile.dbf.DbaseFileReader
2009-07-03 13:08:59,429 TRACE [data.shapefile] - Dbase File Reader has been closed. Number open: 0
2009-07-03 13:08:59,434 DEBUG [gce.imagemosai] - About to read image number 0
2009-07-03 13:08:59,435 DEBUG [gce.imagemosai] - File found mosaic_0.tiff
2009-07-03 13:08:59,632 DEBUG [gce.imagemosai] - About to read image number 1
2009-07-03 13:08:59,633 DEBUG [gce.imagemosai] - File found mosaic_1.tiff
2009-07-03 13:08:59,644 DEBUG [gce.imagemosai] - About to read image number 2
2009-07-03 13:08:59,645 DEBUG [gce.imagemosai] - File found mosaic_2.tiff
2009-07-03 13:08:59,661 DEBUG [gce.imagemosai] - About to read image number 3
2009-07-03 13:08:59,662 DEBUG [gce.imagemosai] - File found mosaic_21.tiff
2009-07-03 13:08:59,676 DEBUG [gce.imagemosai] - About to read image number 4
2009-07-03 13:08:59,676 DEBUG [gce.imagemosai] - File found mosaic_22.tiff
2009-07-03 13:08:59,690 DEBUG [gce.imagemosai] - About to read image number 5
2009-07-03 13:08:59,691 DEBUG [gce.imagemosai] - File found mosaic_23.tiff
2009-07-03 13:08:59,705 DEBUG [gce.imagemosai] - About to read image number 6
2009-07-03 13:08:59,705 DEBUG [gce.imagemosai] - File found mosaic_42.tiff
2009-07-03 13:08:59,716 DEBUG [gce.imagemosai] - About to read image number 7
2009-07-03 13:08:59,717 DEBUG [gce.imagemosai] - File found mosaic_43.tiff
2009-07-03 13:08:59,727 DEBUG [gce.imagemosai] - About to read image number 8
2009-07-03 13:08:59,727 DEBUG [gce.imagemosai] - File found mosaic_44.tiff
2009-07-03 13:08:59,743 DEBUG [gce.imagemosai] - About to read image number 9
2009-07-03 13:08:59,744 DEBUG [gce.imagemosai] - File found mosaic_63.tiff
2009-07-03 13:08:59,752 DEBUG [gce.imagemosai] - About to read image number 10
2009-07-03 13:08:59,753 DEBUG [gce.imagemosai] - File found mosaic_3.tiff
2009-07-03 13:08:59,762 DEBUG [gce.imagemosai] - About to read image number 11
2009-07-03 13:08:59,763 DEBUG [gce.imagemosai] - File found mosaic_4.tiff
2009-07-03 13:08:59,777 DEBUG [gce.imagemosai] - About to read image number 12
2009-07-03 13:08:59,778 DEBUG [gce.imagemosai] - File found mosaic_5.tiff
2009-07-03 13:08:59,788 DEBUG [gce.imagemosai] - About to read image number 13
2009-07-03 13:08:59,789 DEBUG [gce.imagemosai] - File found mosaic_24.tiff
2009-07-03 13:08:59,799 DEBUG [gce.imagemosai] - About to read image number 14
2009-07-03 13:08:59,799 DEBUG [gce.imagemosai] - File found mosaic_25.tiff
2009-07-03 13:08:59,809 DEBUG [gce.imagemosai] - About to read image number 15
2009-07-03 13:08:59,809 DEBUG [gce.imagemosai] - File found mosaic_26.tiff
2009-07-03 13:08:59,824 DEBUG [gce.imagemosai] - About to read image number 16
2009-07-03 13:08:59,824 DEBUG [gce.imagemosai] - File found mosaic_45.tiff
2009-07-03 13:08:59,839 DEBUG [gce.imagemosai] - About to read image number 17
2009-07-03 13:08:59,839 DEBUG [gce.imagemosai] - File found mosaic_46.tiff
2009-07-03 13:08:59,846 DEBUG [gce.imagemosai] - About to read image number 18
2009-07-03 13:08:59,846 DEBUG [gce.imagemosai] - File found mosaic_47.tiff
2009-07-03 13:08:59,856 DEBUG [gce.imagemosai] - About to read image number 19
2009-07-03 13:08:59,857 DEBUG [gce.imagemosai] - File found mosaic_66.tiff
2009-07-03 13:08:59,869 DEBUG [gce.imagemosai] - About to read image number 20
2009-07-03 13:08:59,869 DEBUG [gce.imagemosai] - File found mosaic_6.tiff
2009-07-03 13:08:59,884 DEBUG [gce.imagemosai] - About to read image number 21
2009-07-03 13:08:59,885 DEBUG [gce.imagemosai] - File found mosaic_7.tiff
2009-07-03 13:08:59,898 DEBUG [gce.imagemosai] - About to read image number 22
2009-07-03 13:08:59,899 DEBUG [gce.imagemosai] - File found mosaic_8.tiff
2009-07-03 13:08:59,911 DEBUG [gce.imagemosai] - About to read image number 23
2009-07-03 13:08:59,912 DEBUG [gce.imagemosai] - File found mosaic_27.tiff
2009-07-03 13:08:59,924 DEBUG [gce.imagemosai] - About to read image number 24
2009-07-03 13:08:59,925 DEBUG [gce.imagemosai] - File found mosaic_28.tiff
2009-07-03 13:08:59,936 DEBUG [gce.imagemosai] - About to read image number 25
2009-07-03 13:08:59,936 DEBUG [gce.imagemosai] - File found mosaic_29.tiff
2009-07-03 13:08:59,946 DEBUG [gce.imagemosai] - About to read image number 26
2009-07-03 13:08:59,946 DEBUG [gce.imagemosai] - File found mosaic_48.tiff
2009-07-03 13:08:59,955 DEBUG [gce.imagemosai] - About to read image number 27
2009-07-03 13:08:59,955 DEBUG [gce.imagemosai] - File found mosaic_49.tiff
2009-07-03 13:08:59,967 DEBUG [gce.imagemosai] - About to read image number 28
2009-07-03 13:08:59,967 DEBUG [gce.imagemosai] - File found mosaic_50.tiff
2009-07-03 13:08:59,981 DEBUG [gce.imagemosai] - About to read image number 29
2009-07-03 13:08:59,982 DEBUG [gce.imagemosai] - File found mosaic_69.tiff
2009-07-03 13:08:59,997 DEBUG [gce.imagemosai] - About to read image number 30
2009-07-03 13:08:59,997 DEBUG [gce.imagemosai] - File found mosaic_64.tiff
2009-07-03 13:09:00,006 DEBUG [gce.imagemosai] - About to read image number 31
2009-07-03 13:09:00,006 DEBUG [gce.imagemosai] - File found mosaic_65.tiff
2009-07-03 13:09:00,016 DEBUG [gce.imagemosai] - About to read image number 32
2009-07-03 13:09:00,016 DEBUG [gce.imagemosai] - File found mosaic_84.tiff
2009-07-03 13:09:00,031 DEBUG [gce.imagemosai] - About to read image number 33
2009-07-03 13:09:00,031 DEBUG [gce.imagemosai] - File found mosaic_85.tiff
2009-07-03 13:09:00,043 DEBUG [gce.imagemosai] - About to read image number 34
2009-07-03 13:09:00,043 DEBUG [gce.imagemosai] - File found mosaic_86.tiff
2009-07-03 13:09:00,053 DEBUG [gce.imagemosai] - About to read image number 35
2009-07-03 13:09:00,053 DEBUG [gce.imagemosai] - File found mosaic_105.tiff
2009-07-03 13:09:00,062 DEBUG [gce.imagemosai] - About to read image number 36
2009-07-03 13:09:00,062 DEBUG [gce.imagemosai] - File found mosaic_106.tiff
2009-07-03 13:09:00,072 DEBUG [gce.imagemosai] - About to read image number 37
2009-07-03 13:09:00,072 DEBUG [gce.imagemosai] - File found mosaic_107.tiff
2009-07-03 13:09:00,082 DEBUG [gce.imagemosai] - About to read image number 38
2009-07-03 13:09:00,082 DEBUG [gce.imagemosai] - File found mosaic_126.tiff
2009-07-03 13:09:00,098 DEBUG [gce.imagemosai] - About to read image number 39
2009-07-03 13:09:00,098 DEBUG [gce.imagemosai] - File found mosaic_127.tiff
2009-07-03 13:09:00,110 DEBUG [gce.imagemosai] - About to read image number 40
2009-07-03 13:09:00,110 DEBUG [gce.imagemosai] - File found mosaic_67.tiff
2009-07-03 13:09:00,123 DEBUG [gce.imagemosai] - About to read image number 41
2009-07-03 13:09:00,123 DEBUG [gce.imagemosai] - File found mosaic_68.tiff
2009-07-03 13:09:00,133 DEBUG [gce.imagemosai] - About to read image number 42
2009-07-03 13:09:00,134 DEBUG [gce.imagemosai] - File found mosaic_87.tiff
2009-07-03 13:09:00,147 DEBUG [gce.imagemosai] - About to read image number 43
2009-07-03 13:09:00,147 DEBUG [gce.imagemosai] - File found mosaic_88.tiff
2009-07-03 13:09:00,161 DEBUG [gce.imagemosai] - About to read image number 44
2009-07-03 13:09:00,162 DEBUG [gce.imagemosai] - File found mosaic_89.tiff
2009-07-03 13:09:00,172 DEBUG [gce.imagemosai] - About to read image number 45
2009-07-03 13:09:00,173 DEBUG [gce.imagemosai] - File found mosaic_108.tiff
2009-07-03 13:09:00,184 DEBUG [gce.imagemosai] - About to read image number 46
2009-07-03 13:09:00,185 DEBUG [gce.imagemosai] - File found mosaic_109.tiff
2009-07-03 13:09:00,199 DEBUG [gce.imagemosai] - About to read image number 47
2009-07-03 13:09:00,199 DEBUG [gce.imagemosai] - File found mosaic_110.tiff
2009-07-03 13:09:00,214 DEBUG [gce.imagemosai] - About to read image number 48
2009-07-03 13:09:00,215 DEBUG [gce.imagemosai] - File found mosaic_129.tiff
2009-07-03 13:09:00,230 DEBUG [gce.imagemosai] - About to read image number 49
2009-07-03 13:09:00,231 DEBUG [gce.imagemosai] - File found mosaic_130.tiff
2009-07-03 13:09:00,243 DEBUG [gce.imagemosai] - About to read image number 50
2009-07-03 13:09:00,244 DEBUG [gce.imagemosai] - File found mosaic_70.tiff
2009-07-03 13:09:00,260 DEBUG [gce.imagemosai] - About to read image number 51
2009-07-03 13:09:00,261 DEBUG [gce.imagemosai] - File found mosaic_71.tiff
2009-07-03 13:09:00,267 DEBUG [gce.imagemosai] - About to read image number 52
2009-07-03 13:09:00,267 DEBUG [gce.imagemosai] - File found mosaic_90.tiff
2009-07-03 13:09:00,278 DEBUG [gce.imagemosai] - About to read image number 53
2009-07-03 13:09:00,279 DEBUG [gce.imagemosai] - File found mosaic_91.tiff
2009-07-03 13:09:00,289 DEBUG [gce.imagemosai] - About to read image number 54
2009-07-03 13:09:00,289 DEBUG [gce.imagemosai] - File found mosaic_92.tiff
2009-07-03 13:09:00,301 DEBUG [gce.imagemosai] - About to read image number 55
2009-07-03 13:09:00,301 DEBUG [gce.imagemosai] - File found mosaic_111.tiff
2009-07-03 13:09:00,314 DEBUG [gce.imagemosai] - About to read image number 56
2009-07-03 13:09:00,314 DEBUG [gce.imagemosai] - File found mosaic_112.tiff
2009-07-03 13:09:00,316 DEBUG [gce.imagemosai] - About to read image number 57
2009-07-03 13:09:00,316 DEBUG [gce.imagemosai] - File found mosaic_113.tiff
2009-07-03 13:09:00,332 DEBUG [gce.imagemosai] - About to read image number 58
2009-07-03 13:09:00,333 DEBUG [gce.imagemosai] - File found mosaic_132.tiff
2009-07-03 13:09:00,349 DEBUG [gce.imagemosai] - About to read image number 59
2009-07-03 13:09:00,349 DEBUG [gce.imagemosai] - File found mosaic_133.tiff
2009-07-03 13:09:00,360 DEBUG [gce.imagemosai] - About to read image number 60
2009-07-03 13:09:00,361 DEBUG [gce.imagemosai] - File found mosaic_128.tiff
2009-07-03 13:09:00,362 DEBUG [gce.imagemosai] - About to read image number 61
2009-07-03 13:09:00,363 DEBUG [gce.imagemosai] - File found mosaic_147.tiff
2009-07-03 13:09:00,378 DEBUG [gce.imagemosai] - About to read image number 62
2009-07-03 13:09:00,378 DEBUG [gce.imagemosai] - File found mosaic_148.tiff
2009-07-03 13:09:00,392 DEBUG [gce.imagemosai] - About to read image number 63
2009-07-03 13:09:00,392 DEBUG [gce.imagemosai] - File found mosaic_149.tiff
2009-07-03 13:09:00,405 DEBUG [gce.imagemosai] - About to read image number 64
2009-07-03 13:09:00,406 DEBUG [gce.imagemosai] - File found mosaic_168.tiff
2009-07-03 13:09:00,413 DEBUG [gce.imagemosai] - About to read image number 65
2009-07-03 13:09:00,413 DEBUG [gce.imagemosai] - File found mosaic_169.tiff
2009-07-03 13:09:00,430 DEBUG [gce.imagemosai] - About to read image number 66
2009-07-03 13:09:00,431 DEBUG [gce.imagemosai] - File found mosaic_170.tiff
2009-07-03 13:09:00,474 DEBUG [gce.imagemosai] - About to read image number 67
2009-07-03 13:09:00,475 DEBUG [gce.imagemosai] - File found mosaic_189.tiff
2009-07-03 13:09:00,505 DEBUG [gce.imagemosai] - About to read image number 68
2009-07-03 13:09:00,506 DEBUG [gce.imagemosai] - File found mosaic_190.tiff
2009-07-03 13:09:00,550 DEBUG [gce.imagemosai] - About to read image number 69
2009-07-03 13:09:00,551 DEBUG [gce.imagemosai] - File found mosaic_191.tiff
2009-07-03 13:09:00,559 DEBUG [gce.imagemosai] - About to read image number 70
2009-07-03 13:09:00,559 DEBUG [gce.imagemosai] - File found mosaic_131.tiff
2009-07-03 13:09:00,576 DEBUG [gce.imagemosai] - About to read image number 71
2009-07-03 13:09:00,576 DEBUG [gce.imagemosai] - File found mosaic_150.tiff
2009-07-03 13:09:00,578 DEBUG [gce.imagemosai] - About to read image number 72
2009-07-03 13:09:00,578 DEBUG [gce.imagemosai] - File found mosaic_151.tiff
2009-07-03 13:09:00,634 DEBUG [gce.imagemosai] - About to read image number 73
2009-07-03 13:09:00,634 DEBUG [gce.imagemosai] - File found mosaic_152.tiff
2009-07-03 13:09:00,661 DEBUG [gce.imagemosai] - About to read image number 74
2009-07-03 13:09:00,662 DEBUG [gce.imagemosai] - File found mosaic_171.tiff
2009-07-03 13:09:00,672 DEBUG [gce.imagemosai] - About to read image number 75
2009-07-03 13:09:00,673 DEBUG [gce.imagemosai] - File found mosaic_172.tiff
2009-07-03 13:09:00,682 DEBUG [gce.imagemosai] - About to read image number 76
2009-07-03 13:09:00,682 DEBUG [gce.imagemosai] - File found mosaic_173.tiff
2009-07-03 13:09:00,699 DEBUG [gce.imagemosai] - About to read image number 77
2009-07-03 13:09:00,699 DEBUG [gce.imagemosai] - File found mosaic_192.tiff
2009-07-03 13:09:00,717 DEBUG [gce.imagemosai] - About to read image number 78
2009-07-03 13:09:00,717 DEBUG [gce.imagemosai] - File found mosaic_193.tiff
2009-07-03 13:09:00,724 DEBUG [gce.imagemosai] - About to read image number 79
2009-07-03 13:09:00,724 DEBUG [gce.imagemosai] - File found mosaic_194.tiff
2009-07-03 13:09:00,738 DEBUG [gce.imagemosai] - About to read image number 80
2009-07-03 13:09:00,739 DEBUG [gce.imagemosai] - File found mosaic_134.tiff
2009-07-03 13:09:00,754 DEBUG [gce.imagemosai] - About to read image number 81
2009-07-03 13:09:00,755 DEBUG [gce.imagemosai] - File found mosaic_153.tiff
2009-07-03 13:09:00,761 DEBUG [gce.imagemosai] - About to read image number 82
2009-07-03 13:09:00,763 DEBUG [gce.imagemosai] - File found mosaic_154.tiff
2009-07-03 13:09:00,770 DEBUG [gce.imagemosai] - About to read image number 83
2009-07-03 13:09:00,770 DEBUG [gce.imagemosai] - File found mosaic_155.tiff
2009-07-03 13:09:00,780 DEBUG [gce.imagemosai] - About to read image number 84
2009-07-03 13:09:00,781 DEBUG [gce.imagemosai] - File found mosaic_174.tiff
2009-07-03 13:09:00,788 DEBUG [gce.imagemosai] - About to read image number 85
2009-07-03 13:09:00,789 DEBUG [gce.imagemosai] - File found mosaic_175.tiff
2009-07-03 13:09:00,801 DEBUG [gce.imagemosai] - About to read image number 86
2009-07-03 13:09:00,802 DEBUG [gce.imagemosai] - File found mosaic_176.tiff
2009-07-03 13:09:00,817 DEBUG [gce.imagemosai] - About to read image number 87
2009-07-03 13:09:00,817 DEBUG [gce.imagemosai] - File found mosaic_195.tiff
2009-07-03 13:09:00,826 DEBUG [gce.imagemosai] - About to read image number 88
2009-07-03 13:09:00,827 DEBUG [gce.imagemosai] - File found mosaic_196.tiff
2009-07-03 13:09:00,836 DEBUG [gce.imagemosai] - About to read image number 89
2009-07-03 13:09:00,836 DEBUG [gce.imagemosai] - File found mosaic_197.tiff
2009-07-03 13:09:00,850 DEBUG [gce.imagemosai] - About to read image number 90
2009-07-03 13:09:00,851 DEBUG [gce.imagemosai] - File found mosaic_210.tiff
2009-07-03 13:09:00,857 DEBUG [gce.imagemosai] - About to read image number 91
2009-07-03 13:09:00,858 DEBUG [gce.imagemosai] - File found mosaic_211.tiff
2009-07-03 13:09:00,869 DEBUG [gce.imagemosai] - About to read image number 92
2009-07-03 13:09:00,870 DEBUG [gce.imagemosai] - File found mosaic_212.tiff
2009-07-03 13:09:00,882 DEBUG [gce.imagemosai] - About to read image number 93
2009-07-03 13:09:00,883 DEBUG [gce.imagemosai] - File found mosaic_231.tiff
2009-07-03 13:09:00,894 DEBUG [gce.imagemosai] - About to read image number 94
2009-07-03 13:09:00,894 DEBUG [gce.imagemosai] - File found mosaic_232.tiff
2009-07-03 13:09:00,909 DEBUG [gce.imagemosai] - About to read image number 95
2009-07-03 13:09:00,910 DEBUG [gce.imagemosai] - File found mosaic_233.tiff
2009-07-03 13:09:00,923 DEBUG [gce.imagemosai] - About to read image number 96
2009-07-03 13:09:00,923 DEBUG [gce.imagemosai] - File found mosaic_252.tiff
2009-07-03 13:09:00,931 DEBUG [gce.imagemosai] - About to read image number 97
2009-07-03 13:09:00,931 DEBUG [gce.imagemosai] - File found mosaic_253.tiff
2009-07-03 13:09:00,942 DEBUG [gce.imagemosai] - About to read image number 98
2009-07-03 13:09:00,943 DEBUG [gce.imagemosai] - File found mosaic_254.tiff
2009-07-03 13:09:00,952 DEBUG [gce.imagemosai] - About to read image number 99
2009-07-03 13:09:00,953 DEBUG [gce.imagemosai] - File found mosaic_273.tiff
2009-07-03 13:09:00,966 DEBUG [gce.imagemosai] - About to read image number 100
2009-07-03 13:09:00,967 DEBUG [gce.imagemosai] - File found mosaic_9.tiff
2009-07-03 13:09:00,975 DEBUG [gce.imagemosai] - About to read image number 101
2009-07-03 13:09:00,975 DEBUG [gce.imagemosai] - File found mosaic_10.tiff
2009-07-03 13:09:00,988 DEBUG [gce.imagemosai] - About to read image number 102
2009-07-03 13:09:00,989 DEBUG [gce.imagemosai] - File found mosaic_11.tiff
2009-07-03 13:09:01,002 DEBUG [gce.imagemosai] - About to read image number 103
2009-07-03 13:09:01,002 DEBUG [gce.imagemosai] - File found mosaic_30.tiff
2009-07-03 13:09:01,013 DEBUG [gce.imagemosai] - About to read image number 104
2009-07-03 13:09:01,013 DEBUG [gce.imagemosai] - File found mosaic_31.tiff
2009-07-03 13:09:01,026 DEBUG [gce.imagemosai] - About to read image number 105
2009-07-03 13:09:01,026 DEBUG [gce.imagemosai] - File found mosaic_32.tiff
2009-07-03 13:09:01,039 DEBUG [gce.imagemosai] - About to read image number 106
2009-07-03 13:09:01,040 DEBUG [gce.imagemosai] - File found mosaic_51.tiff
2009-07-03 13:09:01,051 DEBUG [gce.imagemosai] - About to read image number 107
2009-07-03 13:09:01,052 DEBUG [gce.imagemosai] - File found mosaic_52.tiff
2009-07-03 13:09:01,063 DEBUG [gce.imagemosai] - About to read image number 108
2009-07-03 13:09:01,064 DEBUG [gce.imagemosai] - File found mosaic_53.tiff
2009-07-03 13:09:01,076 DEBUG [gce.imagemosai] - About to read image number 109
2009-07-03 13:09:01,077 DEBUG [gce.imagemosai] - File found mosaic_72.tiff
2009-07-03 13:09:01,086 DEBUG [gce.imagemosai] - About to read image number 110
2009-07-03 13:09:01,086 DEBUG [gce.imagemosai] - File found mosaic_12.tiff
2009-07-03 13:09:01,094 DEBUG [gce.imagemosai] - About to read image number 111
2009-07-03 13:09:01,095 DEBUG [gce.imagemosai] - File found mosaic_13.tiff
2009-07-03 13:09:01,107 DEBUG [gce.imagemosai] - About to read image number 112
2009-07-03 13:09:01,107 DEBUG [gce.imagemosai] - File found mosaic_14.tiff
2009-07-03 13:09:01,116 DEBUG [gce.imagemosai] - About to read image number 113
2009-07-03 13:09:01,117 DEBUG [gce.imagemosai] - File found mosaic_33.tiff
2009-07-03 13:09:01,126 DEBUG [gce.imagemosai] - About to read image number 114
2009-07-03 13:09:01,126 DEBUG [gce.imagemosai] - File found mosaic_34.tiff
2009-07-03 13:09:01,145 DEBUG [gce.imagemosai] - About to read image number 115
2009-07-03 13:09:01,145 DEBUG [gce.imagemosai] - File found mosaic_35.tiff
2009-07-03 13:09:01,178 DEBUG [gce.imagemosai] - About to read image number 116
2009-07-03 13:09:01,179 DEBUG [gce.imagemosai] - File found mosaic_54.tiff
2009-07-03 13:09:01,191 DEBUG [gce.imagemosai] - About to read image number 117
2009-07-03 13:09:01,191 DEBUG [gce.imagemosai] - File found mosaic_55.tiff
2009-07-03 13:09:01,211 DEBUG [gce.imagemosai] - About to read image number 118
2009-07-03 13:09:01,211 DEBUG [gce.imagemosai] - File found mosaic_56.tiff
2009-07-03 13:09:01,221 DEBUG [gce.imagemosai] - About to read image number 119
2009-07-03 13:09:01,221 DEBUG [gce.imagemosai] - File found mosaic_75.tiff
2009-07-03 13:09:01,239 DEBUG [gce.imagemosai] - About to read image number 120
2009-07-03 13:09:01,240 DEBUG [gce.imagemosai] - File found mosaic_73.tiff
2009-07-03 13:09:01,289 DEBUG [gce.imagemosai] - About to read image number 121
2009-07-03 13:09:01,289 DEBUG [gce.imagemosai] - File found mosaic_74.tiff
2009-07-03 13:09:01,328 DEBUG [gce.imagemosai] - About to read image number 122
2009-07-03 13:09:01,328 DEBUG [gce.imagemosai] - File found mosaic_93.tiff
2009-07-03 13:09:01,365 DEBUG [gce.imagemosai] - About to read image number 123
2009-07-03 13:09:01,366 DEBUG [gce.imagemosai] - File found mosaic_94.tiff
2009-07-03 13:09:01,402 DEBUG [gce.imagemosai] - About to read image number 124
2009-07-03 13:09:01,403 DEBUG [gce.imagemosai] - File found mosaic_95.tiff
2009-07-03 13:09:01,446 DEBUG [gce.imagemosai] - About to read image number 125
2009-07-03 13:09:01,446 DEBUG [gce.imagemosai] - File found mosaic_114.tiff
2009-07-03 13:09:01,462 DEBUG [gce.imagemosai] - About to read image number 126
2009-07-03 13:09:01,462 DEBUG [gce.imagemosai] - File found mosaic_115.tiff
2009-07-03 13:09:01,474 DEBUG [gce.imagemosai] - About to read image number 127
2009-07-03 13:09:01,474 DEBUG [gce.imagemosai] - File found mosaic_116.tiff
2009-07-03 13:09:01,489 DEBUG [gce.imagemosai] - About to read image number 128
2009-07-03 13:09:01,489 DEBUG [gce.imagemosai] - File found mosaic_135.tiff
2009-07-03 13:09:01,498 DEBUG [gce.imagemosai] - About to read image number 129
2009-07-03 13:09:01,498 DEBUG [gce.imagemosai] - File found mosaic_136.tiff
2009-07-03 13:09:01,513 DEBUG [gce.imagemosai] - About to read image number 130
2009-07-03 13:09:01,514 DEBUG [gce.imagemosai] - File found mosaic_76.tiff
2009-07-03 13:09:01,524 DEBUG [gce.imagemosai] - About to read image number 131
2009-07-03 13:09:01,525 DEBUG [gce.imagemosai] - File found mosaic_77.tiff
2009-07-03 13:09:01,538 DEBUG [gce.imagemosai] - About to read image number 132
2009-07-03 13:09:01,539 DEBUG [gce.imagemosai] - File found mosaic_96.tiff
2009-07-03 13:09:01,554 DEBUG [gce.imagemosai] - About to read image number 133
2009-07-03 13:09:01,554 DEBUG [gce.imagemosai] - File found mosaic_97.tiff
2009-07-03 13:09:01,564 DEBUG [gce.imagemosai] - About to read image number 134
2009-07-03 13:09:01,564 DEBUG [gce.imagemosai] - File found mosaic_98.tiff
2009-07-03 13:09:01,585 DEBUG [gce.imagemosai] - About to read image number 135
2009-07-03 13:09:01,586 DEBUG [gce.imagemosai] - File found mosaic_117.tiff
2009-07-03 13:09:01,606 DEBUG [gce.imagemosai] - About to read image number 136
2009-07-03 13:09:01,606 DEBUG [gce.imagemosai] - File found mosaic_118.tiff
2009-07-03 13:09:01,619 DEBUG [gce.imagemosai] - About to read image number 137
2009-07-03 13:09:01,620 DEBUG [gce.imagemosai] - File found mosaic_119.tiff
2009-07-03 13:09:01,627 DEBUG [gce.imagemosai] - About to read image number 138
2009-07-03 13:09:01,627 DEBUG [gce.imagemosai] - File found mosaic_138.tiff
2009-07-03 13:09:01,635 DEBUG [gce.imagemosai] - About to read image number 139
2009-07-03 13:09:01,635 DEBUG [gce.imagemosai] - File found mosaic_139.tiff
2009-07-03 13:09:01,637 DEBUG [gce.imagemosai] - About to read image number 140
2009-07-03 13:09:01,637 DEBUG [gce.imagemosai] - File found mosaic_137.tiff
2009-07-03 13:09:01,652 DEBUG [gce.imagemosai] - About to read image number 141
2009-07-03 13:09:01,653 DEBUG [gce.imagemosai] - File found mosaic_156.tiff
2009-07-03 13:09:01,654 DEBUG [gce.imagemosai] - About to read image number 142
2009-07-03 13:09:01,654 DEBUG [gce.imagemosai] - File found mosaic_157.tiff
2009-07-03 13:09:01,666 DEBUG [gce.imagemosai] - About to read image number 143
2009-07-03 13:09:01,667 DEBUG [gce.imagemosai] - File found mosaic_158.tiff
2009-07-03 13:09:01,678 DEBUG [gce.imagemosai] - About to read image number 144
2009-07-03 13:09:01,679 DEBUG [gce.imagemosai] - File found mosaic_177.tiff
2009-07-03 13:09:01,692 DEBUG [gce.imagemosai] - About to read image number 145
2009-07-03 13:09:01,693 DEBUG [gce.imagemosai] - File found mosaic_178.tiff
2009-07-03 13:09:01,700 DEBUG [gce.imagemosai] - About to read image number 146
2009-07-03 13:09:01,701 DEBUG [gce.imagemosai] - File found mosaic_179.tiff
2009-07-03 13:09:01,716 DEBUG [gce.imagemosai] - About to read image number 147
2009-07-03 13:09:01,717 DEBUG [gce.imagemosai] - File found mosaic_198.tiff
2009-07-03 13:09:01,725 DEBUG [gce.imagemosai] - About to read image number 148
2009-07-03 13:09:01,726 DEBUG [gce.imagemosai] - File found mosaic_199.tiff
2009-07-03 13:09:01,738 DEBUG [gce.imagemosai] - About to read image number 149
2009-07-03 13:09:01,739 DEBUG [gce.imagemosai] - File found mosaic_200.tiff
2009-07-03 13:09:01,749 DEBUG [gce.imagemosai] - About to read image number 150
2009-07-03 13:09:01,749 DEBUG [gce.imagemosai] - File found mosaic_140.tiff
2009-07-03 13:09:01,751 DEBUG [gce.imagemosai] - About to read image number 151
2009-07-03 13:09:01,751 DEBUG [gce.imagemosai] - File found mosaic_159.tiff
2009-07-03 13:09:01,761 DEBUG [gce.imagemosai] - About to read image number 152
2009-07-03 13:09:01,761 DEBUG [gce.imagemosai] - File found mosaic_160.tiff
2009-07-03 13:09:01,769 DEBUG [gce.imagemosai] - About to read image number 153
2009-07-03 13:09:01,769 DEBUG [gce.imagemosai] - File found mosaic_161.tiff
2009-07-03 13:09:01,778 DEBUG [gce.imagemosai] - About to read image number 154
2009-07-03 13:09:01,779 DEBUG [gce.imagemosai] - File found mosaic_180.tiff
2009-07-03 13:09:01,791 DEBUG [gce.imagemosai] - About to read image number 155
2009-07-03 13:09:01,792 DEBUG [gce.imagemosai] - File found mosaic_181.tiff
2009-07-03 13:09:01,802 DEBUG [gce.imagemosai] - About to read image number 156
2009-07-03 13:09:01,802 DEBUG [gce.imagemosai] - File found mosaic_182.tiff
2009-07-03 13:09:01,819 DEBUG [gce.imagemosai] - About to read image number 157
2009-07-03 13:09:01,820 DEBUG [gce.imagemosai] - File found mosaic_201.tiff
2009-07-03 13:09:01,850 DEBUG [gce.imagemosai] - About to read image number 158
2009-07-03 13:09:01,851 DEBUG [gce.imagemosai] - File found mosaic_202.tiff
2009-07-03 13:09:01,862 DEBUG [gce.imagemosai] - About to read image number 159
2009-07-03 13:09:01,863 DEBUG [gce.imagemosai] - File found mosaic_203.tiff
2009-07-03 13:09:01,879 DEBUG [gce.imagemosai] - About to read image number 160
2009-07-03 13:09:01,879 DEBUG [gce.imagemosai] - File found mosaic_216.tiff
2009-07-03 13:09:01,889 DEBUG [gce.imagemosai] - About to read image number 161
2009-07-03 13:09:01,890 DEBUG [gce.imagemosai] - File found mosaic_217.tiff
2009-07-03 13:09:01,898 DEBUG [gce.imagemosai] - About to read image number 162
2009-07-03 13:09:01,899 DEBUG [gce.imagemosai] - File found mosaic_218.tiff
2009-07-03 13:09:01,906 DEBUG [gce.imagemosai] - About to read image number 163
2009-07-03 13:09:01,907 DEBUG [gce.imagemosai] - File found mosaic_237.tiff
2009-07-03 13:09:01,925 DEBUG [gce.imagemosai] - About to read image number 164
2009-07-03 13:09:01,926 DEBUG [gce.imagemosai] - File found mosaic_238.tiff
2009-07-03 13:09:01,937 DEBUG [gce.imagemosai] - About to read image number 165
2009-07-03 13:09:01,938 DEBUG [gce.imagemosai] - File found mosaic_239.tiff
2009-07-03 13:09:01,947 DEBUG [gce.imagemosai] - About to read image number 166
2009-07-03 13:09:01,947 DEBUG [gce.imagemosai] - File found mosaic_258.tiff
2009-07-03 13:09:01,956 DEBUG [gce.imagemosai] - About to read image number 167
2009-07-03 13:09:01,956 DEBUG [gce.imagemosai] - File found mosaic_259.tiff
2009-07-03 13:09:01,966 DEBUG [gce.imagemosai] - About to read image number 168
2009-07-03 13:09:01,966 DEBUG [gce.imagemosai] - File found mosaic_260.tiff
2009-07-03 13:09:01,978 DEBUG [gce.imagemosai] - About to read image number 169
2009-07-03 13:09:01,979 DEBUG [gce.imagemosai] - File found mosaic_279.tiff
2009-07-03 13:09:01,987 DEBUG [gce.imagemosai] - About to read image number 170
2009-07-03 13:09:01,987 DEBUG [gce.imagemosai] - File found mosaic_219.tiff
2009-07-03 13:09:01,996 DEBUG [gce.imagemosai] - About to read image number 171
2009-07-03 13:09:01,996 DEBUG [gce.imagemosai] - File found mosaic_220.tiff
2009-07-03 13:09:02,008 DEBUG [gce.imagemosai] - About to read image number 172
2009-07-03 13:09:02,009 DEBUG [gce.imagemosai] - File found mosaic_221.tiff
2009-07-03 13:09:02,021 DEBUG [gce.imagemosai] - About to read image number 173
2009-07-03 13:09:02,022 DEBUG [gce.imagemosai] - File found mosaic_240.tiff
2009-07-03 13:09:02,036 DEBUG [gce.imagemosai] - About to read image number 174
2009-07-03 13:09:02,037 DEBUG [gce.imagemosai] - File found mosaic_241.tiff
2009-07-03 13:09:02,045 DEBUG [gce.imagemosai] - About to read image number 175
2009-07-03 13:09:02,046 DEBUG [gce.imagemosai] - File found mosaic_242.tiff
2009-07-03 13:09:02,056 DEBUG [gce.imagemosai] - About to read image number 176
2009-07-03 13:09:02,056 DEBUG [gce.imagemosai] - File found mosaic_261.tiff
2009-07-03 13:09:02,068 DEBUG [gce.imagemosai] - About to read image number 177
2009-07-03 13:09:02,069 DEBUG [gce.imagemosai] - File found mosaic_262.tiff
2009-07-03 13:09:02,077 DEBUG [gce.imagemosai] - About to read image number 178
2009-07-03 13:09:02,077 DEBUG [gce.imagemosai] - File found mosaic_263.tiff
2009-07-03 13:09:02,087 DEBUG [gce.imagemosai] - About to read image number 179
2009-07-03 13:09:02,088 DEBUG [gce.imagemosai] - File found mosaic_282.tiff
2009-07-03 13:09:02,094 DEBUG [gce.imagemosai] - About to read image number 180
2009-07-03 13:09:02,095 DEBUG [gce.imagemosai] - File found mosaic_222.tiff
2009-07-03 13:09:02,108 DEBUG [gce.imagemosai] - About to read image number 181
2009-07-03 13:09:02,108 DEBUG [gce.imagemosai] - File found mosaic_223.tiff
2009-07-03 13:09:02,119 DEBUG [gce.imagemosai] - About to read image number 182
2009-07-03 13:09:02,120 DEBUG [gce.imagemosai] - File found mosaic_224.tiff
2009-07-03 13:09:02,131 DEBUG [gce.imagemosai] - About to read image number 183
2009-07-03 13:09:02,132 DEBUG [gce.imagemosai] - File found mosaic_243.tiff
2009-07-03 13:09:02,142 DEBUG [gce.imagemosai] - About to read image number 184
2009-07-03 13:09:02,143 DEBUG [gce.imagemosai] - File found mosaic_244.tiff
2009-07-03 13:09:02,155 DEBUG [gce.imagemosai] - About to read image number 185
2009-07-03 13:09:02,156 DEBUG [gce.imagemosai] - File found mosaic_245.tiff
2009-07-03 13:09:02,175 DEBUG [gce.imagemosai] - About to read image number 186
2009-07-03 13:09:02,175 DEBUG [gce.imagemosai] - File found mosaic_264.tiff
2009-07-03 13:09:02,194 DEBUG [gce.imagemosai] - About to read image number 187
2009-07-03 13:09:02,195 DEBUG [gce.imagemosai] - File found mosaic_265.tiff
2009-07-03 13:09:02,206 DEBUG [gce.imagemosai] - About to read image number 188
2009-07-03 13:09:02,206 DEBUG [gce.imagemosai] - File found mosaic_266.tiff
2009-07-03 13:09:02,215 DEBUG [gce.imagemosai] - About to read image number 189
2009-07-03 13:09:02,215 DEBUG [gce.imagemosai] - File found mosaic_285.tiff
2009-07-03 13:09:02,224 DEBUG [gce.imagemosai] - About to read image number 190
2009-07-03 13:09:02,225 DEBUG [gce.imagemosai] - File found mosaic_280.tiff
2009-07-03 13:09:02,236 DEBUG [gce.imagemosai] - About to read image number 191
2009-07-03 13:09:02,237 DEBUG [gce.imagemosai] - File found mosaic_281.tiff
2009-07-03 13:09:02,249 DEBUG [gce.imagemosai] - About to read image number 192
2009-07-03 13:09:02,250 DEBUG [gce.imagemosai] - File found mosaic_300.tiff
2009-07-03 13:09:02,258 DEBUG [gce.imagemosai] - About to read image number 193
2009-07-03 13:09:02,258 DEBUG [gce.imagemosai] - File found mosaic_301.tiff
2009-07-03 13:09:02,270 DEBUG [gce.imagemosai] - About to read image number 194
2009-07-03 13:09:02,271 DEBUG [gce.imagemosai] - File found mosaic_302.tiff
2009-07-03 13:09:02,286 DEBUG [gce.imagemosai] - About to read image number 195
2009-07-03 13:09:02,286 DEBUG [gce.imagemosai] - File found mosaic_321.tiff
2009-07-03 13:09:02,300 DEBUG [gce.imagemosai] - About to read image number 196
2009-07-03 13:09:02,301 DEBUG [gce.imagemosai] - File found mosaic_322.tiff
2009-07-03 13:09:02,310 DEBUG [gce.imagemosai] - About to read image number 197
2009-07-03 13:09:02,311 DEBUG [gce.imagemosai] - File found mosaic_323.tiff
2009-07-03 13:09:02,321 DEBUG [gce.imagemosai] - About to read image number 198
2009-07-03 13:09:02,322 DEBUG [gce.imagemosai] - File found mosaic_342.tiff
2009-07-03 13:09:02,334 DEBUG [gce.imagemosai] - About to read image number 199
2009-07-03 13:09:02,334 DEBUG [gce.imagemosai] - File found mosaic_343.tiff
2009-07-03 13:09:02,347 DEBUG [gce.imagemosai] - About to read image number 200
2009-07-03 13:09:02,347 DEBUG [gce.imagemosai] - File found mosaic_15.tiff
2009-07-03 13:09:02,358 DEBUG [gce.imagemosai] - About to read image number 201
2009-07-03 13:09:02,359 DEBUG [gce.imagemosai] - File found mosaic_16.tiff
2009-07-03 13:09:02,371 DEBUG [gce.imagemosai] - About to read image number 202
2009-07-03 13:09:02,371 DEBUG [gce.imagemosai] - File found mosaic_17.tiff
2009-07-03 13:09:02,380 DEBUG [gce.imagemosai] - About to read image number 203
2009-07-03 13:09:02,380 DEBUG [gce.imagemosai] - File found mosaic_36.tiff
2009-07-03 13:09:02,392 DEBUG [gce.imagemosai] - About to read image number 204
2009-07-03 13:09:02,392 DEBUG [gce.imagemosai] - File found mosaic_37.tiff
2009-07-03 13:09:02,423 DEBUG [gce.imagemosai] - About to read image number 205
2009-07-03 13:09:02,423 DEBUG [gce.imagemosai] - File found mosaic_38.tiff
2009-07-03 13:09:02,440 DEBUG [gce.imagemosai] - About to read image number 206
2009-07-03 13:09:02,440 DEBUG [gce.imagemosai] - File found mosaic_57.tiff
2009-07-03 13:09:02,448 DEBUG [gce.imagemosai] - About to read image number 207
2009-07-03 13:09:02,448 DEBUG [gce.imagemosai] - File found mosaic_58.tiff
2009-07-03 13:09:02,461 DEBUG [gce.imagemosai] - About to read image number 208
2009-07-03 13:09:02,462 DEBUG [gce.imagemosai] - File found mosaic_59.tiff
2009-07-03 13:09:02,472 DEBUG [gce.imagemosai] - About to read image number 209
2009-07-03 13:09:02,473 DEBUG [gce.imagemosai] - File found mosaic_78.tiff
2009-07-03 13:09:02,481 DEBUG [gce.imagemosai] - About to read image number 210
2009-07-03 13:09:02,481 DEBUG [gce.imagemosai] - File found mosaic_18.tiff
2009-07-03 13:09:02,493 DEBUG [gce.imagemosai] - About to read image number 211
2009-07-03 13:09:02,494 DEBUG [gce.imagemosai] - File found mosaic_19.tiff
2009-07-03 13:09:02,508 DEBUG [gce.imagemosai] - About to read image number 212
2009-07-03 13:09:02,509 DEBUG [gce.imagemosai] - File found mosaic_20.tiff
2009-07-03 13:09:02,521 DEBUG [gce.imagemosai] - About to read image number 213
2009-07-03 13:09:02,521 DEBUG [gce.imagemosai] - File found mosaic_39.tiff
2009-07-03 13:09:02,536 DEBUG [gce.imagemosai] - About to read image number 214
2009-07-03 13:09:02,536 DEBUG [gce.imagemosai] - File found mosaic_40.tiff
2009-07-03 13:09:02,548 DEBUG [gce.imagemosai] - About to read image number 215
2009-07-03 13:09:02,548 DEBUG [gce.imagemosai] - File found mosaic_41.tiff
2009-07-03 13:09:02,561 DEBUG [gce.imagemosai] - About to read image number 216
2009-07-03 13:09:02,562 DEBUG [gce.imagemosai] - File found mosaic_60.tiff
2009-07-03 13:09:02,570 DEBUG [gce.imagemosai] - About to read image number 217
2009-07-03 13:09:02,571 DEBUG [gce.imagemosai] - File found mosaic_61.tiff
2009-07-03 13:09:02,581 DEBUG [gce.imagemosai] - About to read image number 218
2009-07-03 13:09:02,581 DEBUG [gce.imagemosai] - File found mosaic_62.tiff
2009-07-03 13:09:02,591 DEBUG [gce.imagemosai] - About to read image number 219
2009-07-03 13:09:02,591 DEBUG [gce.imagemosai] - File found mosaic_81.tiff
2009-07-03 13:09:02,599 DEBUG [gce.imagemosai] - About to read image number 220
2009-07-03 13:09:02,599 DEBUG [gce.imagemosai] - File found mosaic_79.tiff
2009-07-03 13:09:02,609 DEBUG [gce.imagemosai] - About to read image number 221
2009-07-03 13:09:02,610 DEBUG [gce.imagemosai] - File found mosaic_80.tiff
2009-07-03 13:09:02,621 DEBUG [gce.imagemosai] - About to read image number 222
2009-07-03 13:09:02,621 DEBUG [gce.imagemosai] - File found mosaic_99.tiff
2009-07-03 13:09:02,636 DEBUG [gce.imagemosai] - About to read image number 223
2009-07-03 13:09:02,637 DEBUG [gce.imagemosai] - File found mosaic_100.tiff
2009-07-03 13:09:02,644 DEBUG [gce.imagemosai] - About to read image number 224
2009-07-03 13:09:02,645 DEBUG [gce.imagemosai] - File found mosaic_101.tiff
2009-07-03 13:09:02,658 DEBUG [gce.imagemosai] - About to read image number 225
2009-07-03 13:09:02,658 DEBUG [gce.imagemosai] - File found mosaic_120.tiff
2009-07-03 13:09:02,667 DEBUG [gce.imagemosai] - About to read image number 226
2009-07-03 13:09:02,667 DEBUG [gce.imagemosai] - File found mosaic_121.tiff
2009-07-03 13:09:02,676 DEBUG [gce.imagemosai] - About to read image number 227
2009-07-03 13:09:02,676 DEBUG [gce.imagemosai] - File found mosaic_122.tiff
2009-07-03 13:09:02,677 DEBUG [gce.imagemosai] - About to read image number 228
2009-07-03 13:09:02,677 DEBUG [gce.imagemosai] - File found mosaic_141.tiff
2009-07-03 13:09:02,686 DEBUG [gce.imagemosai] - About to read image number 229
2009-07-03 13:09:02,687 DEBUG [gce.imagemosai] - File found mosaic_142.tiff
2009-07-03 13:09:02,703 DEBUG [gce.imagemosai] - About to read image number 230
2009-07-03 13:09:02,703 DEBUG [gce.imagemosai] - File found mosaic_82.tiff
2009-07-03 13:09:02,717 DEBUG [gce.imagemosai] - About to read image number 231
2009-07-03 13:09:02,717 DEBUG [gce.imagemosai] - File found mosaic_83.tiff
2009-07-03 13:09:02,728 DEBUG [gce.imagemosai] - About to read image number 232
2009-07-03 13:09:02,728 DEBUG [gce.imagemosai] - File found mosaic_102.tiff
2009-07-03 13:09:02,738 DEBUG [gce.imagemosai] - About to read image number 233
2009-07-03 13:09:02,738 DEBUG [gce.imagemosai] - File found mosaic_103.tiff
2009-07-03 13:09:02,753 DEBUG [gce.imagemosai] - About to read image number 234
2009-07-03 13:09:02,753 DEBUG [gce.imagemosai] - File found mosaic_104.tiff
2009-07-03 13:09:02,763 DEBUG [gce.imagemosai] - About to read image number 235
2009-07-03 13:09:02,764 DEBUG [gce.imagemosai] - File found mosaic_123.tiff
2009-07-03 13:09:02,777 DEBUG [gce.imagemosai] - About to read image number 236
2009-07-03 13:09:02,777 DEBUG [gce.imagemosai] - File found mosaic_124.tiff
2009-07-03 13:09:02,790 DEBUG [gce.imagemosai] - About to read image number 237
2009-07-03 13:09:02,790 DEBUG [gce.imagemosai] - File found mosaic_125.tiff
2009-07-03 13:09:02,798 DEBUG [gce.imagemosai] - About to read image number 238
2009-07-03 13:09:02,798 DEBUG [gce.imagemosai] - File found mosaic_144.tiff
2009-07-03 13:09:02,804 DEBUG [gce.imagemosai] - About to read image number 239
2009-07-03 13:09:02,804 DEBUG [gce.imagemosai] - File found mosaic_145.tiff
2009-07-03 13:09:02,816 DEBUG [gce.imagemosai] - About to read image number 240
2009-07-03 13:09:02,816 DEBUG [gce.imagemosai] - File found mosaic_143.tiff
2009-07-03 13:09:02,827 DEBUG [gce.imagemosai] - About to read image number 241
2009-07-03 13:09:02,827 DEBUG [gce.imagemosai] - File found mosaic_162.tiff
2009-07-03 13:09:02,841 DEBUG [gce.imagemosai] - About to read image number 242
2009-07-03 13:09:02,842 DEBUG [gce.imagemosai] - File found mosaic_163.tiff
2009-07-03 13:09:02,852 DEBUG [gce.imagemosai] - About to read image number 243
2009-07-03 13:09:02,852 DEBUG [gce.imagemosai] - File found mosaic_164.tiff
2009-07-03 13:09:02,862 DEBUG [gce.imagemosai] - About to read image number 244
2009-07-03 13:09:02,862 DEBUG [gce.imagemosai] - File found mosaic_183.tiff
2009-07-03 13:09:02,871 DEBUG [gce.imagemosai] - About to read image number 245
2009-07-03 13:09:02,872 DEBUG [gce.imagemosai] - File found mosaic_184.tiff
2009-07-03 13:09:02,885 DEBUG [gce.imagemosai] - About to read image number 246
2009-07-03 13:09:02,885 DEBUG [gce.imagemosai] - File found mosaic_185.tiff
2009-07-03 13:09:02,898 DEBUG [gce.imagemosai] - About to read image number 247
2009-07-03 13:09:02,898 DEBUG [gce.imagemosai] - File found mosaic_204.tiff
2009-07-03 13:09:02,919 DEBUG [gce.imagemosai] - About to read image number 248
2009-07-03 13:09:02,919 DEBUG [gce.imagemosai] - File found mosaic_205.tiff
2009-07-03 13:09:02,927 DEBUG [gce.imagemosai] - About to read image number 249
2009-07-03 13:09:02,927 DEBUG [gce.imagemosai] - File found mosaic_206.tiff
2009-07-03 13:09:02,941 DEBUG [gce.imagemosai] - About to read image number 250
2009-07-03 13:09:02,942 DEBUG [gce.imagemosai] - File found mosaic_146.tiff
2009-07-03 13:09:02,956 DEBUG [gce.imagemosai] - About to read image number 251
2009-07-03 13:09:02,957 DEBUG [gce.imagemosai] - File found mosaic_165.tiff
2009-07-03 13:09:02,967 DEBUG [gce.imagemosai] - About to read image number 252
2009-07-03 13:09:02,967 DEBUG [gce.imagemosai] - File found mosaic_166.tiff
2009-07-03 13:09:02,976 DEBUG [gce.imagemosai] - About to read image number 253
2009-07-03 13:09:02,976 DEBUG [gce.imagemosai] - File found mosaic_167.tiff
2009-07-03 13:09:02,991 DEBUG [gce.imagemosai] - About to read image number 254
2009-07-03 13:09:02,991 DEBUG [gce.imagemosai] - File found mosaic_186.tiff
2009-07-03 13:09:03,004 DEBUG [gce.imagemosai] - About to read image number 255
2009-07-03 13:09:03,005 DEBUG [gce.imagemosai] - File found mosaic_187.tiff
2009-07-03 13:09:03,015 DEBUG [gce.imagemosai] - About to read image number 256
2009-07-03 13:09:03,016 DEBUG [gce.imagemosai] - File found mosaic_188.tiff
2009-07-03 13:09:03,027 DEBUG [gce.imagemosai] - About to read image number 257
2009-07-03 13:09:03,027 DEBUG [gce.imagemosai] - File found mosaic_207.tiff
2009-07-03 13:09:03,041 DEBUG [gce.imagemosai] - About to read image number 258
2009-07-03 13:09:03,041 DEBUG [gce.imagemosai] - File found mosaic_208.tiff
2009-07-03 13:09:03,050 DEBUG [gce.imagemosai] - About to read image number 259
2009-07-03 13:09:03,051 DEBUG [gce.imagemosai] - File found mosaic_209.tiff
2009-07-03 13:09:03,059 DEBUG [gce.imagemosai] - About to read image number 260
2009-07-03 13:09:03,060 DEBUG [gce.imagemosai] - File found mosaic_225.tiff
2009-07-03 13:09:03,070 DEBUG [gce.imagemosai] - About to read image number 261
2009-07-03 13:09:03,070 DEBUG [gce.imagemosai] - File found mosaic_226.tiff
2009-07-03 13:09:03,077 DEBUG [gce.imagemosai] - About to read image number 262
2009-07-03 13:09:03,078 DEBUG [gce.imagemosai] - File found mosaic_227.tiff
2009-07-03 13:09:03,086 DEBUG [gce.imagemosai] - About to read image number 263
2009-07-03 13:09:03,087 DEBUG [gce.imagemosai] - File found mosaic_246.tiff
2009-07-03 13:09:03,100 DEBUG [gce.imagemosai] - About to read image number 264
2009-07-03 13:09:03,100 DEBUG [gce.imagemosai] - File found mosaic_247.tiff
2009-07-03 13:09:03,113 DEBUG [gce.imagemosai] - About to read image number 265
2009-07-03 13:09:03,113 DEBUG [gce.imagemosai] - File found mosaic_248.tiff
2009-07-03 13:09:03,122 DEBUG [gce.imagemosai] - About to read image number 266
2009-07-03 13:09:03,123 DEBUG [gce.imagemosai] - File found mosaic_267.tiff
2009-07-03 13:09:03,134 DEBUG [gce.imagemosai] - About to read image number 267
2009-07-03 13:09:03,134 DEBUG [gce.imagemosai] - File found mosaic_268.tiff
2009-07-03 13:09:03,146 DEBUG [gce.imagemosai] - About to read image number 268
2009-07-03 13:09:03,147 DEBUG [gce.imagemosai] - File found mosaic_269.tiff
2009-07-03 13:09:03,157 DEBUG [gce.imagemosai] - About to read image number 269
2009-07-03 13:09:03,157 DEBUG [gce.imagemosai] - File found mosaic_288.tiff
2009-07-03 13:09:03,168 DEBUG [gce.imagemosai] - About to read image number 270
2009-07-03 13:09:03,168 DEBUG [gce.imagemosai] - File found mosaic_228.tiff
2009-07-03 13:09:03,180 DEBUG [gce.imagemosai] - About to read image number 271
2009-07-03 13:09:03,181 DEBUG [gce.imagemosai] - File found mosaic_229.tiff
2009-07-03 13:09:03,198 DEBUG [gce.imagemosai] - About to read image number 272
2009-07-03 13:09:03,199 DEBUG [gce.imagemosai] - File found mosaic_230.tiff
2009-07-03 13:09:03,208 DEBUG [gce.imagemosai] - About to read image number 273
2009-07-03 13:09:03,209 DEBUG [gce.imagemosai] - File found mosaic_249.tiff
2009-07-03 13:09:03,216 DEBUG [gce.imagemosai] - About to read image number 274
2009-07-03 13:09:03,217 DEBUG [gce.imagemosai] - File found mosaic_250.tiff
2009-07-03 13:09:03,229 DEBUG [gce.imagemosai] - About to read image number 275
2009-07-03 13:09:03,229 DEBUG [gce.imagemosai] - File found mosaic_251.tiff
2009-07-03 13:09:03,241 DEBUG [gce.imagemosai] - About to read image number 276
2009-07-03 13:09:03,241 DEBUG [gce.imagemosai] - File found mosaic_270.tiff
2009-07-03 13:09:03,251 DEBUG [gce.imagemosai] - About to read image number 277
2009-07-03 13:09:03,251 DEBUG [gce.imagemosai] - File found mosaic_271.tiff
2009-07-03 13:09:03,262 DEBUG [gce.imagemosai] - About to read image number 278
2009-07-03 13:09:03,262 DEBUG [gce.imagemosai] - File found mosaic_272.tiff
2009-07-03 13:09:03,273 DEBUG [gce.imagemosai] - About to read image number 279
2009-07-03 13:09:03,274 DEBUG [gce.imagemosai] - File found mosaic_291.tiff
2009-07-03 13:09:03,282 DEBUG [gce.imagemosai] - About to read image number 280
2009-07-03 13:09:03,282 DEBUG [gce.imagemosai] - File found mosaic_289.tiff
2009-07-03 13:09:03,293 DEBUG [gce.imagemosai] - About to read image number 281
2009-07-03 13:09:03,294 DEBUG [gce.imagemosai] - File found mosaic_290.tiff
2009-07-03 13:09:03,306 DEBUG [gce.imagemosai] - About to read image number 282
2009-07-03 13:09:03,306 DEBUG [gce.imagemosai] - File found mosaic_309.tiff
2009-07-03 13:09:03,322 DEBUG [gce.imagemosai] - About to read image number 283
2009-07-03 13:09:03,323 DEBUG [gce.imagemosai] - File found mosaic_310.tiff
2009-07-03 13:09:03,334 DEBUG [gce.imagemosai] - About to read image number 284
2009-07-03 13:09:03,334 DEBUG [gce.imagemosai] - File found mosaic_311.tiff
2009-07-03 13:09:03,343 DEBUG [gce.imagemosai] - About to read image number 285
2009-07-03 13:09:03,344 DEBUG [gce.imagemosai] - File found mosaic_330.tiff
2009-07-03 13:09:03,353 DEBUG [gce.imagemosai] - About to read image number 286
2009-07-03 13:09:03,353 DEBUG [gce.imagemosai] - File found mosaic_331.tiff
2009-07-03 13:09:03,364 DEBUG [gce.imagemosai] - About to read image number 287
2009-07-03 13:09:03,365 DEBUG [gce.imagemosai] - File found mosaic_332.tiff
2009-07-03 13:09:03,375 DEBUG [gce.imagemosai] - About to read image number 288
2009-07-03 13:09:03,375 DEBUG [gce.imagemosai] - File found mosaic_351.tiff
2009-07-03 13:09:03,389 DEBUG [gce.imagemosai] - About to read image number 289
2009-07-03 13:09:03,389 DEBUG [gce.imagemosai] - File found mosaic_352.tiff
2009-07-03 13:09:03,395 DEBUG [gce.imagemosai] - About to read image number 290
2009-07-03 13:09:03,396 DEBUG [gce.imagemosai] - File found mosaic_292.tiff
2009-07-03 13:09:03,403 DEBUG [gce.imagemosai] - About to read image number 291
2009-07-03 13:09:03,403 DEBUG [gce.imagemosai] - File found mosaic_293.tiff
2009-07-03 13:09:03,418 DEBUG [gce.imagemosai] - About to read image number 292
2009-07-03 13:09:03,419 DEBUG [gce.imagemosai] - File found mosaic_312.tiff
2009-07-03 13:09:03,429 DEBUG [gce.imagemosai] - About to read image number 293
2009-07-03 13:09:03,429 DEBUG [gce.imagemosai] - File found mosaic_313.tiff
2009-07-03 13:09:03,439 DEBUG [gce.imagemosai] - About to read image number 294
2009-07-03 13:09:03,440 DEBUG [gce.imagemosai] - File found mosaic_314.tiff
2009-07-03 13:09:03,455 DEBUG [gce.imagemosai] - About to read image number 295
2009-07-03 13:09:03,456 DEBUG [gce.imagemosai] - File found mosaic_333.tiff
2009-07-03 13:09:03,461 DEBUG [gce.imagemosai] - About to read image number 296
2009-07-03 13:09:03,462 DEBUG [gce.imagemosai] - File found mosaic_334.tiff
2009-07-03 13:09:03,473 DEBUG [gce.imagemosai] - About to read image number 297
2009-07-03 13:09:03,474 DEBUG [gce.imagemosai] - File found mosaic_335.tiff
2009-07-03 13:09:03,484 DEBUG [gce.imagemosai] - About to read image number 298
2009-07-03 13:09:03,484 DEBUG [gce.imagemosai] - File found mosaic_354.tiff
2009-07-03 13:09:03,494 DEBUG [gce.imagemosai] - About to read image number 299
2009-07-03 13:09:03,495 DEBUG [gce.imagemosai] - File found mosaic_355.tiff
2009-07-03 13:09:03,502 DEBUG [gce.imagemosai] - About to read image number 300
2009-07-03 13:09:03,503 DEBUG [gce.imagemosai] - File found mosaic_213.tiff
2009-07-03 13:09:03,515 DEBUG [gce.imagemosai] - About to read image number 301
2009-07-03 13:09:03,515 DEBUG [gce.imagemosai] - File found mosaic_214.tiff
2009-07-03 13:09:03,527 DEBUG [gce.imagemosai] - About to read image number 302
2009-07-03 13:09:03,527 DEBUG [gce.imagemosai] - File found mosaic_215.tiff
2009-07-03 13:09:03,535 DEBUG [gce.imagemosai] - About to read image number 303
2009-07-03 13:09:03,535 DEBUG [gce.imagemosai] - File found mosaic_234.tiff
2009-07-03 13:09:03,547 DEBUG [gce.imagemosai] - About to read image number 304
2009-07-03 13:09:03,547 DEBUG [gce.imagemosai] - File found mosaic_235.tiff
2009-07-03 13:09:03,556 DEBUG [gce.imagemosai] - About to read image number 305
2009-07-03 13:09:03,557 DEBUG [gce.imagemosai] - File found mosaic_236.tiff
2009-07-03 13:09:03,567 DEBUG [gce.imagemosai] - About to read image number 306
2009-07-03 13:09:03,567 DEBUG [gce.imagemosai] - File found mosaic_255.tiff
2009-07-03 13:09:03,581 DEBUG [gce.imagemosai] - About to read image number 307
2009-07-03 13:09:03,581 DEBUG [gce.imagemosai] - File found mosaic_256.tiff
2009-07-03 13:09:03,592 DEBUG [gce.imagemosai] - About to read image number 308
2009-07-03 13:09:03,593 DEBUG [gce.imagemosai] - File found mosaic_257.tiff
2009-07-03 13:09:03,606 DEBUG [gce.imagemosai] - About to read image number 309
2009-07-03 13:09:03,606 DEBUG [gce.imagemosai] - File found mosaic_276.tiff
2009-07-03 13:09:03,613 DEBUG [gce.imagemosai] - About to read image number 310
2009-07-03 13:09:03,613 DEBUG [gce.imagemosai] - File found mosaic_274.tiff
2009-07-03 13:09:03,623 DEBUG [gce.imagemosai] - About to read image number 311
2009-07-03 13:09:03,623 DEBUG [gce.imagemosai] - File found mosaic_275.tiff
2009-07-03 13:09:03,636 DEBUG [gce.imagemosai] - About to read image number 312
2009-07-03 13:09:03,636 DEBUG [gce.imagemosai] - File found mosaic_294.tiff
2009-07-03 13:09:03,646 DEBUG [gce.imagemosai] - About to read image number 313
2009-07-03 13:09:03,646 DEBUG [gce.imagemosai] - File found mosaic_295.tiff
2009-07-03 13:09:03,655 DEBUG [gce.imagemosai] - About to read image number 314
2009-07-03 13:09:03,656 DEBUG [gce.imagemosai] - File found mosaic_296.tiff
2009-07-03 13:09:03,665 DEBUG [gce.imagemosai] - About to read image number 315
2009-07-03 13:09:03,665 DEBUG [gce.imagemosai] - File found mosaic_315.tiff
2009-07-03 13:09:03,675 DEBUG [gce.imagemosai] - About to read image number 316
2009-07-03 13:09:03,675 DEBUG [gce.imagemosai] - File found mosaic_316.tiff
2009-07-03 13:09:03,681 DEBUG [gce.imagemosai] - About to read image number 317
2009-07-03 13:09:03,682 DEBUG [gce.imagemosai] - File found mosaic_317.tiff
2009-07-03 13:09:03,691 DEBUG [gce.imagemosai] - About to read image number 318
2009-07-03 13:09:03,692 DEBUG [gce.imagemosai] - File found mosaic_336.tiff
2009-07-03 13:09:03,702 DEBUG [gce.imagemosai] - About to read image number 319
2009-07-03 13:09:03,703 DEBUG [gce.imagemosai] - File found mosaic_337.tiff
2009-07-03 13:09:03,714 DEBUG [gce.imagemosai] - About to read image number 320
2009-07-03 13:09:03,714 DEBUG [gce.imagemosai] - File found mosaic_277.tiff
2009-07-03 13:09:03,723 DEBUG [gce.imagemosai] - About to read image number 321
2009-07-03 13:09:03,724 DEBUG [gce.imagemosai] - File found mosaic_278.tiff
2009-07-03 13:09:03,737 DEBUG [gce.imagemosai] - About to read image number 322
2009-07-03 13:09:03,738 DEBUG [gce.imagemosai] - File found mosaic_297.tiff
2009-07-03 13:09:03,748 DEBUG [gce.imagemosai] - About to read image number 323
2009-07-03 13:09:03,748 DEBUG [gce.imagemosai] - File found mosaic_298.tiff
2009-07-03 13:09:03,760 DEBUG [gce.imagemosai] - About to read image number 324
2009-07-03 13:09:03,760 DEBUG [gce.imagemosai] - File found mosaic_299.tiff
2009-07-03 13:09:03,772 DEBUG [gce.imagemosai] - About to read image number 325
2009-07-03 13:09:03,772 DEBUG [gce.imagemosai] - File found mosaic_318.tiff
2009-07-03 13:09:03,785 DEBUG [gce.imagemosai] - About to read image number 326
2009-07-03 13:09:03,786 DEBUG [gce.imagemosai] - File found mosaic_319.tiff
2009-07-03 13:09:03,797 DEBUG [gce.imagemosai] - About to read image number 327
2009-07-03 13:09:03,797 DEBUG [gce.imagemosai] - File found mosaic_320.tiff
2009-07-03 13:09:03,807 DEBUG [gce.imagemosai] - About to read image number 328
2009-07-03 13:09:03,808 DEBUG [gce.imagemosai] - File found mosaic_339.tiff
2009-07-03 13:09:03,815 DEBUG [gce.imagemosai] - About to read image number 329
2009-07-03 13:09:03,816 DEBUG [gce.imagemosai] - File found mosaic_340.tiff
2009-07-03 13:09:03,830 DEBUG [gce.imagemosai] - About to read image number 330
2009-07-03 13:09:03,831 DEBUG [gce.imagemosai] - File found mosaic_338.tiff
2009-07-03 13:09:03,839 DEBUG [gce.imagemosai] - About to read image number 331
2009-07-03 13:09:03,839 DEBUG [gce.imagemosai] - File found mosaic_357.tiff
2009-07-03 13:09:03,853 DEBUG [gce.imagemosai] - About to read image number 332
2009-07-03 13:09:03,853 DEBUG [gce.imagemosai] - File found mosaic_358.tiff
2009-07-03 13:09:03,863 DEBUG [gce.imagemosai] - About to read image number 333
2009-07-03 13:09:03,863 DEBUG [gce.imagemosai] - File found mosaic_359.tiff
2009-07-03 13:09:03,875 DEBUG [gce.imagemosai] - About to read image number 334
2009-07-03 13:09:03,876 DEBUG [gce.imagemosai] - File found mosaic_378.tiff
2009-07-03 13:09:03,889 DEBUG [gce.imagemosai] - About to read image number 335
2009-07-03 13:09:03,889 DEBUG [gce.imagemosai] - File found mosaic_379.tiff
2009-07-03 13:09:03,901 DEBUG [gce.imagemosai] - About to read image number 336
2009-07-03 13:09:03,901 DEBUG [gce.imagemosai] - File found mosaic_380.tiff
2009-07-03 13:09:03,917 DEBUG [gce.imagemosai] - About to read image number 337
2009-07-03 13:09:03,917 DEBUG [gce.imagemosai] - File found mosaic_399.tiff
2009-07-03 13:09:03,925 DEBUG [gce.imagemosai] - About to read image number 338
2009-07-03 13:09:03,926 DEBUG [gce.imagemosai] - File found mosaic_400.tiff
2009-07-03 13:09:03,940 DEBUG [gce.imagemosai] - About to read image number 339
2009-07-03 13:09:03,940 DEBUG [gce.imagemosai] - File found mosaic_401.tiff
2009-07-03 13:09:03,952 DEBUG [gce.imagemosai] - About to read image number 340
2009-07-03 13:09:03,952 DEBUG [gce.imagemosai] - File found mosaic_341.tiff
2009-07-03 13:09:03,963 DEBUG [gce.imagemosai] - About to read image number 341
2009-07-03 13:09:03,964 DEBUG [gce.imagemosai] - File found mosaic_360.tiff
2009-07-03 13:09:03,978 DEBUG [gce.imagemosai] - About to read image number 342
2009-07-03 13:09:03,979 DEBUG [gce.imagemosai] - File found mosaic_361.tiff
2009-07-03 13:09:03,987 DEBUG [gce.imagemosai] - About to read image number 343
2009-07-03 13:09:03,987 DEBUG [gce.imagemosai] - File found mosaic_362.tiff
2009-07-03 13:09:03,997 DEBUG [gce.imagemosai] - About to read image number 344
2009-07-03 13:09:03,998 DEBUG [gce.imagemosai] - File found mosaic_381.tiff
2009-07-03 13:09:04,007 DEBUG [gce.imagemosai] - About to read image number 345
2009-07-03 13:09:04,007 DEBUG [gce.imagemosai] - File found mosaic_382.tiff
2009-07-03 13:09:04,019 DEBUG [gce.imagemosai] - About to read image number 346
2009-07-03 13:09:04,019 DEBUG [gce.imagemosai] - File found mosaic_383.tiff
2009-07-03 13:09:04,027 DEBUG [gce.imagemosai] - About to read image number 347
2009-07-03 13:09:04,027 DEBUG [gce.imagemosai] - File found mosaic_402.tiff
2009-07-03 13:09:04,037 DEBUG [gce.imagemosai] - About to read image number 348
2009-07-03 13:09:04,037 DEBUG [gce.imagemosai] - File found mosaic_403.tiff
2009-07-03 13:09:04,047 DEBUG [gce.imagemosai] - About to read image number 349
2009-07-03 13:09:04,047 DEBUG [gce.imagemosai] - File found mosaic_404.tiff
2009-07-03 13:09:04,056 DEBUG [gce.imagemosai] - About to read image number 350
2009-07-03 13:09:04,056 DEBUG [gce.imagemosai] - File found mosaic_420.tiff
2009-07-03 13:09:04,064 DEBUG [gce.imagemosai] - About to read image number 351
2009-07-03 13:09:04,065 DEBUG [gce.imagemosai] - File found mosaic_421.tiff
2009-07-03 13:09:04,075 DEBUG [gce.imagemosai] - About to read image number 352
2009-07-03 13:09:04,075 DEBUG [gce.imagemosai] - File found mosaic_422.tiff
2009-07-03 13:09:04,084 DEBUG [gce.imagemosai] - About to read image number 353
2009-07-03 13:09:04,084 DEBUG [gce.imagemosai] - File found mosaic_423.tiff
2009-07-03 13:09:04,095 DEBUG [gce.imagemosai] - About to read image number 354
2009-07-03 13:09:04,095 DEBUG [gce.imagemosai] - File found mosaic_424.tiff
2009-07-03 13:09:04,109 DEBUG [gce.imagemosai] - About to read image number 355
2009-07-03 13:09:04,110 DEBUG [gce.imagemosai] - File found mosaic_425.tiff
2009-07-03 13:09:04,120 DEBUG [gce.imagemosai] - About to read image number 356
2009-07-03 13:09:04,121 DEBUG [gce.imagemosai] - File found mosaic_283.tiff
2009-07-03 13:09:04,136 DEBUG [gce.imagemosai] - About to read image number 357
2009-07-03 13:09:04,136 DEBUG [gce.imagemosai] - File found mosaic_284.tiff
2009-07-03 13:09:04,148 DEBUG [gce.imagemosai] - About to read image number 358
2009-07-03 13:09:04,149 DEBUG [gce.imagemosai] - File found mosaic_303.tiff
2009-07-03 13:09:04,161 DEBUG [gce.imagemosai] - About to read image number 359
2009-07-03 13:09:04,161 DEBUG [gce.imagemosai] - File found mosaic_304.tiff
2009-07-03 13:09:04,176 DEBUG [gce.imagemosai] - About to read image number 360
2009-07-03 13:09:04,176 DEBUG [gce.imagemosai] - File found mosaic_305.tiff
2009-07-03 13:09:04,185 DEBUG [gce.imagemosai] - About to read image number 361
2009-07-03 13:09:04,185 DEBUG [gce.imagemosai] - File found mosaic_324.tiff
2009-07-03 13:09:04,199 DEBUG [gce.imagemosai] - About to read image number 362
2009-07-03 13:09:04,200 DEBUG [gce.imagemosai] - File found mosaic_325.tiff
2009-07-03 13:09:04,215 DEBUG [gce.imagemosai] - About to read image number 363
2009-07-03 13:09:04,215 DEBUG [gce.imagemosai] - File found mosaic_326.tiff
2009-07-03 13:09:04,225 DEBUG [gce.imagemosai] - About to read image number 364
2009-07-03 13:09:04,225 DEBUG [gce.imagemosai] - File found mosaic_345.tiff
2009-07-03 13:09:04,241 DEBUG [gce.imagemosai] - About to read image number 365
2009-07-03 13:09:04,241 DEBUG [gce.imagemosai] - File found mosaic_346.tiff
2009-07-03 13:09:04,276 DEBUG [gce.imagemosai] - About to read image number 366
2009-07-03 13:09:04,277 DEBUG [gce.imagemosai] - File found mosaic_286.tiff
2009-07-03 13:09:04,286 DEBUG [gce.imagemosai] - About to read image number 367
2009-07-03 13:09:04,287 DEBUG [gce.imagemosai] - File found mosaic_287.tiff
2009-07-03 13:09:04,297 DEBUG [gce.imagemosai] - About to read image number 368
2009-07-03 13:09:04,298 DEBUG [gce.imagemosai] - File found mosaic_306.tiff
2009-07-03 13:09:04,309 DEBUG [gce.imagemosai] - About to read image number 369
2009-07-03 13:09:04,309 DEBUG [gce.imagemosai] - File found mosaic_307.tiff
2009-07-03 13:09:04,324 DEBUG [gce.imagemosai] - About to read image number 370
2009-07-03 13:09:04,324 DEBUG [gce.imagemosai] - File found mosaic_308.tiff
2009-07-03 13:09:04,334 DEBUG [gce.imagemosai] - About to read image number 371
2009-07-03 13:09:04,335 DEBUG [gce.imagemosai] - File found mosaic_327.tiff
2009-07-03 13:09:04,346 DEBUG [gce.imagemosai] - About to read image number 372
2009-07-03 13:09:04,346 DEBUG [gce.imagemosai] - File found mosaic_328.tiff
2009-07-03 13:09:04,358 DEBUG [gce.imagemosai] - About to read image number 373
2009-07-03 13:09:04,358 DEBUG [gce.imagemosai] - File found mosaic_329.tiff
2009-07-03 13:09:04,373 DEBUG [gce.imagemosai] - About to read image number 374
2009-07-03 13:09:04,374 DEBUG [gce.imagemosai] - File found mosaic_348.tiff
2009-07-03 13:09:04,387 DEBUG [gce.imagemosai] - About to read image number 375
2009-07-03 13:09:04,387 DEBUG [gce.imagemosai] - File found mosaic_349.tiff
2009-07-03 13:09:04,399 DEBUG [gce.imagemosai] - About to read image number 376
2009-07-03 13:09:04,399 DEBUG [gce.imagemosai] - File found mosaic_344.tiff
2009-07-03 13:09:04,409 DEBUG [gce.imagemosai] - About to read image number 377
2009-07-03 13:09:04,409 DEBUG [gce.imagemosai] - File found mosaic_363.tiff
2009-07-03 13:09:04,420 DEBUG [gce.imagemosai] - About to read image number 378
2009-07-03 13:09:04,420 DEBUG [gce.imagemosai] - File found mosaic_364.tiff
2009-07-03 13:09:04,429 DEBUG [gce.imagemosai] - About to read image number 379
2009-07-03 13:09:04,430 DEBUG [gce.imagemosai] - File found mosaic_365.tiff
2009-07-03 13:09:04,443 DEBUG [gce.imagemosai] - About to read image number 380
2009-07-03 13:09:04,443 DEBUG [gce.imagemosai] - File found mosaic_384.tiff
2009-07-03 13:09:04,454 DEBUG [gce.imagemosai] - About to read image number 381
2009-07-03 13:09:04,454 DEBUG [gce.imagemosai] - File found mosaic_385.tiff
2009-07-03 13:09:04,463 DEBUG [gce.imagemosai] - About to read image number 382
2009-07-03 13:09:04,464 DEBUG [gce.imagemosai] - File found mosaic_386.tiff
2009-07-03 13:09:04,474 DEBUG [gce.imagemosai] - About to read image number 383
2009-07-03 13:09:04,475 DEBUG [gce.imagemosai] - File found mosaic_405.tiff
2009-07-03 13:09:04,483 DEBUG [gce.imagemosai] - About to read image number 384
2009-07-03 13:09:04,483 DEBUG [gce.imagemosai] - File found mosaic_406.tiff
2009-07-03 13:09:04,494 DEBUG [gce.imagemosai] - About to read image number 385
2009-07-03 13:09:04,495 DEBUG [gce.imagemosai] - File found mosaic_407.tiff
2009-07-03 13:09:04,504 DEBUG [gce.imagemosai] - About to read image number 386
2009-07-03 13:09:04,504 DEBUG [gce.imagemosai] - File found mosaic_347.tiff
2009-07-03 13:09:04,518 DEBUG [gce.imagemosai] - About to read image number 387
2009-07-03 13:09:04,519 DEBUG [gce.imagemosai] - File found mosaic_366.tiff
2009-07-03 13:09:04,528 DEBUG [gce.imagemosai] - About to read image number 388
2009-07-03 13:09:04,529 DEBUG [gce.imagemosai] - File found mosaic_367.tiff
2009-07-03 13:09:04,544 DEBUG [gce.imagemosai] - About to read image number 389
2009-07-03 13:09:04,544 DEBUG [gce.imagemosai] - File found mosaic_368.tiff
2009-07-03 13:09:04,553 DEBUG [gce.imagemosai] - About to read image number 390
2009-07-03 13:09:04,554 DEBUG [gce.imagemosai] - File found mosaic_387.tiff
2009-07-03 13:09:04,567 DEBUG [gce.imagemosai] - About to read image number 391
2009-07-03 13:09:04,567 DEBUG [gce.imagemosai] - File found mosaic_388.tiff
2009-07-03 13:09:04,577 DEBUG [gce.imagemosai] - About to read image number 392
2009-07-03 13:09:04,578 DEBUG [gce.imagemosai] - File found mosaic_389.tiff
2009-07-03 13:09:04,589 DEBUG [gce.imagemosai] - About to read image number 393
2009-07-03 13:09:04,590 DEBUG [gce.imagemosai] - File found mosaic_408.tiff
2009-07-03 13:09:04,603 DEBUG [gce.imagemosai] - About to read image number 394
2009-07-03 13:09:04,603 DEBUG [gce.imagemosai] - File found mosaic_409.tiff
2009-07-03 13:09:04,615 DEBUG [gce.imagemosai] - About to read image number 395
2009-07-03 13:09:04,616 DEBUG [gce.imagemosai] - File found mosaic_410.tiff
2009-07-03 13:09:04,631 DEBUG [gce.imagemosai] - About to read image number 396
2009-07-03 13:09:04,631 DEBUG [gce.imagemosai] - File found mosaic_350.tiff
2009-07-03 13:09:04,645 DEBUG [gce.imagemosai] - About to read image number 397
2009-07-03 13:09:04,646 DEBUG [gce.imagemosai] - File found mosaic_369.tiff
2009-07-03 13:09:04,653 DEBUG [gce.imagemosai] - About to read image number 398
2009-07-03 13:09:04,654 DEBUG [gce.imagemosai] - File found mosaic_370.tiff
2009-07-03 13:09:04,667 DEBUG [gce.imagemosai] - About to read image number 399
2009-07-03 13:09:04,667 DEBUG [gce.imagemosai] - File found mosaic_371.tiff
2009-07-03 13:09:04,678 DEBUG [gce.imagemosai] - About to read image number 400
2009-07-03 13:09:04,678 DEBUG [gce.imagemosai] - File found mosaic_390.tiff
2009-07-03 13:09:04,686 DEBUG [gce.imagemosai] - About to read image number 401
2009-07-03 13:09:04,687 DEBUG [gce.imagemosai] - File found mosaic_391.tiff
2009-07-03 13:09:04,698 DEBUG [gce.imagemosai] - About to read image number 402
2009-07-03 13:09:04,698 DEBUG [gce.imagemosai] - File found mosaic_392.tiff
2009-07-03 13:09:04,712 DEBUG [gce.imagemosai] - About to read image number 403
2009-07-03 13:09:04,712 DEBUG [gce.imagemosai] - File found mosaic_411.tiff
2009-07-03 13:09:04,719 DEBUG [gce.imagemosai] - About to read image number 404
2009-07-03 13:09:04,720 DEBUG [gce.imagemosai] - File found mosaic_412.tiff
2009-07-03 13:09:04,730 DEBUG [gce.imagemosai] - About to read image number 405
2009-07-03 13:09:04,730 DEBUG [gce.imagemosai] - File found mosaic_413.tiff
2009-07-03 13:09:04,743 DEBUG [gce.imagemosai] - About to read image number 406
2009-07-03 13:09:04,744 DEBUG [gce.imagemosai] - File found mosaic_426.tiff
2009-07-03 13:09:04,753 DEBUG [gce.imagemosai] - About to read image number 407
2009-07-03 13:09:04,753 DEBUG [gce.imagemosai] - File found mosaic_427.tiff
2009-07-03 13:09:04,763 DEBUG [gce.imagemosai] - About to read image number 408
2009-07-03 13:09:04,764 DEBUG [gce.imagemosai] - File found mosaic_428.tiff
2009-07-03 13:09:04,776 DEBUG [gce.imagemosai] - About to read image number 409
2009-07-03 13:09:04,776 DEBUG [gce.imagemosai] - File found mosaic_429.tiff
2009-07-03 13:09:04,786 DEBUG [gce.imagemosai] - About to read image number 410
2009-07-03 13:09:04,787 DEBUG [gce.imagemosai] - File found mosaic_430.tiff
2009-07-03 13:09:04,795 DEBUG [gce.imagemosai] - About to read image number 411
2009-07-03 13:09:04,796 DEBUG [gce.imagemosai] - File found mosaic_431.tiff
2009-07-03 13:09:04,810 DEBUG [gce.imagemosai] - About to read image number 412
2009-07-03 13:09:04,810 DEBUG [gce.imagemosai] - File found mosaic_353.tiff
2009-07-03 13:09:04,823 DEBUG [gce.imagemosai] - About to read image number 413
2009-07-03 13:09:04,823 DEBUG [gce.imagemosai] - File found mosaic_372.tiff
2009-07-03 13:09:04,836 DEBUG [gce.imagemosai] - About to read image number 414
2009-07-03 13:09:04,836 DEBUG [gce.imagemosai] - File found mosaic_373.tiff
2009-07-03 13:09:04,846 DEBUG [gce.imagemosai] - About to read image number 415
2009-07-03 13:09:04,846 DEBUG [gce.imagemosai] - File found mosaic_374.tiff
2009-07-03 13:09:04,859 DEBUG [gce.imagemosai] - About to read image number 416
2009-07-03 13:09:04,860 DEBUG [gce.imagemosai] - File found mosaic_393.tiff
2009-07-03 13:09:04,873 DEBUG [gce.imagemosai] - About to read image number 417
2009-07-03 13:09:04,874 DEBUG [gce.imagemosai] - File found mosaic_394.tiff
2009-07-03 13:09:04,885 DEBUG [gce.imagemosai] - About to read image number 418
2009-07-03 13:09:04,886 DEBUG [gce.imagemosai] - File found mosaic_395.tiff
2009-07-03 13:09:04,895 DEBUG [gce.imagemosai] - About to read image number 419
2009-07-03 13:09:04,896 DEBUG [gce.imagemosai] - File found mosaic_414.tiff
2009-07-03 13:09:04,907 DEBUG [gce.imagemosai] - About to read image number 420
2009-07-03 13:09:04,908 DEBUG [gce.imagemosai] - File found mosaic_415.tiff
2009-07-03 13:09:04,930 DEBUG [gce.imagemosai] - About to read image number 421
2009-07-03 13:09:04,930 DEBUG [gce.imagemosai] - File found mosaic_416.tiff
2009-07-03 13:09:04,940 DEBUG [gce.imagemosai] - About to read image number 422
2009-07-03 13:09:04,940 DEBUG [gce.imagemosai] - File found mosaic_356.tiff
2009-07-03 13:09:04,950 DEBUG [gce.imagemosai] - About to read image number 423
2009-07-03 13:09:04,951 DEBUG [gce.imagemosai] - File found mosaic_375.tiff
2009-07-03 13:09:04,962 DEBUG [gce.imagemosai] - About to read image number 424
2009-07-03 13:09:04,963 DEBUG [gce.imagemosai] - File found mosaic_376.tiff
2009-07-03 13:09:04,971 DEBUG [gce.imagemosai] - About to read image number 425
2009-07-03 13:09:04,972 DEBUG [gce.imagemosai] - File found mosaic_377.tiff
2009-07-03 13:09:04,984 DEBUG [gce.imagemosai] - About to read image number 426
2009-07-03 13:09:04,984 DEBUG [gce.imagemosai] - File found mosaic_396.tiff
2009-07-03 13:09:04,993 DEBUG [gce.imagemosai] - About to read image number 427
2009-07-03 13:09:04,994 DEBUG [gce.imagemosai] - File found mosaic_397.tiff
2009-07-03 13:09:05,003 DEBUG [gce.imagemosai] - About to read image number 428
2009-07-03 13:09:05,003 DEBUG [gce.imagemosai] - File found mosaic_398.tiff
2009-07-03 13:09:05,041 DEBUG [gce.imagemosai] - About to read image number 429
2009-07-03 13:09:05,041 DEBUG [gce.imagemosai] - File found mosaic_417.tiff
2009-07-03 13:09:05,091 DEBUG [gce.imagemosai] - About to read image number 430
2009-07-03 13:09:05,091 DEBUG [gce.imagemosai] - File found mosaic_418.tiff
2009-07-03 13:09:05,118 DEBUG [gce.imagemosai] - About to read image number 431
2009-07-03 13:09:05,119 DEBUG [gce.imagemosai] - File found mosaic_419.tiff
2009-07-03 13:09:05,128 DEBUG [gce.imagemosai] - About to read image number 432
2009-07-03 13:09:05,128 DEBUG [gce.imagemosai] - File found mosaic_432.tiff
2009-07-03 13:09:05,147 DEBUG [gce.imagemosai] - About to read image number 433
2009-07-03 13:09:05,148 DEBUG [gce.imagemosai] - File found mosaic_433.tiff
2009-07-03 13:09:05,167 DEBUG [gce.imagemosai] - About to read image number 434
2009-07-03 13:09:05,168 DEBUG [gce.imagemosai] - File found mosaic_434.tiff
2009-07-03 13:09:05,178 DEBUG [gce.imagemosai] - About to read image number 435
2009-07-03 13:09:05,179 DEBUG [gce.imagemosai] - File found mosaic_435.tiff
2009-07-03 13:09:05,189 DEBUG [gce.imagemosai] - About to read image number 436
2009-07-03 13:09:05,190 DEBUG [gce.imagemosai] - File found mosaic_436.tiff
2009-07-03 13:09:05,199 DEBUG [gce.imagemosai] - About to read image number 437
2009-07-03 13:09:05,200 DEBUG [gce.imagemosai] - File found mosaic_437.tiff
2009-07-03 13:09:05,210 DEBUG [gce.imagemosai] - About to read image number 438
2009-07-03 13:09:05,210 DEBUG [gce.imagemosai] - File found mosaic_438.tiff
2009-07-03 13:09:05,220 DEBUG [gce.imagemosai] - About to read image number 439
2009-07-03 13:09:05,221 DEBUG [gce.imagemosai] - File found mosaic_439.tiff
2009-07-03 13:09:05,230 DEBUG [gce.imagemosai] - About to read image number 440
2009-07-03 13:09:05,230 DEBUG [gce.imagemosai] - File found mosaic_440.tiff
2009-07-03 13:09:05,253 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,257 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,495 DEBUG [gce.imagemosai] - Adding to mosaic image number 0
2009-07-03 13:09:05,498 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,499 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,501 DEBUG [gce.imagemosai] - Adding to mosaic image number 1
2009-07-03 13:09:05,502 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,503 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,505 DEBUG [gce.imagemosai] - Adding to mosaic image number 2
2009-07-03 13:09:05,506 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,507 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,509 DEBUG [gce.imagemosai] - Adding to mosaic image number 3
2009-07-03 13:09:05,510 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,511 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,513 DEBUG [gce.imagemosai] - Adding to mosaic image number 4
2009-07-03 13:09:05,514 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,515 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,517 DEBUG [gce.imagemosai] - Adding to mosaic image number 5
2009-07-03 13:09:05,518 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,519 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,521 DEBUG [gce.imagemosai] - Adding to mosaic image number 6
2009-07-03 13:09:05,522 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,523 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,525 DEBUG [gce.imagemosai] - Adding to mosaic image number 7
2009-07-03 13:09:05,526 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,527 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,529 DEBUG [gce.imagemosai] - Adding to mosaic image number 8
2009-07-03 13:09:05,530 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,531 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,533 DEBUG [gce.imagemosai] - Adding to mosaic image number 9
2009-07-03 13:09:05,534 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,535 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,537 DEBUG [gce.imagemosai] - Adding to mosaic image number 10
2009-07-03 13:09:05,538 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,538 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,542 DEBUG [gce.imagemosai] - Adding to mosaic image number 11
2009-07-03 13:09:05,543 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,543 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,545 DEBUG [gce.imagemosai] - Adding to mosaic image number 12
2009-07-03 13:09:05,546 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,547 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,549 DEBUG [gce.imagemosai] - Adding to mosaic image number 13
2009-07-03 13:09:05,550 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,551 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,553 DEBUG [gce.imagemosai] - Adding to mosaic image number 14
2009-07-03 13:09:05,554 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,555 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,557 DEBUG [gce.imagemosai] - Adding to mosaic image number 15
2009-07-03 13:09:05,558 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,559 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,561 DEBUG [gce.imagemosai] - Adding to mosaic image number 16
2009-07-03 13:09:05,562 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,562 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,564 DEBUG [gce.imagemosai] - Adding to mosaic image number 17
2009-07-03 13:09:05,565 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,566 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,568 DEBUG [gce.imagemosai] - Adding to mosaic image number 18
2009-07-03 13:09:05,569 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,570 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,572 DEBUG [gce.imagemosai] - Adding to mosaic image number 19
2009-07-03 13:09:05,573 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,574 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,576 DEBUG [gce.imagemosai] - Adding to mosaic image number 20
2009-07-03 13:09:05,577 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,578 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,580 DEBUG [gce.imagemosai] - Adding to mosaic image number 21
2009-07-03 13:09:05,581 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,582 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,584 DEBUG [gce.imagemosai] - Adding to mosaic image number 22
2009-07-03 13:09:05,584 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,585 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,586 DEBUG [gce.imagemosai] - Adding to mosaic image number 23
2009-07-03 13:09:05,587 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,588 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,590 DEBUG [gce.imagemosai] - Adding to mosaic image number 24
2009-07-03 13:09:05,591 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,592 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,594 DEBUG [gce.imagemosai] - Adding to mosaic image number 25
2009-07-03 13:09:05,595 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,596 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,598 DEBUG [gce.imagemosai] - Adding to mosaic image number 26
2009-07-03 13:09:05,599 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,600 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,602 DEBUG [gce.imagemosai] - Adding to mosaic image number 27
2009-07-03 13:09:05,603 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,604 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,606 DEBUG [gce.imagemosai] - Adding to mosaic image number 28
2009-07-03 13:09:05,607 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,608 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,609 DEBUG [gce.imagemosai] - Adding to mosaic image number 29
2009-07-03 13:09:05,610 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,611 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,613 DEBUG [gce.imagemosai] - Adding to mosaic image number 30
2009-07-03 13:09:05,615 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,616 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,618 DEBUG [gce.imagemosai] - Adding to mosaic image number 31
2009-07-03 13:09:05,619 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,620 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,622 DEBUG [gce.imagemosai] - Adding to mosaic image number 32
2009-07-03 13:09:05,623 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,624 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,625 DEBUG [gce.imagemosai] - Adding to mosaic image number 33
2009-07-03 13:09:05,639 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,640 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,642 DEBUG [gce.imagemosai] - Adding to mosaic image number 34
2009-07-03 13:09:05,644 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,644 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,646 DEBUG [gce.imagemosai] - Adding to mosaic image number 35
2009-07-03 13:09:05,647 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,648 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,650 DEBUG [gce.imagemosai] - Adding to mosaic image number 36
2009-07-03 13:09:05,651 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,652 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,654 DEBUG [gce.imagemosai] - Adding to mosaic image number 37
2009-07-03 13:09:05,655 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,656 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,659 DEBUG [gce.imagemosai] - Adding to mosaic image number 38
2009-07-03 13:09:05,660 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,661 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,662 DEBUG [gce.imagemosai] - Adding to mosaic image number 39
2009-07-03 13:09:05,663 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,664 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,666 DEBUG [gce.imagemosai] - Adding to mosaic image number 40
2009-07-03 13:09:05,667 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,667 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,669 DEBUG [gce.imagemosai] - Adding to mosaic image number 41
2009-07-03 13:09:05,670 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,671 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,673 DEBUG [gce.imagemosai] - Adding to mosaic image number 42
2009-07-03 13:09:05,674 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,675 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,677 DEBUG [gce.imagemosai] - Adding to mosaic image number 43
2009-07-03 13:09:05,678 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,679 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,680 DEBUG [gce.imagemosai] - Adding to mosaic image number 44
2009-07-03 13:09:05,681 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,682 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,684 DEBUG [gce.imagemosai] - Adding to mosaic image number 45
2009-07-03 13:09:05,685 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,686 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,688 DEBUG [gce.imagemosai] - Adding to mosaic image number 46
2009-07-03 13:09:05,690 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,690 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,692 DEBUG [gce.imagemosai] - Adding to mosaic image number 47
2009-07-03 13:09:05,693 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,694 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,696 DEBUG [gce.imagemosai] - Adding to mosaic image number 48
2009-07-03 13:09:05,697 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,698 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,700 DEBUG [gce.imagemosai] - Adding to mosaic image number 49
2009-07-03 13:09:05,701 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,702 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,703 DEBUG [gce.imagemosai] - Adding to mosaic image number 50
2009-07-03 13:09:05,704 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,705 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,707 DEBUG [gce.imagemosai] - Adding to mosaic image number 51
2009-07-03 13:09:05,708 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,709 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,710 DEBUG [gce.imagemosai] - Adding to mosaic image number 52
2009-07-03 13:09:05,711 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,712 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,713 DEBUG [gce.imagemosai] - Adding to mosaic image number 53
2009-07-03 13:09:05,714 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,715 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,717 DEBUG [gce.imagemosai] - Adding to mosaic image number 54
2009-07-03 13:09:05,718 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,719 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,721 DEBUG [gce.imagemosai] - Adding to mosaic image number 55
2009-07-03 13:09:05,722 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,723 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,725 DEBUG [gce.imagemosai] - Adding to mosaic image number 56
2009-07-03 13:09:05,725 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,726 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,728 DEBUG [gce.imagemosai] - Adding to mosaic image number 57
2009-07-03 13:09:05,729 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,730 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,732 DEBUG [gce.imagemosai] - Adding to mosaic image number 58
2009-07-03 13:09:05,733 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,734 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,736 DEBUG [gce.imagemosai] - Adding to mosaic image number 59
2009-07-03 13:09:05,737 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,738 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,740 DEBUG [gce.imagemosai] - Adding to mosaic image number 60
2009-07-03 13:09:05,740 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,741 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,743 DEBUG [gce.imagemosai] - Adding to mosaic image number 61
2009-07-03 13:09:05,744 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,745 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,747 DEBUG [gce.imagemosai] - Adding to mosaic image number 62
2009-07-03 13:09:05,748 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,749 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,751 DEBUG [gce.imagemosai] - Adding to mosaic image number 63
2009-07-03 13:09:05,751 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,751 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,753 DEBUG [gce.imagemosai] - Adding to mosaic image number 64
2009-07-03 13:09:05,754 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,755 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,757 DEBUG [gce.imagemosai] - Adding to mosaic image number 65
2009-07-03 13:09:05,758 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,759 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,760 DEBUG [gce.imagemosai] - Adding to mosaic image number 66
2009-07-03 13:09:05,761 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,762 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,764 DEBUG [gce.imagemosai] - Adding to mosaic image number 67
2009-07-03 13:09:05,765 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,766 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,768 DEBUG [gce.imagemosai] - Adding to mosaic image number 68
2009-07-03 13:09:05,769 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,770 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,772 DEBUG [gce.imagemosai] - Adding to mosaic image number 69
2009-07-03 13:09:05,773 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,774 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,776 DEBUG [gce.imagemosai] - Adding to mosaic image number 70
2009-07-03 13:09:05,776 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,777 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,779 DEBUG [gce.imagemosai] - Adding to mosaic image number 71
2009-07-03 13:09:05,780 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,781 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,783 DEBUG [gce.imagemosai] - Adding to mosaic image number 72
2009-07-03 13:09:05,784 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,785 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,787 DEBUG [gce.imagemosai] - Adding to mosaic image number 73
2009-07-03 13:09:05,787 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,789 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,790 DEBUG [gce.imagemosai] - Adding to mosaic image number 74
2009-07-03 13:09:05,791 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,792 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,793 DEBUG [gce.imagemosai] - Adding to mosaic image number 75
2009-07-03 13:09:05,794 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,795 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,797 DEBUG [gce.imagemosai] - Adding to mosaic image number 76
2009-07-03 13:09:05,797 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,798 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,800 DEBUG [gce.imagemosai] - Adding to mosaic image number 77
2009-07-03 13:09:05,801 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,802 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,804 DEBUG [gce.imagemosai] - Adding to mosaic image number 78
2009-07-03 13:09:05,805 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,806 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,807 DEBUG [gce.imagemosai] - Adding to mosaic image number 79
2009-07-03 13:09:05,808 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,809 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,811 DEBUG [gce.imagemosai] - Adding to mosaic image number 80
2009-07-03 13:09:05,812 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,813 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,814 DEBUG [gce.imagemosai] - Adding to mosaic image number 81
2009-07-03 13:09:05,815 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,816 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,818 DEBUG [gce.imagemosai] - Adding to mosaic image number 82
2009-07-03 13:09:05,819 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,820 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,822 DEBUG [gce.imagemosai] - Adding to mosaic image number 83
2009-07-03 13:09:05,822 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,823 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,825 DEBUG [gce.imagemosai] - Adding to mosaic image number 84
2009-07-03 13:09:05,826 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,827 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,829 DEBUG [gce.imagemosai] - Adding to mosaic image number 85
2009-07-03 13:09:05,830 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,831 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,833 DEBUG [gce.imagemosai] - Adding to mosaic image number 86
2009-07-03 13:09:05,834 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,834 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,836 DEBUG [gce.imagemosai] - Adding to mosaic image number 87
2009-07-03 13:09:05,837 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,838 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,840 DEBUG [gce.imagemosai] - Adding to mosaic image number 88
2009-07-03 13:09:05,841 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,842 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,846 DEBUG [gce.imagemosai] - Adding to mosaic image number 89
2009-07-03 13:09:05,848 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,849 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,851 DEBUG [gce.imagemosai] - Adding to mosaic image number 90
2009-07-03 13:09:05,851 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,854 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,856 DEBUG [gce.imagemosai] - Adding to mosaic image number 91
2009-07-03 13:09:05,857 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,858 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,860 DEBUG [gce.imagemosai] - Adding to mosaic image number 92
2009-07-03 13:09:05,861 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,862 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,863 DEBUG [gce.imagemosai] - Adding to mosaic image number 93
2009-07-03 13:09:05,864 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,865 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,867 DEBUG [gce.imagemosai] - Adding to mosaic image number 94
2009-07-03 13:09:05,868 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,869 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,871 DEBUG [gce.imagemosai] - Adding to mosaic image number 95
2009-07-03 13:09:05,872 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,873 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,875 DEBUG [gce.imagemosai] - Adding to mosaic image number 96
2009-07-03 13:09:05,875 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,875 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,877 DEBUG [gce.imagemosai] - Adding to mosaic image number 97
2009-07-03 13:09:05,878 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,879 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,881 DEBUG [gce.imagemosai] - Adding to mosaic image number 98
2009-07-03 13:09:05,882 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,882 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,884 DEBUG [gce.imagemosai] - Adding to mosaic image number 99
2009-07-03 13:09:05,885 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,886 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,904 DEBUG [gce.imagemosai] - Adding to mosaic image number 100
2009-07-03 13:09:05,905 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,906 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,908 DEBUG [gce.imagemosai] - Adding to mosaic image number 101
2009-07-03 13:09:05,909 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,910 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,912 DEBUG [gce.imagemosai] - Adding to mosaic image number 102
2009-07-03 13:09:05,912 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,913 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,915 DEBUG [gce.imagemosai] - Adding to mosaic image number 103
2009-07-03 13:09:05,916 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,917 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,918 DEBUG [gce.imagemosai] - Adding to mosaic image number 104
2009-07-03 13:09:05,919 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,920 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,922 DEBUG [gce.imagemosai] - Adding to mosaic image number 105
2009-07-03 13:09:05,923 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,924 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,925 DEBUG [gce.imagemosai] - Adding to mosaic image number 106
2009-07-03 13:09:05,926 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,927 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,929 DEBUG [gce.imagemosai] - Adding to mosaic image number 107
2009-07-03 13:09:05,930 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,931 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,933 DEBUG [gce.imagemosai] - Adding to mosaic image number 108
2009-07-03 13:09:05,933 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,934 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,936 DEBUG [gce.imagemosai] - Adding to mosaic image number 109
2009-07-03 13:09:05,937 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,938 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,940 DEBUG [gce.imagemosai] - Adding to mosaic image number 110
2009-07-03 13:09:05,940 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,941 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,943 DEBUG [gce.imagemosai] - Adding to mosaic image number 111
2009-07-03 13:09:05,944 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,945 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,947 DEBUG [gce.imagemosai] - Adding to mosaic image number 112
2009-07-03 13:09:05,947 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,948 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,950 DEBUG [gce.imagemosai] - Adding to mosaic image number 113
2009-07-03 13:09:05,951 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,952 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,954 DEBUG [gce.imagemosai] - Adding to mosaic image number 114
2009-07-03 13:09:05,954 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,955 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,957 DEBUG [gce.imagemosai] - Adding to mosaic image number 115
2009-07-03 13:09:05,958 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,958 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,960 DEBUG [gce.imagemosai] - Adding to mosaic image number 116
2009-07-03 13:09:05,961 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,962 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,963 DEBUG [gce.imagemosai] - Adding to mosaic image number 117
2009-07-03 13:09:05,964 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,965 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,967 DEBUG [gce.imagemosai] - Adding to mosaic image number 118
2009-07-03 13:09:05,968 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,969 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,970 DEBUG [gce.imagemosai] - Adding to mosaic image number 119
2009-07-03 13:09:05,971 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,972 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,974 DEBUG [gce.imagemosai] - Adding to mosaic image number 120
2009-07-03 13:09:05,975 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,975 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,977 DEBUG [gce.imagemosai] - Adding to mosaic image number 121
2009-07-03 13:09:05,978 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,979 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,981 DEBUG [gce.imagemosai] - Adding to mosaic image number 122
2009-07-03 13:09:05,981 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,982 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,984 DEBUG [gce.imagemosai] - Adding to mosaic image number 123
2009-07-03 13:09:05,985 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,986 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,988 DEBUG [gce.imagemosai] - Adding to mosaic image number 124
2009-07-03 13:09:05,989 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,990 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,992 DEBUG [gce.imagemosai] - Adding to mosaic image number 125
2009-07-03 13:09:05,992 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,993 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,995 DEBUG [gce.imagemosai] - Adding to mosaic image number 126
2009-07-03 13:09:05,996 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:05,997 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:05,998 DEBUG [gce.imagemosai] - Adding to mosaic image number 127
2009-07-03 13:09:05,999 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,000 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,001 DEBUG [gce.imagemosai] - Adding to mosaic image number 128
2009-07-03 13:09:06,002 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,003 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,005 DEBUG [gce.imagemosai] - Adding to mosaic image number 129
2009-07-03 13:09:06,005 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,006 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,008 DEBUG [gce.imagemosai] - Adding to mosaic image number 130
2009-07-03 13:09:06,009 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,010 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,012 DEBUG [gce.imagemosai] - Adding to mosaic image number 131
2009-07-03 13:09:06,012 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,013 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,015 DEBUG [gce.imagemosai] - Adding to mosaic image number 132
2009-07-03 13:09:06,016 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,017 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,018 DEBUG [gce.imagemosai] - Adding to mosaic image number 133
2009-07-03 13:09:06,019 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,020 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,022 DEBUG [gce.imagemosai] - Adding to mosaic image number 134
2009-07-03 13:09:06,022 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,023 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,025 DEBUG [gce.imagemosai] - Adding to mosaic image number 135
2009-07-03 13:09:06,026 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,027 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,029 DEBUG [gce.imagemosai] - Adding to mosaic image number 136
2009-07-03 13:09:06,029 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,030 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,032 DEBUG [gce.imagemosai] - Adding to mosaic image number 137
2009-07-03 13:09:06,033 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,034 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,036 DEBUG [gce.imagemosai] - Adding to mosaic image number 138
2009-07-03 13:09:06,036 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,037 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,039 DEBUG [gce.imagemosai] - Adding to mosaic image number 139
2009-07-03 13:09:06,040 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,041 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,041 DEBUG [gce.imagemosai] - Adding to mosaic image number 140
2009-07-03 13:09:06,042 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,043 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,045 DEBUG [gce.imagemosai] - Adding to mosaic image number 141
2009-07-03 13:09:06,046 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,047 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,048 DEBUG [gce.imagemosai] - Adding to mosaic image number 142
2009-07-03 13:09:06,049 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,050 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,052 DEBUG [gce.imagemosai] - Adding to mosaic image number 143
2009-07-03 13:09:06,052 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,053 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,055 DEBUG [gce.imagemosai] - Adding to mosaic image number 144
2009-07-03 13:09:06,056 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,057 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,059 DEBUG [gce.imagemosai] - Adding to mosaic image number 145
2009-07-03 13:09:06,059 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,060 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,062 DEBUG [gce.imagemosai] - Adding to mosaic image number 146
2009-07-03 13:09:06,063 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,064 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,065 DEBUG [gce.imagemosai] - Adding to mosaic image number 147
2009-07-03 13:09:06,066 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,067 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,069 DEBUG [gce.imagemosai] - Adding to mosaic image number 148
2009-07-03 13:09:06,069 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,070 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,072 DEBUG [gce.imagemosai] - Adding to mosaic image number 149
2009-07-03 13:09:06,073 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,074 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,076 DEBUG [gce.imagemosai] - Adding to mosaic image number 150
2009-07-03 13:09:06,076 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,077 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,079 DEBUG [gce.imagemosai] - Adding to mosaic image number 151
2009-07-03 13:09:06,080 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,081 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,082 DEBUG [gce.imagemosai] - Adding to mosaic image number 152
2009-07-03 13:09:06,083 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,083 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,085 DEBUG [gce.imagemosai] - Adding to mosaic image number 153
2009-07-03 13:09:06,086 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,087 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,089 DEBUG [gce.imagemosai] - Adding to mosaic image number 154
2009-07-03 13:09:06,090 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,091 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,092 DEBUG [gce.imagemosai] - Adding to mosaic image number 155
2009-07-03 13:09:06,093 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,094 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,096 DEBUG [gce.imagemosai] - Adding to mosaic image number 156
2009-07-03 13:09:06,096 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,097 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,099 DEBUG [gce.imagemosai] - Adding to mosaic image number 157
2009-07-03 13:09:06,100 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,101 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,102 DEBUG [gce.imagemosai] - Adding to mosaic image number 158
2009-07-03 13:09:06,103 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,104 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,106 DEBUG [gce.imagemosai] - Adding to mosaic image number 159
2009-07-03 13:09:06,106 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,107 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,109 DEBUG [gce.imagemosai] - Adding to mosaic image number 160
2009-07-03 13:09:06,110 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,111 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,112 DEBUG [gce.imagemosai] - Adding to mosaic image number 161
2009-07-03 13:09:06,113 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,114 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,116 DEBUG [gce.imagemosai] - Adding to mosaic image number 162
2009-07-03 13:09:06,117 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,117 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,119 DEBUG [gce.imagemosai] - Adding to mosaic image number 163
2009-07-03 13:09:06,120 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,121 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,123 DEBUG [gce.imagemosai] - Adding to mosaic image number 164
2009-07-03 13:09:06,123 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,124 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,125 DEBUG [gce.imagemosai] - Adding to mosaic image number 165
2009-07-03 13:09:06,126 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,127 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,142 DEBUG [gce.imagemosai] - Adding to mosaic image number 166
2009-07-03 13:09:06,143 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,144 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,145 DEBUG [gce.imagemosai] - Adding to mosaic image number 167
2009-07-03 13:09:06,146 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,147 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,149 DEBUG [gce.imagemosai] - Adding to mosaic image number 168
2009-07-03 13:09:06,150 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,151 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,153 DEBUG [gce.imagemosai] - Adding to mosaic image number 169
2009-07-03 13:09:06,153 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,154 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,156 DEBUG [gce.imagemosai] - Adding to mosaic image number 170
2009-07-03 13:09:06,157 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,158 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,159 DEBUG [gce.imagemosai] - Adding to mosaic image number 171
2009-07-03 13:09:06,160 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,161 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,163 DEBUG [gce.imagemosai] - Adding to mosaic image number 172
2009-07-03 13:09:06,163 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,164 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,166 DEBUG [gce.imagemosai] - Adding to mosaic image number 173
2009-07-03 13:09:06,166 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,166 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,168 DEBUG [gce.imagemosai] - Adding to mosaic image number 174
2009-07-03 13:09:06,169 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,170 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,172 DEBUG [gce.imagemosai] - Adding to mosaic image number 175
2009-07-03 13:09:06,173 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,174 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,176 DEBUG [gce.imagemosai] - Adding to mosaic image number 176
2009-07-03 13:09:06,177 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,178 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,180 DEBUG [gce.imagemosai] - Adding to mosaic image number 177
2009-07-03 13:09:06,181 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,182 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,184 DEBUG [gce.imagemosai] - Adding to mosaic image number 178
2009-07-03 13:09:06,185 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,186 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,188 DEBUG [gce.imagemosai] - Adding to mosaic image number 179
2009-07-03 13:09:06,188 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,189 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,191 DEBUG [gce.imagemosai] - Adding to mosaic image number 180
2009-07-03 13:09:06,192 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,193 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,195 DEBUG [gce.imagemosai] - Adding to mosaic image number 181
2009-07-03 13:09:06,196 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,197 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,199 DEBUG [gce.imagemosai] - Adding to mosaic image number 182
2009-07-03 13:09:06,199 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,200 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,202 DEBUG [gce.imagemosai] - Adding to mosaic image number 183
2009-07-03 13:09:06,203 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,204 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,205 DEBUG [gce.imagemosai] - Adding to mosaic image number 184
2009-07-03 13:09:06,206 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,207 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,208 DEBUG [gce.imagemosai] - Adding to mosaic image number 185
2009-07-03 13:09:06,210 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,211 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,213 DEBUG [gce.imagemosai] - Adding to mosaic image number 186
2009-07-03 13:09:06,214 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,215 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,216 DEBUG [gce.imagemosai] - Adding to mosaic image number 187
2009-07-03 13:09:06,217 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,218 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,220 DEBUG [gce.imagemosai] - Adding to mosaic image number 188
2009-07-03 13:09:06,221 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,222 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,224 DEBUG [gce.imagemosai] - Adding to mosaic image number 189
2009-07-03 13:09:06,225 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,226 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,227 DEBUG [gce.imagemosai] - Adding to mosaic image number 190
2009-07-03 13:09:06,228 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,229 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,231 DEBUG [gce.imagemosai] - Adding to mosaic image number 191
2009-07-03 13:09:06,231 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,232 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,234 DEBUG [gce.imagemosai] - Adding to mosaic image number 192
2009-07-03 13:09:06,235 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,236 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,237 DEBUG [gce.imagemosai] - Adding to mosaic image number 193
2009-07-03 13:09:06,238 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,239 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,241 DEBUG [gce.imagemosai] - Adding to mosaic image number 194
2009-07-03 13:09:06,241 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,242 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,244 DEBUG [gce.imagemosai] - Adding to mosaic image number 195
2009-07-03 13:09:06,245 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,246 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,247 DEBUG [gce.imagemosai] - Adding to mosaic image number 196
2009-07-03 13:09:06,248 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,249 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,250 DEBUG [gce.imagemosai] - Adding to mosaic image number 197
2009-07-03 13:09:06,250 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,251 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,253 DEBUG [gce.imagemosai] - Adding to mosaic image number 198
2009-07-03 13:09:06,254 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,255 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,256 DEBUG [gce.imagemosai] - Adding to mosaic image number 199
2009-07-03 13:09:06,257 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,258 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,259 DEBUG [gce.imagemosai] - Adding to mosaic image number 200
2009-07-03 13:09:06,260 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,261 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,263 DEBUG [gce.imagemosai] - Adding to mosaic image number 201
2009-07-03 13:09:06,264 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,264 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,266 DEBUG [gce.imagemosai] - Adding to mosaic image number 202
2009-07-03 13:09:06,267 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,268 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,269 DEBUG [gce.imagemosai] - Adding to mosaic image number 203
2009-07-03 13:09:06,270 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,271 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,273 DEBUG [gce.imagemosai] - Adding to mosaic image number 204
2009-07-03 13:09:06,273 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,274 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,276 DEBUG [gce.imagemosai] - Adding to mosaic image number 205
2009-07-03 13:09:06,277 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,278 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,279 DEBUG [gce.imagemosai] - Adding to mosaic image number 206
2009-07-03 13:09:06,280 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,281 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,283 DEBUG [gce.imagemosai] - Adding to mosaic image number 207
2009-07-03 13:09:06,283 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,284 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,286 DEBUG [gce.imagemosai] - Adding to mosaic image number 208
2009-07-03 13:09:06,287 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,288 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,289 DEBUG [gce.imagemosai] - Adding to mosaic image number 209
2009-07-03 13:09:06,290 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,291 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,292 DEBUG [gce.imagemosai] - Adding to mosaic image number 210
2009-07-03 13:09:06,292 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,293 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,295 DEBUG [gce.imagemosai] - Adding to mosaic image number 211
2009-07-03 13:09:06,296 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,297 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,298 DEBUG [gce.imagemosai] - Adding to mosaic image number 212
2009-07-03 13:09:06,299 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,300 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,301 DEBUG [gce.imagemosai] - Adding to mosaic image number 213
2009-07-03 13:09:06,302 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,303 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,305 DEBUG [gce.imagemosai] - Adding to mosaic image number 214
2009-07-03 13:09:06,305 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,306 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,308 DEBUG [gce.imagemosai] - Adding to mosaic image number 215
2009-07-03 13:09:06,309 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,310 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,312 DEBUG [gce.imagemosai] - Adding to mosaic image number 216
2009-07-03 13:09:06,312 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,313 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,315 DEBUG [gce.imagemosai] - Adding to mosaic image number 217
2009-07-03 13:09:06,316 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,317 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,318 DEBUG [gce.imagemosai] - Adding to mosaic image number 218
2009-07-03 13:09:06,319 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,320 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,322 DEBUG [gce.imagemosai] - Adding to mosaic image number 219
2009-07-03 13:09:06,322 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,323 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,325 DEBUG [gce.imagemosai] - Adding to mosaic image number 220
2009-07-03 13:09:06,326 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,327 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,329 DEBUG [gce.imagemosai] - Adding to mosaic image number 221
2009-07-03 13:09:06,329 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,330 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,332 DEBUG [gce.imagemosai] - Adding to mosaic image number 222
2009-07-03 13:09:06,332 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,332 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,334 DEBUG [gce.imagemosai] - Adding to mosaic image number 223
2009-07-03 13:09:06,335 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,336 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,337 DEBUG [gce.imagemosai] - Adding to mosaic image number 224
2009-07-03 13:09:06,338 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,339 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,341 DEBUG [gce.imagemosai] - Adding to mosaic image number 225
2009-07-03 13:09:06,341 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,342 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,344 DEBUG [gce.imagemosai] - Adding to mosaic image number 226
2009-07-03 13:09:06,345 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,346 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,347 DEBUG [gce.imagemosai] - Adding to mosaic image number 227
2009-07-03 13:09:06,350 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,351 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,352 DEBUG [gce.imagemosai] - Adding to mosaic image number 228
2009-07-03 13:09:06,353 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,354 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,356 DEBUG [gce.imagemosai] - Adding to mosaic image number 229
2009-07-03 13:09:06,357 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,358 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,359 DEBUG [gce.imagemosai] - Adding to mosaic image number 230
2009-07-03 13:09:06,360 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,361 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,363 DEBUG [gce.imagemosai] - Adding to mosaic image number 231
2009-07-03 13:09:06,363 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,364 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,377 DEBUG [gce.imagemosai] - Adding to mosaic image number 232
2009-07-03 13:09:06,379 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,380 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,381 DEBUG [gce.imagemosai] - Adding to mosaic image number 233
2009-07-03 13:09:06,382 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,383 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,385 DEBUG [gce.imagemosai] - Adding to mosaic image number 234
2009-07-03 13:09:06,385 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,386 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,388 DEBUG [gce.imagemosai] - Adding to mosaic image number 235
2009-07-03 13:09:06,389 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,390 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,392 DEBUG [gce.imagemosai] - Adding to mosaic image number 236
2009-07-03 13:09:06,392 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,393 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,395 DEBUG [gce.imagemosai] - Adding to mosaic image number 237
2009-07-03 13:09:06,396 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,397 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,398 DEBUG [gce.imagemosai] - Adding to mosaic image number 238
2009-07-03 13:09:06,399 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,400 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,402 DEBUG [gce.imagemosai] - Adding to mosaic image number 239
2009-07-03 13:09:06,402 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,403 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,405 DEBUG [gce.imagemosai] - Adding to mosaic image number 240
2009-07-03 13:09:06,406 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,407 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,408 DEBUG [gce.imagemosai] - Adding to mosaic image number 241
2009-07-03 13:09:06,409 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,410 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,412 DEBUG [gce.imagemosai] - Adding to mosaic image number 242
2009-07-03 13:09:06,412 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,413 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,415 DEBUG [gce.imagemosai] - Adding to mosaic image number 243
2009-07-03 13:09:06,415 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,416 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,417 DEBUG [gce.imagemosai] - Adding to mosaic image number 244
2009-07-03 13:09:06,418 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,419 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,421 DEBUG [gce.imagemosai] - Adding to mosaic image number 245
2009-07-03 13:09:06,421 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,422 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,424 DEBUG [gce.imagemosai] - Adding to mosaic image number 246
2009-07-03 13:09:06,424 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,425 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,427 DEBUG [gce.imagemosai] - Adding to mosaic image number 247
2009-07-03 13:09:06,428 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,429 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,431 DEBUG [gce.imagemosai] - Adding to mosaic image number 248
2009-07-03 13:09:06,432 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,433 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,434 DEBUG [gce.imagemosai] - Adding to mosaic image number 249
2009-07-03 13:09:06,435 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,436 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,438 DEBUG [gce.imagemosai] - Adding to mosaic image number 250
2009-07-03 13:09:06,439 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,440 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,442 DEBUG [gce.imagemosai] - Adding to mosaic image number 251
2009-07-03 13:09:06,442 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,443 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,445 DEBUG [gce.imagemosai] - Adding to mosaic image number 252
2009-07-03 13:09:06,445 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,446 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,448 DEBUG [gce.imagemosai] - Adding to mosaic image number 253
2009-07-03 13:09:06,449 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,450 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,451 DEBUG [gce.imagemosai] - Adding to mosaic image number 254
2009-07-03 13:09:06,452 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,453 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,455 DEBUG [gce.imagemosai] - Adding to mosaic image number 255
2009-07-03 13:09:06,455 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,456 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,457 DEBUG [gce.imagemosai] - Adding to mosaic image number 256
2009-07-03 13:09:06,457 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,458 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,460 DEBUG [gce.imagemosai] - Adding to mosaic image number 257
2009-07-03 13:09:06,460 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,461 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,463 DEBUG [gce.imagemosai] - Adding to mosaic image number 258
2009-07-03 13:09:06,464 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,465 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,466 DEBUG [gce.imagemosai] - Adding to mosaic image number 259
2009-07-03 13:09:06,467 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,468 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,470 DEBUG [gce.imagemosai] - Adding to mosaic image number 260
2009-07-03 13:09:06,470 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,471 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,473 DEBUG [gce.imagemosai] - Adding to mosaic image number 261
2009-07-03 13:09:06,474 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,474 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,476 DEBUG [gce.imagemosai] - Adding to mosaic image number 262
2009-07-03 13:09:06,477 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,478 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,479 DEBUG [gce.imagemosai] - Adding to mosaic image number 263
2009-07-03 13:09:06,480 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,481 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,483 DEBUG [gce.imagemosai] - Adding to mosaic image number 264
2009-07-03 13:09:06,483 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,484 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,486 DEBUG [gce.imagemosai] - Adding to mosaic image number 265
2009-07-03 13:09:06,487 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,487 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,489 DEBUG [gce.imagemosai] - Adding to mosaic image number 266
2009-07-03 13:09:06,490 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,491 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,492 DEBUG [gce.imagemosai] - Adding to mosaic image number 267
2009-07-03 13:09:06,493 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,494 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,495 DEBUG [gce.imagemosai] - Adding to mosaic image number 268
2009-07-03 13:09:06,496 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,497 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,498 DEBUG [gce.imagemosai] - Adding to mosaic image number 269
2009-07-03 13:09:06,498 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,499 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,501 DEBUG [gce.imagemosai] - Adding to mosaic image number 270
2009-07-03 13:09:06,502 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,502 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,504 DEBUG [gce.imagemosai] - Adding to mosaic image number 271
2009-07-03 13:09:06,505 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,506 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,507 DEBUG [gce.imagemosai] - Adding to mosaic image number 272
2009-07-03 13:09:06,508 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,509 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,511 DEBUG [gce.imagemosai] - Adding to mosaic image number 273
2009-07-03 13:09:06,511 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,512 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,514 DEBUG [gce.imagemosai] - Adding to mosaic image number 274
2009-07-03 13:09:06,514 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,515 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,517 DEBUG [gce.imagemosai] - Adding to mosaic image number 275
2009-07-03 13:09:06,518 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,519 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,520 DEBUG [gce.imagemosai] - Adding to mosaic image number 276
2009-07-03 13:09:06,521 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,522 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,524 DEBUG [gce.imagemosai] - Adding to mosaic image number 277
2009-07-03 13:09:06,524 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,525 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,527 DEBUG [gce.imagemosai] - Adding to mosaic image number 278
2009-07-03 13:09:06,527 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,528 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,530 DEBUG [gce.imagemosai] - Adding to mosaic image number 279
2009-07-03 13:09:06,531 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,531 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,533 DEBUG [gce.imagemosai] - Adding to mosaic image number 280
2009-07-03 13:09:06,534 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,535 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,536 DEBUG [gce.imagemosai] - Adding to mosaic image number 281
2009-07-03 13:09:06,537 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,538 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,540 DEBUG [gce.imagemosai] - Adding to mosaic image number 282
2009-07-03 13:09:06,540 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,540 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,542 DEBUG [gce.imagemosai] - Adding to mosaic image number 283
2009-07-03 13:09:06,543 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,544 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,546 DEBUG [gce.imagemosai] - Adding to mosaic image number 284
2009-07-03 13:09:06,546 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,547 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,549 DEBUG [gce.imagemosai] - Adding to mosaic image number 285
2009-07-03 13:09:06,550 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,551 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,552 DEBUG [gce.imagemosai] - Adding to mosaic image number 286
2009-07-03 13:09:06,553 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,554 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,555 DEBUG [gce.imagemosai] - Adding to mosaic image number 287
2009-07-03 13:09:06,556 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,557 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,559 DEBUG [gce.imagemosai] - Adding to mosaic image number 288
2009-07-03 13:09:06,559 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,560 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,562 DEBUG [gce.imagemosai] - Adding to mosaic image number 289
2009-07-03 13:09:06,563 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,563 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,565 DEBUG [gce.imagemosai] - Adding to mosaic image number 290
2009-07-03 13:09:06,566 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,567 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,568 DEBUG [gce.imagemosai] - Adding to mosaic image number 291
2009-07-03 13:09:06,569 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,570 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,572 DEBUG [gce.imagemosai] - Adding to mosaic image number 292
2009-07-03 13:09:06,572 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,573 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,575 DEBUG [gce.imagemosai] - Adding to mosaic image number 293
2009-07-03 13:09:06,575 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,576 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,578 DEBUG [gce.imagemosai] - Adding to mosaic image number 294
2009-07-03 13:09:06,579 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,580 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,581 DEBUG [gce.imagemosai] - Adding to mosaic image number 295
2009-07-03 13:09:06,582 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,582 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,583 DEBUG [gce.imagemosai] - Adding to mosaic image number 296
2009-07-03 13:09:06,584 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,585 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,587 DEBUG [gce.imagemosai] - Adding to mosaic image number 297
2009-07-03 13:09:06,588 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,589 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,590 DEBUG [gce.imagemosai] - Adding to mosaic image number 298
2009-07-03 13:09:06,608 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,609 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,611 DEBUG [gce.imagemosai] - Adding to mosaic image number 299
2009-07-03 13:09:06,612 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,613 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,615 DEBUG [gce.imagemosai] - Adding to mosaic image number 300
2009-07-03 13:09:06,616 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,617 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,619 DEBUG [gce.imagemosai] - Adding to mosaic image number 301
2009-07-03 13:09:06,619 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,620 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,622 DEBUG [gce.imagemosai] - Adding to mosaic image number 302
2009-07-03 13:09:06,622 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,623 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,624 DEBUG [gce.imagemosai] - Adding to mosaic image number 303
2009-07-03 13:09:06,625 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,626 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,627 DEBUG [gce.imagemosai] - Adding to mosaic image number 304
2009-07-03 13:09:06,628 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,629 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,631 DEBUG [gce.imagemosai] - Adding to mosaic image number 305
2009-07-03 13:09:06,631 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,632 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,634 DEBUG [gce.imagemosai] - Adding to mosaic image number 306
2009-07-03 13:09:06,634 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,635 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,637 DEBUG [gce.imagemosai] - Adding to mosaic image number 307
2009-07-03 13:09:06,638 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,638 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,640 DEBUG [gce.imagemosai] - Adding to mosaic image number 308
2009-07-03 13:09:06,641 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,642 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,643 DEBUG [gce.imagemosai] - Adding to mosaic image number 309
2009-07-03 13:09:06,644 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,645 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,646 DEBUG [gce.imagemosai] - Adding to mosaic image number 310
2009-07-03 13:09:06,647 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,648 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,650 DEBUG [gce.imagemosai] - Adding to mosaic image number 311
2009-07-03 13:09:06,650 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,651 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,653 DEBUG [gce.imagemosai] - Adding to mosaic image number 312
2009-07-03 13:09:06,654 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,655 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,656 DEBUG [gce.imagemosai] - Adding to mosaic image number 313
2009-07-03 13:09:06,657 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,658 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,659 DEBUG [gce.imagemosai] - Adding to mosaic image number 314
2009-07-03 13:09:06,660 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,661 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,663 DEBUG [gce.imagemosai] - Adding to mosaic image number 315
2009-07-03 13:09:06,663 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,664 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,665 DEBUG [gce.imagemosai] - Adding to mosaic image number 316
2009-07-03 13:09:06,666 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,667 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,668 DEBUG [gce.imagemosai] - Adding to mosaic image number 317
2009-07-03 13:09:06,669 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,670 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,672 DEBUG [gce.imagemosai] - Adding to mosaic image number 318
2009-07-03 13:09:06,672 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,673 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,675 DEBUG [gce.imagemosai] - Adding to mosaic image number 319
2009-07-03 13:09:06,675 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,676 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,678 DEBUG [gce.imagemosai] - Adding to mosaic image number 320
2009-07-03 13:09:06,679 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,680 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,681 DEBUG [gce.imagemosai] - Adding to mosaic image number 321
2009-07-03 13:09:06,682 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,683 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,685 DEBUG [gce.imagemosai] - Adding to mosaic image number 322
2009-07-03 13:09:06,685 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,686 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,688 DEBUG [gce.imagemosai] - Adding to mosaic image number 323
2009-07-03 13:09:06,688 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,689 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,691 DEBUG [gce.imagemosai] - Adding to mosaic image number 324
2009-07-03 13:09:06,692 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,693 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,694 DEBUG [gce.imagemosai] - Adding to mosaic image number 325
2009-07-03 13:09:06,695 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,696 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,697 DEBUG [gce.imagemosai] - Adding to mosaic image number 326
2009-07-03 13:09:06,698 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,699 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,701 DEBUG [gce.imagemosai] - Adding to mosaic image number 327
2009-07-03 13:09:06,702 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,703 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,704 DEBUG [gce.imagemosai] - Adding to mosaic image number 328
2009-07-03 13:09:06,705 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,706 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,707 DEBUG [gce.imagemosai] - Adding to mosaic image number 329
2009-07-03 13:09:06,707 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,708 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,710 DEBUG [gce.imagemosai] - Adding to mosaic image number 330
2009-07-03 13:09:06,710 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,711 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,713 DEBUG [gce.imagemosai] - Adding to mosaic image number 331
2009-07-03 13:09:06,714 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,715 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,717 DEBUG [gce.imagemosai] - Adding to mosaic image number 332
2009-07-03 13:09:06,717 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,718 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,720 DEBUG [gce.imagemosai] - Adding to mosaic image number 333
2009-07-03 13:09:06,721 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,721 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,723 DEBUG [gce.imagemosai] - Adding to mosaic image number 334
2009-07-03 13:09:06,724 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,725 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,726 DEBUG [gce.imagemosai] - Adding to mosaic image number 335
2009-07-03 13:09:06,727 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,728 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,730 DEBUG [gce.imagemosai] - Adding to mosaic image number 336
2009-07-03 13:09:06,730 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,731 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,733 DEBUG [gce.imagemosai] - Adding to mosaic image number 337
2009-07-03 13:09:06,733 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,734 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,736 DEBUG [gce.imagemosai] - Adding to mosaic image number 338
2009-07-03 13:09:06,737 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,738 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,740 DEBUG [gce.imagemosai] - Adding to mosaic image number 339
2009-07-03 13:09:06,740 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,741 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,743 DEBUG [gce.imagemosai] - Adding to mosaic image number 340
2009-07-03 13:09:06,743 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,744 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,746 DEBUG [gce.imagemosai] - Adding to mosaic image number 341
2009-07-03 13:09:06,747 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,748 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,748 DEBUG [gce.imagemosai] - Adding to mosaic image number 342
2009-07-03 13:09:06,749 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,750 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,752 DEBUG [gce.imagemosai] - Adding to mosaic image number 343
2009-07-03 13:09:06,752 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,753 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,755 DEBUG [gce.imagemosai] - Adding to mosaic image number 344
2009-07-03 13:09:06,755 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,756 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,758 DEBUG [gce.imagemosai] - Adding to mosaic image number 345
2009-07-03 13:09:06,759 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,760 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,761 DEBUG [gce.imagemosai] - Adding to mosaic image number 346
2009-07-03 13:09:06,762 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,763 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,765 DEBUG [gce.imagemosai] - Adding to mosaic image number 347
2009-07-03 13:09:06,765 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,766 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,768 DEBUG [gce.imagemosai] - Adding to mosaic image number 348
2009-07-03 13:09:06,768 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,769 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,771 DEBUG [gce.imagemosai] - Adding to mosaic image number 349
2009-07-03 13:09:06,772 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,773 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,775 DEBUG [gce.imagemosai] - Adding to mosaic image number 350
2009-07-03 13:09:06,775 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,776 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,778 DEBUG [gce.imagemosai] - Adding to mosaic image number 351
2009-07-03 13:09:06,779 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,780 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,783 DEBUG [gce.imagemosai] - Adding to mosaic image number 352
2009-07-03 13:09:06,784 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,785 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,787 DEBUG [gce.imagemosai] - Adding to mosaic image number 353
2009-07-03 13:09:06,788 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,789 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,790 DEBUG [gce.imagemosai] - Adding to mosaic image number 354
2009-07-03 13:09:06,791 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,792 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,793 DEBUG [gce.imagemosai] - Adding to mosaic image number 355
2009-07-03 13:09:06,794 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,795 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,797 DEBUG [gce.imagemosai] - Adding to mosaic image number 356
2009-07-03 13:09:06,797 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,798 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,800 DEBUG [gce.imagemosai] - Adding to mosaic image number 357
2009-07-03 13:09:06,801 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,801 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,803 DEBUG [gce.imagemosai] - Adding to mosaic image number 358
2009-07-03 13:09:06,804 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,805 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,806 DEBUG [gce.imagemosai] - Adding to mosaic image number 359
2009-07-03 13:09:06,807 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,808 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,809 DEBUG [gce.imagemosai] - Adding to mosaic image number 360
2009-07-03 13:09:06,810 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,811 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,813 DEBUG [gce.imagemosai] - Adding to mosaic image number 361
2009-07-03 13:09:06,813 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,814 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,816 DEBUG [gce.imagemosai] - Adding to mosaic image number 362
2009-07-03 13:09:06,816 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,818 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,820 DEBUG [gce.imagemosai] - Adding to mosaic image number 363
2009-07-03 13:09:06,820 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:06,821 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:06,823 DEBUG [gce.imagemosai] - Adding to mosaic image number 364
2009-07-03 13:09:06,824 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,131 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,132 DEBUG [gce.imagemosai] - Adding to mosaic image number 365
2009-07-03 13:09:07,133 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,134 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,136 DEBUG [gce.imagemosai] - Adding to mosaic image number 366
2009-07-03 13:09:07,136 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,137 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,139 DEBUG [gce.imagemosai] - Adding to mosaic image number 367
2009-07-03 13:09:07,140 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,141 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,142 DEBUG [gce.imagemosai] - Adding to mosaic image number 368
2009-07-03 13:09:07,143 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,144 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,145 DEBUG [gce.imagemosai] - Adding to mosaic image number 369
2009-07-03 13:09:07,146 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,147 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,148 DEBUG [gce.imagemosai] - Adding to mosaic image number 370
2009-07-03 13:09:07,149 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,150 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,152 DEBUG [gce.imagemosai] - Adding to mosaic image number 371
2009-07-03 13:09:07,152 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,153 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,155 DEBUG [gce.imagemosai] - Adding to mosaic image number 372
2009-07-03 13:09:07,156 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,157 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,159 DEBUG [gce.imagemosai] - Adding to mosaic image number 373
2009-07-03 13:09:07,160 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,161 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,162 DEBUG [gce.imagemosai] - Adding to mosaic image number 374
2009-07-03 13:09:07,163 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,163 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,165 DEBUG [gce.imagemosai] - Adding to mosaic image number 375
2009-07-03 13:09:07,165 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,166 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,168 DEBUG [gce.imagemosai] - Adding to mosaic image number 376
2009-07-03 13:09:07,169 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,170 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,171 DEBUG [gce.imagemosai] - Adding to mosaic image number 377
2009-07-03 13:09:07,172 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,174 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,176 DEBUG [gce.imagemosai] - Adding to mosaic image number 378
2009-07-03 13:09:07,177 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,178 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,179 DEBUG [gce.imagemosai] - Adding to mosaic image number 379
2009-07-03 13:09:07,180 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,181 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,183 DEBUG [gce.imagemosai] - Adding to mosaic image number 380
2009-07-03 13:09:07,183 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,184 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,186 DEBUG [gce.imagemosai] - Adding to mosaic image number 381
2009-07-03 13:09:07,186 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,187 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,189 DEBUG [gce.imagemosai] - Adding to mosaic image number 382
2009-07-03 13:09:07,189 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,190 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,192 DEBUG [gce.imagemosai] - Adding to mosaic image number 383
2009-07-03 13:09:07,193 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,193 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,195 DEBUG [gce.imagemosai] - Adding to mosaic image number 384
2009-07-03 13:09:07,196 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,196 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,198 DEBUG [gce.imagemosai] - Adding to mosaic image number 385
2009-07-03 13:09:07,199 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,200 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,201 DEBUG [gce.imagemosai] - Adding to mosaic image number 386
2009-07-03 13:09:07,202 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,203 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,204 DEBUG [gce.imagemosai] - Adding to mosaic image number 387
2009-07-03 13:09:07,205 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,205 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,206 DEBUG [gce.imagemosai] - Adding to mosaic image number 388
2009-07-03 13:09:07,207 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,208 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,209 DEBUG [gce.imagemosai] - Adding to mosaic image number 389
2009-07-03 13:09:07,210 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,211 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,212 DEBUG [gce.imagemosai] - Adding to mosaic image number 390
2009-07-03 13:09:07,213 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,214 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,216 DEBUG [gce.imagemosai] - Adding to mosaic image number 391
2009-07-03 13:09:07,216 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,217 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,219 DEBUG [gce.imagemosai] - Adding to mosaic image number 392
2009-07-03 13:09:07,220 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,220 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,222 DEBUG [gce.imagemosai] - Adding to mosaic image number 393
2009-07-03 13:09:07,223 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,224 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,225 DEBUG [gce.imagemosai] - Adding to mosaic image number 394
2009-07-03 13:09:07,226 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,227 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,229 DEBUG [gce.imagemosai] - Adding to mosaic image number 395
2009-07-03 13:09:07,229 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,230 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,232 DEBUG [gce.imagemosai] - Adding to mosaic image number 396
2009-07-03 13:09:07,232 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,233 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,235 DEBUG [gce.imagemosai] - Adding to mosaic image number 397
2009-07-03 13:09:07,235 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,236 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,238 DEBUG [gce.imagemosai] - Adding to mosaic image number 398
2009-07-03 13:09:07,239 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,239 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,241 DEBUG [gce.imagemosai] - Adding to mosaic image number 399
2009-07-03 13:09:07,242 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,242 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,244 DEBUG [gce.imagemosai] - Adding to mosaic image number 400
2009-07-03 13:09:07,245 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,246 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,246 DEBUG [gce.imagemosai] - Adding to mosaic image number 401
2009-07-03 13:09:07,247 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,248 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,250 DEBUG [gce.imagemosai] - Adding to mosaic image number 402
2009-07-03 13:09:07,250 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,251 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,253 DEBUG [gce.imagemosai] - Adding to mosaic image number 403
2009-07-03 13:09:07,253 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,254 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,256 DEBUG [gce.imagemosai] - Adding to mosaic image number 404
2009-07-03 13:09:07,256 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,257 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,259 DEBUG [gce.imagemosai] - Adding to mosaic image number 405
2009-07-03 13:09:07,260 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,261 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,262 DEBUG [gce.imagemosai] - Adding to mosaic image number 406
2009-07-03 13:09:07,264 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,264 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,266 DEBUG [gce.imagemosai] - Adding to mosaic image number 407
2009-07-03 13:09:07,267 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,268 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,269 DEBUG [gce.imagemosai] - Adding to mosaic image number 408
2009-07-03 13:09:07,270 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,271 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,272 DEBUG [gce.imagemosai] - Adding to mosaic image number 409
2009-07-03 13:09:07,273 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,274 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,276 DEBUG [gce.imagemosai] - Adding to mosaic image number 410
2009-07-03 13:09:07,276 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,277 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,279 DEBUG [gce.imagemosai] - Adding to mosaic image number 411
2009-07-03 13:09:07,279 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,280 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,282 DEBUG [gce.imagemosai] - Adding to mosaic image number 412
2009-07-03 13:09:07,282 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,283 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,285 DEBUG [gce.imagemosai] - Adding to mosaic image number 413
2009-07-03 13:09:07,285 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,286 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,288 DEBUG [gce.imagemosai] - Adding to mosaic image number 414
2009-07-03 13:09:07,288 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,288 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,290 DEBUG [gce.imagemosai] - Adding to mosaic image number 415
2009-07-03 13:09:07,291 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,291 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,293 DEBUG [gce.imagemosai] - Adding to mosaic image number 416
2009-07-03 13:09:07,294 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,295 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,296 DEBUG [gce.imagemosai] - Adding to mosaic image number 417
2009-07-03 13:09:07,297 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,298 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,299 DEBUG [gce.imagemosai] - Adding to mosaic image number 418
2009-07-03 13:09:07,300 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,301 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,302 DEBUG [gce.imagemosai] - Adding to mosaic image number 419
2009-07-03 13:09:07,303 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,304 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,306 DEBUG [gce.imagemosai] - Adding to mosaic image number 420
2009-07-03 13:09:07,306 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,307 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,309 DEBUG [gce.imagemosai] - Adding to mosaic image number 421
2009-07-03 13:09:07,309 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,310 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,312 DEBUG [gce.imagemosai] - Adding to mosaic image number 422
2009-07-03 13:09:07,312 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,313 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,315 DEBUG [gce.imagemosai] - Adding to mosaic image number 423
2009-07-03 13:09:07,315 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,316 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,318 DEBUG [gce.imagemosai] - Adding to mosaic image number 424
2009-07-03 13:09:07,319 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,319 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,321 DEBUG [gce.imagemosai] - Adding to mosaic image number 425
2009-07-03 13:09:07,322 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,323 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,324 DEBUG [gce.imagemosai] - Adding to mosaic image number 426
2009-07-03 13:09:07,325 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,326 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,327 DEBUG [gce.imagemosai] - Adding to mosaic image number 427
2009-07-03 13:09:07,328 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,329 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,330 DEBUG [gce.imagemosai] - Adding to mosaic image number 428
2009-07-03 13:09:07,330 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,331 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,332 DEBUG [gce.imagemosai] - Adding to mosaic image number 429
2009-07-03 13:09:07,333 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,334 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,335 DEBUG [gce.imagemosai] - Adding to mosaic image number 430
2009-07-03 13:09:07,336 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,337 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,339 DEBUG [gce.imagemosai] - Adding to mosaic image number 431
2009-07-03 13:09:07,351 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,352 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,354 DEBUG [gce.imagemosai] - Adding to mosaic image number 432
2009-07-03 13:09:07,355 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,356 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,357 DEBUG [gce.imagemosai] - Adding to mosaic image number 433
2009-07-03 13:09:07,358 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,359 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,360 DEBUG [gce.imagemosai] - Adding to mosaic image number 434
2009-07-03 13:09:07,361 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,362 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,364 DEBUG [gce.imagemosai] - Adding to mosaic image number 435
2009-07-03 13:09:07,364 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,365 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,367 DEBUG [gce.imagemosai] - Adding to mosaic image number 436
2009-07-03 13:09:07,367 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,368 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,370 DEBUG [gce.imagemosai] - Adding to mosaic image number 437
2009-07-03 13:09:07,370 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,371 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,372 DEBUG [gce.imagemosai] - Adding to mosaic image number 438
2009-07-03 13:09:07,373 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,374 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,375 DEBUG [gce.imagemosai] - Adding to mosaic image number 439
2009-07-03 13:09:07,376 DEBUG [gce.imagemosai] - Loading raster data for granule org.geotools.gce.imagemosaic.Granule@anonymised.com
2009-07-03 13:09:07,377 DEBUG [gce.imagemosai] - Loading level 0 with source region java.awt.Rectangle[x=0,y=0,width=1028,height=1028]
2009-07-03 13:09:07,379 DEBUG [gce.imagemosai] - Adding to mosaic image number 440
2009-07-03 13:09:07,379 DEBUG [gce.imagemosai] - Loaded bbox ReferencedEnvelope[-180.0 : -90.00208449138555, -89.997915508613 : 1.4352963262354024E-12] while crop bbox ReferencedEnvelope[-180.0 : -90.00208449138555, -89.997915508613 : 1.4352963262354024E-12]
2009-07-03 13:09:07,381 DEBUG [gce.imagemosai] - Mosaic created
2009-07-03 13:09:14,743 DEBUG [referencing.factory] - Failure in the primary factory: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject". Now trying the fallback factory...
2009-07-03 13:09:14,749 ERROR [geoserver.ows] -
org.vfny.geoserver.wcs.WcsException: java.io.IOException: The requested coverage could not be found.
  at org.geoserver.wcs.DefaultWebCoverageService111.getCoverage(DefaultWebCoverageService111.java:349)
  at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:310)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:182)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:149)
  at org.geoserver.ows.util.EMFLogger.invoke(EMFLogger.java:51)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
  at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
  at $Proxy14.getCoverage(Unknown Source)
  at org.geoserver.security.OperationSecurityInterceptor.invoke(OperationSecurityInterceptor.java:41)
  at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:583)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:212)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
  at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
  at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
  at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
  at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
  at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:265)
  at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
  at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
  at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275)
  at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:124)
  at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
  at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:174)
  at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:249)
  at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:149)
  at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
  at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
  at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:163)
  at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
  at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
  at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
  at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
  at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
  at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
  at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:206)
  at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
  at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
  at org.mortbay.jetty.Server.handle(Server.java:324)
  at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
  at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:828)
  at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:514)
  at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
  at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
  at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:395)
  at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
Caused by: java.io.IOException: The requested coverage could not be found.
  at org.geoserver.wcs.DefaultWebCoverageService111.getCoverage(DefaultWebCoverageService111.java:255)
  ... 67 more
2009-07-03 13:09:14,798 DEBUG [geotools.xml] - building schema for schema: http://www.opengis.net/ows/1.1
2009-07-03 13:09:15,397 DEBUG [geotools.xml] - Could not locate schema for: owsGetResourceByID.xsd.
2009-07-03 13:09:15,413 DEBUG [geotools.xml] - Could not locate schema for: owsDataIdentification.xsd.
2009-07-03 13:09:15,419 DEBUG [geotools.xml] - Could not locate schema for: owsCommon.xsd.
2009-07-03 13:09:15,428 DEBUG [geotools.xml] - building schema for schema: http://www.w3.org/1999/xlink
2009-07-03 13:09:15,442 DEBUG [geotools.xml] - Could not locate schema for: ows19115subset.xsd.
2009-07-03 13:09:15,452 DEBUG [geotools.xml] - building schema for schema: http://www.w3.org/XML/1998/namespace
2009-07-03 13:09:15,463 DEBUG [geotools.xml] - Could not locate schema for: owsGetCapabilities.xsd.
2009-07-03 13:09:15,772 DEBUG [geotools.xml] - Could not locate schema for: owsServiceIdentification.xsd.
2009-07-03 13:09:15,778 DEBUG [geotools.xml] - Could not locate schema for: owsDataIdentification.xsd.
2009-07-03 13:09:15,785 DEBUG [geotools.xml] - Could not locate schema for: owsServiceProvider.xsd.
2009-07-03 13:09:15,790 DEBUG [geotools.xml] - Could not locate schema for: ows19115subset.xsd.
2009-07-03 13:09:15,796 DEBUG [geotools.xml] - Could not locate schema for: owsOperationsMetadata.xsd.
2009-07-03 13:09:15,802 DEBUG [geotools.xml] - Could not locate schema for: owsCommon.xsd.
2009-07-03 13:09:15,804 DEBUG [geotools.xml] - Could not locate schema for: ows19115subset.xsd.
2009-07-03 13:09:15,806 DEBUG [geotools.xml] - Could not locate schema for: owsDomainType.xsd.
2009-07-03 13:09:15,816 DEBUG [geotools.xml] - Could not locate schema for: owsCommon.xsd.
2009-07-03 13:09:15,855 DEBUG [geotools.xml] - Could not locate schema for: owsExceptionReport.xsd.
2009-07-03 13:09:15,860 DEBUG [geotools.xml] - Could not resolve schema location: null to physical location.
2009-07-03 13:09:15,862 DEBUG [geotools.xml] - Could not locate schema for: owsDomainType.xsd.
2009-07-03 13:09:15,864 DEBUG [geotools.xml] - Could not locate schema for: owsContents.xsd.
2009-07-03 13:09:15,869 DEBUG [geotools.xml] - Could not locate schema for: owsDataIdentification.xsd.
2009-07-03 13:09:15,874 DEBUG [geotools.xml] - Could not locate schema for: owsInputOutputData.xsd.
2009-07-03 13:09:15,879 DEBUG [geotools.xml] - Could not locate schema for: owsManifest.xsd.
2009-07-03 13:09:15,891 DEBUG [geotools.xml] - Could not locate schema for: owsDataIdentification.xsd.
